Thank you very much for your answer. Good to know, that it is a Python garbage problem.
As part of a Multilevel Monte Carlo simulation, I am doing a Monte Carlo simulation for the estimation of e.g. the H1 norm of random PDE solutions.
The MWE below solves the Poisson equation on a unit square domain with a discontinuous coefficient given by a vertical line discontinuity at a random location x = random.uniform(0.2, 08). Left of the line the coefficient value is 0.1, right of the line the value is 10.
The mesh is adapted to the discontinuity, so for each PDE solve I have a different underlying mesh.
I need a very small error in my simulation and thus have to compute a lot of solution samples (in the millions).
In my code I am parallelizing on 6 CPUs over the samples with multiprocessing (mp.pool.starmap). This is not the best choice, since for large degrees of freedom it interferes with the parallelization inside fenics.solve, but still reduces my computational time.
When using mpirun with this MWE, it does not work for the adapted mesh (Error: Unable to extract local mesh data.) and with a non-adapted UnitSquareMesh it executes the same code 6 times.
I will have to rewrite my code, so that it parallelizes over the samples with mpirun properly.
The only other chance I see right now is to split the millions of samples into smaller computable sizes, save them to files and load them later in an extra session to compute the whole sum/average/estimation.
import fenics as fn
import mshr
from dolfin import MPI
def rand_field_line_strict(position_x):
tol = 10**(-14)
return fn.Expression("x[0] < position_x + tol ? low : high", position_x=position_x, low=0.1, high=10, tol=tol, degree=0)
def create_adapted_mesh(position_x, resolution):
polygon_mshr = mshr.Rectangle(fn.Point(0.0,0.0),fn.Point(1.0,1.0))
polygon_mshr.set_subdomain(1, mshr.Polygon([fn.Point(0.0, 0.0),\
fn.Point(position_x,0.0),\
fn.Point(position_x, 1.0),\
fn.Point(0.0, 1.0)]))
return mshr.generate_mesh(polygon_mshr, resolution)
if __name__=="__main__":
fn.set_log_level(30)
# Failed at ~2700
N_block = 1950
N_compute = 20000
# Block some MPI communicators to run into "RuntimeError" faster
for i in range(N_block):
print(i, MPI.comm_self.Dup())
MC_sum = 0
for i in range(N_compute):
print(i)
# Draw a uniformly distributed random number for the discontinuity position
position_x = np.random.uniform(0.2,0.8)
# Generate adapted mesh
mesh = create_adapted_mesh(position_x, 10)
# Set up and solve variational problem
V = fn.FunctionSpace(mesh, 'CG', 1)
u_D = fn.Expression("0", degree=0)
bc = fn.DirichletBC(V, u_D, 'on_boundary')
a = rand_field_line_strict(position_x)
f = fn.Constant(1.0)
u = fn.TrialFunction(V)
v = fn.TestFunction(V)
lhs = fn.dot(a*fn.grad(u),fn.grad(v))*fn.dx
rhs = f*v*fn.dx
sol = fn.Function(V)
fn.solve(lhs==rhs, sol, bc)
# Compute H1 norm
H1_norm = fn.norm(sol, 'H1')
# Add to MC sum
MC_sum += H1_norm
# Average
MC_sum /= N_compute
print("The Monte Carlo estimation yields: ", MC_sum)
Output:
2655
2656
2657
File âMC_estimation_MPI_test.pyâ, line 59, in
File â/home/beschlcc/.conda/envs/fenicsproject/lib/python3.8/site-packages/dolfin/function/function.pyâ, line 216, in init
self._cpp_object = cpp.function.Function(V._cpp_object)
RuntimeError:
*** Error: Unable to successfully call PETSc function âVecCreateâ.
*** Reason: PETSc error code is: 1 ((null)).
*** Where: This error was encountered inside /home/conda/feedstock_root/build_artifacts/fenics-pkgs_1582286059742/work/dolfin/dolfin/la/PETScVector.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: 15b823f2c45d3036b6af931284d0f8e3c77b6845
