I have a program, but it produces different results when running single core and multi-core, with multi-core appearing to have poor convergence. Many people are very certain that there must be a problem with my code rather than any other reason. The minimum simplified code that can reproduce this error is as follows:(dolfinx: v0.7.2)
import numpy
from dolfinx import mesh, fem
from ufl import sqrt, dot, grad, div, dx, rhs, lhs
domain = mesh.create_rectangle(MPI.COMM_WORLD, [(0,0),(12.5e-3,12.5e-3)],(50,50) )
##### Defining FunctionSpace
### Voltage
V = fem.FunctionSpace(domain, ("Lagrange", 1))
### Particle density
P = ufl.FiniteElement("Lagrange", domain.ufl_cell(), 1)
element_P = ufl.MixedElement([P, P])
N = fem.FunctionSpace(domain, element_P)
##### Create boundary condition
### anode_marker
def anode_marker(x):
return numpy.isclose(x[1], 12.5e-3)
### cathode_marker
def cathode_marker(x):
return numpy.isclose(x[1], 0)
### bc1
anode_boundary_entity = mesh.locate_entities_boundary(domain, 1, anode_marker)
anode_boundary_dof = fem.locate_dofs_topological(V, 1, anode_boundary_entity)
bc1_voltage = fem.dirichletbc(PETSc.ScalarType(18750), anode_boundary_dof, V)
### bc2
cathode_boundary_entity = mesh.locate_entities_boundary(domain, 1, cathode_marker)
cathode_boundary_dof = fem.locate_dofs_topological(V, 1, cathode_boundary_entity)
bc2_voltage = fem.dirichletbc(PETSc.ScalarType(0), cathode_boundary_dof, V)
##### Create initial condition
def gaussian_distribution(x, y, x0, y0, sigma, amplitude):
return amplitude * numpy.exp(-((x - x0)**2 + (y - y0)**2) / (sigma**2))
backgroud_density = 1e13
def partical_initial_condition(x):
return gaussian_distribution(x[0], x[1], 0, 10e-3, 0.4e-3, 5e18) + backgroud_density
partical_n = fem.Function(N)
partical_n.sub(0).interpolate(lambda x: numpy.full(x.shape[1], backgroud_density))
partical_n.sub(1).interpolate(partical_initial_condition)
##### Defining the variational problem
### problem_voltage
air_dielectric = fem.Constant(domain, PETSc.ScalarType(8.85e-12))
elementary_charge = fem.Constant(domain, PETSc.ScalarType(1.6e-19))
partical_n_electron, partical_n_positive = ufl.split(partical_n)
trial_voltage = ufl.TrialFunction(V)
test_voltage = ufl.TestFunction(V)
a_voltage = fem.form(dot(grad(trial_voltage), grad(test_voltage)) * x[0] * dx)
L_voltage = fem.form(elementary_charge / air_dielectric
* (partical_n_positive-partical_n_electron) * test_voltage * x[0] * dx)
voltage = fem.Function(V)
problem_voltage = LinearProblem(a_voltage, L_voltage, u=voltage,
bcs=[bc1_voltage, bc2_voltage],
petsc_options={"ksp_type": "cg",
### problem_partical
# compute difussion coefficient
E_mod = sqrt(dot(-grad(voltage), -grad(voltage)))
# compute particle velocity
velocity = grad(voltage)
trial_electron, trial_positive = ufl.TrialFunctions(N)
test_electron, test_positive = ufl.TestFunctions(N)
dt = fem.Constant(domain, 2e-12)
def axisymmetric_divergence(u):
div_u = (1 / x[0]) * (x[0] * u[0]).dx(0) + u[1].dx(1)
return div_u
F1 = (trial_electron - partical_n_electron) / dt * test_electron * x[0] * dx
F1 += axisymmetric_divergence(trial_electron * velocity) * test_electron * x[0] * dx
F2 = (trial_positive - partical_n_positive) / dt * test_positive * x[0] * dx
F = F1 + F2
a_partical = fem.form(lhs(F))
L_partical = fem.form(rhs(F))
partical = fem.Function(N)
problem_partical = LinearProblem(a_partical, L_partical, u=partical,
petsc_options={"ksp_type": "gmres",
"ksp_rtol": 1e-6})
xdmf_partical_electron = XDMFFile(MPI.COMM_WORLD, "result2.xdmf", "w")
xdmf_partical_electron.write_mesh(domain)
T = 0.2e-9
t = 0
i = 0
while t < T:
problem_voltage.solve()
xdmf_partical_electron.write_function(partical_n.sub(0), t)
t = t + dt.value
i = i + 1
problem_partical.solve()
partical_n.x.array[:] = partical.x.array
The results in XDMF file looks like this:
The one on the left is the result of single core running, while the one on the right is 2-core running. It can be intuitively seen that there is a strange numerical phenomenon in the middle of the 2-core result.
Another point is that if we change "ksp_rtol": 1e-6
to "ksp_rtol": 1e-12
, the running results of single core and multi-core can be consistent. So I suspect that the difference in results may be related to the way KSP works, as I have checked my simple code several times and do not think there is a problem.
Can anyone help? Thanks in advance!
