FEniCS using only one node on HPC machine. How do I use more than one?
I’m using FEniCS (2019.1.0) in anaconda (2019.10). I’m running my case with the mpirun in the conda environment. It runs fine on my local machine and will run on the cluster that my lab uses (uses SLURM scheduler). I also never ran into the issues described here or here either. The problem is that it runs on one node even when I specify more than one (currently just trying to use two). The reason I know this is that seff [jobid] shows that the job is killed for running out of memory, but I’ve only used half of it.
Is there something special that I need to be doing? I don’t know if maybe I’m not searching for the right thing?
Thanks.
FEniCS application:
# Environment setup
import os
# FEniCS imports
from ufl import nabla_div
#from mshr import *
import numpy
# Define communicator and rank for this process, in case we are running with MPI
mpi_comm = MPI.comm_world
mpi_rank = mpi_comm.Get_rank()
set_log_level(INFO)
# Variables
mu = 1          # Lame coefficient
rho = 1
beta = 1
lambda_ = beta  # Lame coefficient
tol = 1E-14     # Boundary condition cutoff
# Read the mesh
mesh = Mesh(mpi_comm)
with XDMFFile(mpi_comm, "mesh.xdmf") as infile:
    infile.read(mesh)
# Define a mesh value collection of dim = 3, for the cell data
# read boundaries
# Define function space
# Define the forcing function
el = V.ufl_element()
f = Expression(("0.", "0.", "500*t*x[0]*x[1]*x[2]"), t=0, element = el)
# Define boundary condition
def clamped_boundary(x, on_boundary):
    return on_boundary and x[2] < tol
bc = DirichletBC(V, Constant((0, 0, 0)), clamped_boundary)
# Define strain and stress
def sigma(u):
    return lambda_*nabla_div(u)*Identity(d) + 2*mu*epsilon(u)
# Define a and L and assemble matrix A
d = u.geometric_dimension()  # space dimension
Tr = Constant((0, 0, 0))
L = dot(f, v)*dx + dot(Tr, v)*ds
print("Assembling matrix.")
A = assemble(a)
# Create XDMF files for visualization output
xdmffile_u = XDMFFile(mpi_comm, 'results/displacement.xdmf')
# Time-stepping
print("Starting time loop.")
while t <= T:
    f.t = t             # Update forcing function
    b = assemble(L)     # Update b=f
    bc.apply(A,b)       # Apply bcs to updated b
    # Compute solution
    solve(A, u.vector(), b, "bicgstab")
    # Save solution to file (XDMF/HDF5)
    u.rename("u", "displacement")
    xdmffile_u.write(u, t)
    # Update time trackers
    i +=1
    t +=dt
    if mpi_rank == 0:
       print("We just solved for time t=", t-dt)
SLURM submission script:
#!/bin/bash
#SBATCH -p debug_queue
#SBATCH -N 2
#SBATCH --ntasks-per-node=44
#SBATCH --time=0-04:00:00
#SBATCH --job-name=fenics
module load anaconda/2019.10
conda init bash
source ~/.bashrc
conda activate fenicsproject
mpirun -n 88 python parallel.py
What seff is returning:
State: FAILED (exit code 137)
Nodes: 2
Cores per node: 44
CPU Utilized: 04:07:45
CPU Efficiency: 81.21% of 05:05:04 core-walltime
Job Wall-clock time: 00:03:28
Memory Utilized: 494.49 GB
Memory Efficiency: 49.16% of 1005.84 GB
Edits: a link and seff box
I notice in the download section, it says of the anaconda build (emphasis mine):
Update. 2017.2.0 release on conda-forge features MUMPS direct solver, but lacks SuperLU_dist and MPI-enabled HDF5.
I’m starting to understand that this also holds for the current version. Likewise, I ran it on one cpu and didn’t run into the memory issue at all.
If the cluster you’re using supports Singularity, I’d recommend trying that instead of the Anaconda build. Singularity is basically an HPC version of Docker, and you can automatically convert the FEniCS Docker images to Singularity images. This is the main way I’ve used FEniCS on clusters, including large multi-node computations that wouldn’t fit on a single node.
Oh, that’s what singularity is! Our cluster has a module. I’ll go try that right now and report back.
Edit: We have singularity 3.6.0. I’ve got a .sif file running from importing the docker file:
singularity build fenics.sif docker://quay.io/fenicsproject/stable:latest
and it’s running in serial with the command
singularity exec -B $PWD fenics.sif python3 demo_poisson.py
where demo_poisson.py is the usual poisson demo in the working directory. However, I’m still having issues with mpirun very similar to what is described here (and par_test.py is the script from that thread as well):
mpirun -n 4 singularity exec -B $PWD fenics.sif python3 par_test.py
rank / size:  0 / 1
rank / size:  0 / 1
rank / size:  0 / 1
rank / size:  0 / 1
I’ve tried a few other variations to no avail, but I think this has probably veered from the inital topic enough already.
Got it running with singularity (3.6.0). First made an image straight from Docker:
Then ran it with an mpich module. This was the cause of the error above. I’ve always used openmpi and didn’t even think that may have been the issue until running into these posts (1,2). The resulting batch script, assuming the file is in the working directory:
#!/bin/bash
#SBATCH -N 2
#SBATCH --time=0-00:10:00
#SBATCH --job-name=fenics_mpi_test
echo "Loading mpich and singularity"
module load mvapich2_2.3a/gcc_4.8.5
module load singularity/3.6.0
echo "Starting fenics simulation."
mpirun -n 88 singularity exec -B $PWD fenics.sif python3 par_test.py
Thanks for the suggestion to use singularity; it’s working out so far!
