I am trying to run my job on multiple nodes. but when i look at the output, it seems like the job is not running in parallel.
this is my job submission script ![]()
#!/bin/bash
#SBATCH --job-name=gather
#SBATCH -N 4
#SBATCH --ntasks-per-node=1
#SBATCH --cpus-per-task=1
#SBATCH --exclusive
#SBATCH --switches=1
#SBATCH --time=14-00:00:00
#SBATCH --partition=normal
module load python-3.9.6-gcc-8.4.1-2yf35k6
echo "Job $SLURM_JOB_ID running on SLURM NODELIST: $SLURM_NODELIST"
mpirun -n 4 singularity exec /project/user/fenics/fenics.simg python3 ./run_test.py
I am getting output like
Job 30456205 running on SLURM NODELIST: rome[067-070]
Rank 0: 8128311 vertices (local)
Solving linear variational problem.
It seems like it is not distributing the mesh across the nodes. If I use singularity exec -e /project/user/fenics/fenics.simg mpirun -n 4 python3 ./run_test.py > output_test it now seems like it is distributing the mesh, but now the problem is the job runs using only one node. Other nodes, although showing assigned, remain idle.
