Hi all,
I’m working on integrating MPI in my code but I think I do not fully understand what’s going on. Below are two snippets of code, With one difference; The problem is solved in all processes in the first snippet, and only in the process with rank 0 in the second.
I’d expect the second case to run in a similar time as the first, as only the first process is actually solving the problem and not all processes.
However, the second piece of code does not finish running as the program hangs on the problem.solve step.
import timeit
from dolfinx import FunctionSpace, Constant, fem, Function
from ufl import TrialFunction, TestFunction, inner, dx
comm = MPI.COMM_WORLD
rank = comm.rank
start_time = timeit.default_timer()
def p(str):
print(f"[Rank {rank} ({timeit.default_timer() - start_time:3.5f}s)] {str}")
N = 2 ** 11
mesh = dolfinx.UnitSquareMesh(MPI.COMM_WORLD, N, N, dolfinx.cpp.mesh.CellType.triangle)
V = FunctionSpace(mesh, ("CG", 1))
f = Constant(mesh, 4)
uh = Function(V)
A = inner(u, v) * dx
F = inner(f, v) * dx
p("Defining problem")
problem = fem.LinearProblem(A, F, u=uh)
p("Start solving")
problem.solve()
p("Finished")
With result
47ce1a25ceac:python3 -u /opt/project/threading_test.py 3
[Rank 1 (15.68399s)] Defining problem
[Rank 2 (15.68618s)] Defining problem
[Rank 0 (15.68862s)] Defining problem
[Rank 1 (17.02300s)] Start solving
[Rank 2 (17.02234s)] Start solving
[Rank 0 (17.02337s)] Start solving
[Rank 0 (20.09286s)] Finished
[Rank 1 (20.09350s)] Finished
[Rank 2 (20.09285s)] Finished
And the second piece of code:
import timeit
rank = comm.rank
def p(str):
N = 2 ** 11
uh = Function(V)
p("Start solving")
problem.solve()
if rank == 0:
p("Finished")
With result
b9e6cd267292:python3 -u /opt/project/threading_test.py 3
[Rank 2 (15.59279s)] Defining problem
[Rank 1 (15.59342s)] Defining problem
[Rank 0 (15.60022s)] Defining problem
[Rank 1 (16.80396s)] Start solving
[Rank 1 (16.80400s)] Finished
[Rank 2 (16.80393s)] Start solving
[Rank 2 (16.80398s)] Finished
[Rank 0 (16.80780s)] Start solving
Note that rank 0 does not get past the Start solving print statement
Can somebody give me a hint on what I’m missing in the understanding of MPI? This because I fear I’m missing some fundamental understanding.
I’m using v0.3.0 if that’s relevant
- Wouter
