Hello everyone,
I have updated my DOLFINx installation from 0.5.1 to 0.9.0. So far, I had never used parallelization through MPI. Instead, I used to set the environment variable OMP_NUM_THREADS (set and export) to a value >1 and I could see sufficient increase of performance.
After updating DOLFINx, I have noticed that this does not work in my installation anymore. When I run a simulation, only one thread is involved, no matter the value I give to such an environment variable.
Consequently, I have tried to use MPI parallelization (for my first time). However, when I do mpirun -n 2 python3 file.py, I oberserve in Paraview that there is a part of the mesh that does not deform. When I do python3 file.py, all the mesh deforms as expected (and the simulation takes longer).
The particular case I am studying is an implementation of spherical contact with the penalty method. I copy the code below. May the problem be related with: (i) the implementation of mpi in my code?; (ii) the visualization? Thank you in advance.
from numpy import array
import dolfinx.io
import math
import petsc4py
default_scalar_type = PETSc.ScalarType
from dolfinx import fem
import dolfinx.fem.petsc
import dolfinx.nls.petsc
name = "Output.xdmf" # Name of the output file
name1 = "Output.h5"
T = 0.25 # Final time
steps = 0 #Inizialization of the variable.
# Time parameters
tiempo = 0.0
tot_steps = 5;
dt = T / tot_steps
#Import mesh & subdomains from .msh file:
filename="Box"
from dolfinx.io import gmshio
mesh, cell_markers, facet_markers = gmshio.read_from_msh(filename+'.msh', MPI.COMM_WORLD, gdim=3)
metadata = {"quadrature_degree": 2}
dx = ufl.Measure('dx')(domain=mesh, subdomain_data=cell_markers, metadata=metadata) #Integration measures for each subdomain
# FUNCTION SPACES
V = dolfinx.fem.functionspace(mesh, ("CG",2,(mesh.geometry.dim, )))
VV = dolfinx.fem.functionspace(mesh,('CG',1, (mesh.geometry.dim, )))
# FUNCTIONS IN THE FUNCTION SPACE V (Function - Trial - Test).
u = dolfinx.fem.Function(V) #Unkown.
########## BOUNDARY CONDITIONS ############################################
def bnd_encastre(x):
tol = 1e-4
return np.logical_or.reduce((
np.isclose(x[2], 0, atol=tol), # Fix z = 0
np.isclose(x[0], 0, atol=tol), # Fix x = 0
np.isclose(x[1], 0, atol=tol), # Fix y = 0
np.isclose(x[0], 1, atol=tol), # Fix x = 1
np.isclose(x[1], 1, atol=tol) # Fix y = 1
bnd_encastre_dofs0 = dolfinx.fem.locate_dofs_geometrical(V,bnd_encastre)
u_encastre_vect0 = np.array((0,) * mesh.geometry.dim, dtype=default_scalar_type)
bc_boundar = dolfinx.fem.dirichletbc(u_encastre_vect0,bnd_encastre_dofs0,V)
bc = [bc_boundar]
########## CONTACT SURFACE #####################################
def bnd_side(x):
return np.isclose(x[2],1)
upper_facets = dolfinx.mesh.locate_entities_boundary(mesh, mesh.topology.dim - 1, bnd_side)
facet_upper_tag = dolfinx.mesh.meshtags(mesh, mesh.topology.dim - 1, upper_facets, 1)
ds_contact = ufl.Measure('ds', domain=mesh, subdomain_data=facet_upper_tag, subdomain_id=1)#, metadata=metadata)
########## OBSTACLE #####################################
d_ = dolfinx.fem.Constant(mesh, 0.0)
def obstacle(x):
h0 = 1.1
Rad = 0.3
return -d_ + h0 + 1/2/Rad * ((x[0]-0.5)**2 + (x[1]-0.5)**2)
## PRIMARY FIELDS
dd = len(u)
Id = ufl.Identity(dd)
F = Id + ufl.grad(u)
## CONSTITUTIVE MODEL:
######### NEO-HOOKEAN ##################################################################
def Piso(F,i):
j,k,l,m = ufl.indices(4)
FinvT = ufl.inv(F).T
A1 = ufl.as_tensor(Id[j,l]*Id[k,m],(j,k,l,m))
A2 = ufl.as_tensor(-1/3*FinvT[j,k]*F[l,m],(j,k,l,m))
Pfourth = A1+A2
Fiso = 1/ufl.det(F)**(1/3)*F
Piso_ = G[i]*Fiso
return 1/(ufl.det(F)**(1/3))*ufl.as_tensor(Pfourth[j,k,l,m]*Piso_[l,m],(j,k))
def Pvol(F,i):
return kappa[i]*ufl.det(F)*(ufl.det(F)-1)*ufl.inv(F).T
G = [1000,0]
poisson=[0.495,0,0]
kappa = [2*G[0]*(1+poisson[0])/3/(1-2*poisson[0]),0,0]
####### VARIATIONAL PROBLEM - WEAK FORM ################################################
pen = 1e4
Res_u = (ufl.inner(Piso(F, 0), ufl.grad(v))\
+ ufl.inner(Pvol(F, 0), ufl.grad(v))) * dx\
+ pen * (((u[2]+1)-obstacle(x)) + np.abs((u[2]+1)-obstacle(x)))/2 * v[2] * ds_contact(1)
# Setup Non-linear variational problem
problem = fem.petsc.NonlinearProblem(Res_u,u,bc)
from dolfinx import nls
solver_problem = nls.petsc.NewtonSolver(mesh.comm, problem)
solver_problem.atol = 1e-8
solver_problem.rtol = 1e-8
solver_problem.convergence_criterion = "incremental"
import os
if os.path.exists(name):
os.remove(name)
os.remove(name1)
# Save results into an .xdmf
file_results = dolfinx.io.XDMFFile(MPI.COMM_WORLD,name,'w')
# Write the mesh and subdomains info
file_results.write_mesh(mesh)
###### TIME-INCREMENTAL SOLVING LOOP ########################
while (tiempo < T):
#Display report simulation
from dolfinx import log
print("Iteration info", flush=True)
d_.value = tiempo
print("dt: ",dt)
print("Step: ",steps)
print("Tiempo: ",tiempo,"/",T)
solver_problem.solve(u)
log.set_log_level(log.LogLevel.OFF)
# Write to .xdmf results file
uVector=dolfinx.fem.Function(VV); uVector.name = "Displacement"; u_expr = dolfinx.fem.Expression(u, VV.element.interpolation_points()); uVector.interpolate(u_expr)
file_results.write_function(uVector,tiempo)
steps += 1
tiempo += dt
file_results.close()
print("Finished")
Note: the mesh is taken as input, but it is a simple unit square.
