I am solving the same problem on multiple processes with varying initial conditions. On each iteration I would like to collect the average of the solutions on rank 0 and then write them to file on rank 0 as well.
However, when I try to perform certain actions under the if mpi_rank == 0: condition, FEniCS hangs and I have to force quit the code.
Here is a MWE that shows my problem:
mpi_rank = MPI.rank(MPI.comm_world)
mpi_size = MPI.size(MPI.comm_world)
mesh = UnitSquareMesh(MPI.comm_self,2,2)
P1 = FiniteElement("P", mesh.ufl_cell(), 1)
W = FunctionSpace(mesh, P1)
N = Function(W)
m = Function(W)
m.vector()[:] = mpi_rank
mm = MPI.comm_world.reduce(m.vector()[:]/mpi_size,root=0)
if mpi_rank == 0:
N.vector()[:] = mm
File("average.pvd") << N
If I remove the File(“average.pvd”) << N line the code completes and if I print out the values of the function N it correctly has the average only on rank 0, but hangs with this line.
Of course this code works if I just do this on all processes but this is obviously not efficient with a lot of processes.
