Hello everyone, thanks for the help. I am trying to solve a parametric PDE multiple times. For that, I am trying to use MPI to distribute the computation of the different solutions. This is the first time I have used MPI. Currently, I am facing the issue that the computations freeze when I apply the boundary conditions. I guess it is because I am not assigning any communicator to the mesh. I am using a mesh obtained from meshr. I am having issues assigning the communicator the mesh.
For the creation of the mesh I followed ( Solving PDEs in Python -
The FEniCS Tutorial Volume I (fenicsproject.org))
Here is the code for this section
from mshr import Rectangle, Circle, generate_mesh
comm = MPI.COMM_WORLD
rank = comm.Get_rank()
size = comm.Get_size()
self_comm = MPI.COMM_SELF
channel = Rectangle(Point(0, 0), Point(1.0, 0.4))
cylinder = Circle(Point(0.2, 0.2), 0.05)
domain = channel - cylinder
mesh = generate_mesh(domain, 30)
mesh = comm.bcast(mesh, root=0)
The error I got is:
File “mpi4py/MPI/Comm.pyx”, line 1569, in mpi4py.MPI.Comm.bcast
File “mpi4py/MPI/msgpickle.pxi”, line 721, in mpi4py.MPI.PyMPI_bcast
File “mpi4py/MPI/msgpickle.pxi”, line 145, in mpi4py.MPI.pickle_dump
File “mpi4py/MPI/msgpickle.pxi”, line 131, in mpi4py.MPI.cdumps
TypeError: cannot pickle ‘dolfin.cpp.mesh.Mesh’ object
My second attempt was to generate the mesh directly using dolfin and assign the communicator in the creation of the RectangleMesh and CircleMesh. But I am getting the following error while creating the CircleMesh ( CircleMesh — FEniCS Project)
import dolfin as dl
Define the circle parameters
center = dl.Point(0.0, 0.0)
radius = 1.0
resolution = 32
Create the circle mesh
mesh = dl.cpp.mesh.CircleMesh(center, radius, resolution)
But I get the following error
module ‘dolfin.cpp.mesh’ has no attribute ‘CircleMesh’
My third attempt was to store the mesh, read it, and then assign it
file_name = ‘mesh_square_cyliner_ns.xml’
file_format = ‘xml’
if os.path.exists(file_name):
mesh = Mesh()
with XDMFFile(file_name) as infile:
infile.read(mesh)
Any help is appreciated! Thanks!
