My codes work in serial, but not in parallel due to issues with cache files
In the last months, I was trying to install FEniCS 2018.1.0 in my personal computer and in a cluster. After solving several problems during the installation process, I got to install FEniCS in my computer and I checked it works properly with some codes. However, the same code does not work in the cluster, even when the installation process is supposed to be completed.
I realized the program does not work properly when I tried to run my simulations in the cluster using more than one processor. During the simulation, it seems the program writes some temporal files in “.cache/”. When we are using only one processor, it is the only one which is reading and writing on those files and everything works correctly. When we try to increase the number of processors, each of them try to create their own temporal files, but they find those files that have been created by other processors. For this reason, it tries to back up the existing files, to remove them and to create its own temporal files. Due to this behavior, we can get two different results:
  • In some simulations, the different processors work coordinately and the simulation seems to work. However, the program is terribly slow, because it is making copies and moving files all the time. Moreover, I do not rely on the results, although I can not check them because the program is very slow.
  • In other simulations, when one of the processors is copying those temporal files, another processor try to access to one of those files, it does not find the right file and the program prints the error that is shown below (the error that is shown in that topic is an extract of the error that is printed):
Moving new file over differing existing file:
src: /tmp/tmp983p99_d/ffc_element_ee3c68ce6482b04838050db8ba0e96b7572c5935.cpp.gz
dst: /home/acastele/.cache/dijitso/src/ffc_element_ee3c68ce6482b04838050db8ba0e96b7572c5935.cpp.gz
backup: /home/acastele/.cache/dijitso/src/ffc_element_ee3c68ce6482b04838050db8ba0e96b7572c5935.cpp.gz.old
src: /tmp/tmp3fmi3u_z/ffc_element_ee3c68ce6482b04838050db8ba0e96b7572c5935.cpp.gz
Backup file exists, overwriting.
src: /tmp/tmpd9tfdgrg/ffc_element_ee3c68ce6482b04838050db8ba0e96b7572c5935.cpp.gz
src: /tmp/tmp_7qcgtkr/ffc_element_ee3c68ce6482b04838050db8ba0e96b7572c5935.cpp.gz
src: /tmp/tmp3fl3r0x6/ffc_element_ee3c68ce6482b04838050db8ba0e96b7572c5935.cpp.gz
src: /tmp/tmpj5jkkqik/ffc_element_ee3c68ce6482b04838050db8ba0e96b7572c5935.cpp.gz
File “/apps/cent7/anaconda/5.3.1-py37/lib/python3.7/shutil.py”, line 557, in move
os.rename(src, real_dst)
FileNotFoundError: [Errno 2] No such file or directory: ‘/home/acastele/.cache/dijitso/src/ffc_element_ee3c68ce6482b04838050db8ba0e96b7572c5935.cpp.gz’ -> ‘/home/acastele/.cache/dijitso/src/ffc_element_ee3c68ce6482b04838050db8ba0e96b7572c5935.cpp.gz.old.priv.265268745244341306884196712515058776583’
File “Elasticidad2D-Fractura.py”, line 165, in
V = FunctionSpace(mesh, U)
File “/home/acastele/.conda/envs/cent7/5.3.1-py37/FEniCS.env/lib/python3.7/site-packages/dolfin/function/functionspace.py”, line 31, in init
*self._init_from_ufl(*args, *kwargs)
File “/home/acastele/.conda/envs/cent7/5.3.1-py37/FEniCS.env/lib/python3.7/site-packages/dolfin/function/functionspace.py”, line 43, in _init_from_ufl
mpi_comm=mesh.mpi_comm())
File “/home/acastele/.conda/envs/cent7/5.3.1-py37/FEniCS.env/lib/python3.7/site-packages/dolfin/jit/jit.py”, line 47, in mpi_jit
*return local_jit(*args, *kwargs)
File “/home/acastele/.conda/envs/cent7/5.3.1-py37/FEniCS.env/lib/python3.7/site-packages/dolfin/jit/jit.py”, line 97, in ffc_jit
File “/home/acastele/.conda/envs/cent7/5.3.1-py37/FEniCS.env/lib/python3.7/site-packages/ffc/jitcompiler.py”, line 217, in jit
module = jit_build(ufl_object, module_name, parameters)
File “/home/acastele/.conda/envs/cent7/5.3.1-py37/FEniCS.env/lib/python3.7/site-packages/ffc/jitcompiler.py”, line 133, in jit_build
generate=jit_generate)
File “/home/acastele/.conda/envs/cent7/5.3.1-py37/FEniCS.env/lib/python3.7/site-packages/dijitso/jit.py”, line 165, in jit
header, source, dependencies = generate(jitable, name, signature, params[“generator”])
File “/home/acastele/.conda/envs/cent7/5.3.1-py37/FEniCS.env/lib/python3.7/site-packages/ffc/jitcompiler.py”, line 76, in jit_generate
dep_module_name = jit(dep, parameters, indirect=True)
File “/home/acastele/.conda/envs/cent7/5.3.1-py37/FEniCS.env/lib/python3.7/site-packages/dijitso/jit.py”, line 178, in jit
params)
File “/home/acastele/.conda/envs/cent7/5.3.1-py37/FEniCS.env/lib/python3.7/site-packages/dijitso/build.py”, line 181, in build_shared_library
lockfree_move_file(temp_src_filename, src_filename)
File “/home/acastele/.conda/envs/cent7/5.3.1-py37/FEniCS.env/lib/python3.7/site-packages/dijitso/system.py”, line 248, in lockfree_move_file
return _lockfree_move_file(src, dst, False)
File “/home/acastele/.conda/envs/cent7/5.3.1-py37/FEniCS.env/lib/python3.7/site-packages/dijitso/system.py”, line 275, in _lockfree_move_file
_lockfree_move_file(dst, backup, True)
File “/home/acastele/.conda/envs/cent7/5.3.1-py37/FEniCS.env/lib/python3.7/site-packages/dijitso/system.py”, line 287, in _lockfree_move_file
move_file(src, priv(ui))
File “/home/acastele/.conda/envs/cent7/5.3.1-py37/FEniCS.env/lib/python3.7/site-packages/dijitso/system.py”, line 234, in move_file
shutil.move(srcfilename, dstfilename)
File “/apps/cent7/anaconda/5.3.1-py37/lib/python3.7/shutil.py”, line 571, in move
copy_function(src, real_dst)
File “/apps/cent7/anaconda/5.3.1-py37/lib/python3.7/shutil.py”, line 257, in copy2
copyfile(src, dst, follow_symlinks=follow_symlinks)
File “/apps/cent7/anaconda/5.3.1-py37/lib/python3.7/shutil.py”, line 120, in copyfile
with open(src, ‘rb’) as fsrc:
FileNotFoundError: [Errno 2] No such file or directory: ‘/home/acastele/.cache/dijitso/src/ffc_element_ee3c68ce6482b04838050db8ba0e96b7572c5935.cpp.gz’ -> ‘/home/acastele/.cache/dijitso/src/ffc_element_ee3c68ce6482b04838050db8ba0e96b7572c5935.cpp.gz.old.priv.221521007679093248207297234337480157215’
The behavior of the program depends on the number of processors. However, if we increase the number of processors, it will be easier to get the error.
Below, I show one of the codes that works in my personal computer, but not in parallel in the cluster.
Define numerical simulation specific parameters
Define geometrical parameters
Lx = 1.000e+00
Ly = 1.000e+00
Define elasticity theory parameters
lame_lambda = 1.2115e+05
lame_mu = 8.0770e+04
Define fracture model parameters
Gc = 2.700e+00
Define movement parameters
umax = 2.500e-02
Define temporal parameters
time_ini_t = 0.000e+00
time_fin_t = 1.000e+00
time_dt = 1.000e-04
num_steps = 10000
Create mesh
Define empty mesh
mesh = Mesh()
Define mesh editor
editor = MeshEditor()
Open mesh editor
editor.open(mesh, "quadrilateral", 2, 2)
Set numerical simulation discretization options
Nx = 500
Ny = 500
p = 2
Define number of vertices
editor.init_vertices( ( Nx + 1 ) * ( Ny + 1 ) )
Define number of cells
editor.init_cells( Nx * Ny )
Define list of vertices for mesh
for j in range( Ny + 1 ):
	for i in range( Nx + 1 ):
		vertex_index = ( ( ( Nx + 1 ) * ( j ) ) + ( i ) )
		vertex_x = ( ( i ) * ( Lx / Nx ) )
		vertex_y = ( ( j ) * ( Ly / Ny ) )
		editor.add_vertex( vertex_index, [ vertex_x, vertex_y ] )
Define list of cells for mesh
for j in range( Ny ):
	for i in range ( Nx ):
		cell_index = ( ( Nx * j ) + ( i ) )
		cell_vertex_1 = ( ( ( Nx + 1 ) * ( j ) ) + ( i ) )
		cell_vertex_2 = ( ( ( Nx + 1 ) * ( j ) ) + ( i + 1 ) )
		cell_vertex_3 = ( ( ( Nx + 1 ) * ( j + 1 ) ) + ( i ) )
		cell_vertex_4 = ( ( ( Nx + 1 ) * ( j + 1 ) ) + ( i + 1 ) )
		editor.add_cell( cell_index, [ cell_vertex_1, cell_vertex_2, cell_vertex_3, cell_vertex_4 ] )
Close mesh editor
editor.close()
Define phase field parameters
l = ( 2 * mesh.hmin() )
Class for interfacing with the Newton solver
class Displacements_Equation(NonlinearProblem):
	def __init__(self, L, a, bc):
		self.L = L
		self.a = a
		self.bc = bc
	def F(self, b, x):
		assemble(self.L, tensor=b)
		self.bc[0].apply(b, x)
		self.bc[1].apply(b, x)
	def J(self, A, x):
		assemble(self.a, tensor=A)
		self.bc[0].apply(A)
		self.bc[1].apply(A)
class PhaseField_Equation(NonlinearProblem):
		self.L = L
		self.a = a
		self.bc = bc
	def F(self, b, x):
		self.bc.apply(b, x)
	def J(self, A, x):
		self.bc.apply(A)
Define function spaces
U = VectorElement("Lagrange", mesh.ufl_cell(), p)
M = FiniteElement("Lagrange", mesh.ufl_cell(), p)
P = FiniteElement("Lagrange", mesh.ufl_cell(), 1)
N = FunctionSpace(mesh, M)
Q = FunctionSpace(mesh, P)
Define trial and test functions
du = TrialFunction(V)
dm = TrialFunction(N)
n = TestFunction(N)
Define functions for solutions
m = Function(N)
p = Function(Q)
unew = Function(V)
mold = Function(N)
H = Function(Q)
Hold = Function(Q)
Define boundary conditions
Define values for boundary conditions
Value_Fixed = Constant((0.0, 0.0))
Value_Movement = Expression(("umax*t", "0.0"), degree = 1, umax = umax, t = 0.0)
Value_PhaseField = Constant(1.0)
Define boundaries for boundary conditions
class Boundaries_Bottom(SubDomain):
		return abs( x[1] ) < 1.0e-10 and on_boundary
class Boundaries_Top(SubDomain):
		return abs( x[1] - Ly ) < 1.0e-10 and on_boundary
class Boundaries_PhaseField(SubDomain):
		return x[0] <= Lx / 2. and abs( x[1] - Ly / 2. ) < 2.5e-03
BC_Fixed_Bottom = DirichletBC(V, Value_Fixed, Boundaries_Bottom())
BC_Movement_Top = DirichletBC(V, Value_Movement, Boundaries_Top())
BC_Displacements = [BC_Fixed_Bottom, BC_Movement_Top]
BC_PhaseField = DirichletBC(N, Value_PhaseField, Boundaries_PhaseField())
Define expressions used in variational forms
def Psi0(u):
	return ( ( lame_lambda / 2. ) * ( ( grad(u)[0, 0] + grad(u)[1, 1] ) ** ( 2. ) ) ) \
	     + ( ( lame_mu ) * ( ( ( grad(u)[0, 0] ) ** ( 2. ) ) + ( ( grad(u)[1, 1] ) ** ( 2. ) ) + ( grad(u)[0, 1] * grad(u)[1, 0] ) ) ) \
	     + ( ( lame_mu / 2. ) * ( ( ( grad(u)[0, 1] ) ** ( 2. ) ) + ( ( grad(u)[1, 0] ) ** ( 2. ) ) ) )
Define variational problem for time step
Equation_Displacements = ( ( ( ( 1. - mold ) ** ( 2 ) ) * ( inner( ( ( ( lame_lambda ) * ( div(u) ) * ( Identity(2) ) ) + ( ( 2. ) * ( lame_mu ) * ( ( 1. / 2. ) * ( ( grad(u) ) + ( grad(u).T ) ) ) ) ), ( ( 1. / 2. ) * ( ( grad(v) ) + ( grad(v).T ) ) ) ) ) ) * ( dx ) )
Equation_PhaseField_1 = ( ( ( ( l ) ** ( 2 ) ) * ( inner( ( grad(m) ), ( grad(n) ) ) ) ) * ( dx ) )
Equation_PhaseField_2 = ( ( ( ( 1. ) + ( ( ( 2. * l ) / ( Gc ) ) * ( H ) ) ) * ( inner( ( m ), ( n ) ) ) ) * ( dx ) )
Equation_PhaseField_3 = ( ( ( ( ( 2. * l ) / ( Gc ) ) * ( H ) ) * ( n ) ) * ( dx ) )
Equation_PhaseField = ( Equation_PhaseField_1 + Equation_PhaseField_2 - Equation_PhaseField_3 )
Compute directional derivative (Jacobian)
Jacobian_Displacements = derivative(Equation_Displacements, u, du)
Jacobian_PhaseField = derivative(Equation_PhaseField, m, dm)
Create nonlinear problem
Problem_Displacements = Displacements_Equation(Equation_Displacements, Jacobian_Displacements, BC_Displacements)
Problem_PhaseField = PhaseField_Equation(Equation_PhaseField, Jacobian_PhaseField, BC_PhaseField)
Create Newton solver
Displacements_solver = NewtonSolver()
Displacements_solver.parameters["absolute_tolerance"] = 1.000e-50
Displacements_solver.parameters["convergence_criterion"] = "residual"
Displacements_solver.parameters["error_on_nonconvergence"] = True
Displacements_solver.parameters["linear_solver"] = "cg"
Displacements_solver.parameters["maximum_iterations"] = 100
Displacements_solver.parameters["preconditioner"] = "hypre_euclid"
Displacements_solver.parameters["relative_tolerance"] = 1.000e-05
Displacements_solver.parameters["report"] = True
Displacements_solver.parameters["krylov_solver"]["absolute_tolerance"] = 1.000e-50
Displacements_solver.parameters["krylov_solver"]["error_on_nonconvergence"] = True
Displacements_solver.parameters["krylov_solver"]["maximum_iterations"] = 50000
Displacements_solver.parameters["krylov_solver"]["monitor_convergence"] = False
Displacements_solver.parameters["krylov_solver"]["relative_tolerance"] = 1.000e-05
Displacements_solver.parameters["krylov_solver"]["report"] = True
Displacements_solver.parameters["lu_solver"]["report"] = True
Displacements_solver.parameters["lu_solver"]["symmetric"] = True
Displacements_solver.parameters["lu_solver"]["verbose"] = True
info( Displacements_solver.parameters, True )
PhaseField_solver = NewtonSolver()
PhaseField_solver.parameters["absolute_tolerance"] = 1.000e-50
PhaseField_solver.parameters["convergence_criterion"] = "residual"
PhaseField_solver.parameters["error_on_nonconvergence"] = True
PhaseField_solver.parameters["linear_solver"] = "cg"
PhaseField_solver.parameters["maximum_iterations"] = 100
PhaseField_solver.parameters["preconditioner"] = "hypre_euclid"
PhaseField_solver.parameters["relative_tolerance"] = 1.000e-05
PhaseField_solver.parameters["report"] = True
PhaseField_solver.parameters["krylov_solver"]["absolute_tolerance"] = 1.000e-50
PhaseField_solver.parameters["krylov_solver"]["error_on_nonconvergence"] = True
PhaseField_solver.parameters["krylov_solver"]["maximum_iterations"] = 50000
PhaseField_solver.parameters["krylov_solver"]["monitor_convergence"] = False
PhaseField_solver.parameters["krylov_solver"]["relative_tolerance"] = 1.000e-05
PhaseField_solver.parameters["krylov_solver"]["report"] = True
PhaseField_solver.parameters["lu_solver"]["report"] = True
PhaseField_solver.parameters["lu_solver"]["symmetric"] = True
PhaseField_solver.parameters["lu_solver"]["verbose"] = True
info( PhaseField_solver.parameters, True )
Set form compiler options
info( parameters, True )
Define time - stepping
for i in range(num_steps):
Update current time
	time_t = ( ( time_ini_t ) + ( i * time_dt ) )
Update current time for boundary conditions
	Value_Movement.t = time_t
Solve variational problem for time step (step 1)
	print (" \n Solving Displacements Equation \n ")
	Displacements_solver.solve(Problem_Displacements, u.vector())
	unew.assign(u)
Update maximum strain energy
	Hn = project(Psi0(unew), Q)
	zz = np.maximum(Hn.vector().get_local(), Hold.vector().get_local())
	p.vector().set_local(zz)
	assign(H, p)
Solve variational problem for time step (step 2)
	print (" \n Solving PhaseField Equation \n ")
	PhaseField_solver.solve(Problem_PhaseField, m.vector())
	mold.assign(m)
Update historical maximum strain energy
	assign(Hold, p)
Save solution to file in VTK format
	if ( ( i % 400 ) == ( 0 ) ):
		print ( " \n\n Simulation Time: ", time_t, " \n\n " )
		u.rename( "Displacements", "Displacements" )
		m.rename( "PhaseField", "PhaseField" )
		vtkfile_Displacements = File( "/scratch/brown/acastele/simulations/Elasticity2D-FractureModel-Displacements-" + str(i) + ".pvd" )
		vtkfile_Displacements << ( u, time_t )
		vtkfile_PhaseField = File( "/scratch/brown/acastele/simulations/Elasticity2D-FractureModel-PhaseField-" + str(i) + ".pvd" )
		vtkfile_PhaseField << ( m, time_t )
Dear @acastele ,
I am not able to reproduce your error. However, running your problem in parallel on my own computer gave me some indications.
As far as I can understand, the problem is your mesh-generation with mesh editor. I don’t known if the mesh editor has parallel support, and even if it has, I would not recommend creating the mesh as part of the simulation.
Creating a similar mesh as you have in your problem can be done as follows:
Nx = 500
Ny = 500
mesh = UnitSquareMesh.create(Nx, Ny, CellType.Type.quadrilateral)
This results in the code running on my own computer (I did not do the full simulation, but I get passed the place where your code fails).
What happens if you reduce the mesh size and run it on your local computer in parallel?
I used docker:
docker run -ti --rm -v $(pwd):/home/fenics/shared/ -w /home/fenics/shared quay.io/fenicsproject/stable:2018.1.0.r3
Another note is that I would not recommend saving your solution as a “pvd” file when running in parallel. I recommend the HDF5 or XDMF-format .
Could you indicate if this helps?
I actually have the same issue.
I have a solver function for Nernst-Planck equation that runs flawlessly in serial, but I want to fit the diffusion coefficient for different datasets. So, I want to run a least squares optimization in parallel for each dataset. I implemented it using python’s multiprocessing and using
import multiprocessing as mp
if __name__ == '__main__':
    dataFiles   = files_with_extension(dataPath,'.h5')
    pool            = mp.Pool(processes=40)
    pool.map(fit_vfb,dataFiles)
vfb_fit is just a function that runs the least squares optimization, the minimal version does something like:
def vfb_fit(datafile):
   hf = h5py.File(dataFile,'r')
   x = np.array(hf['x'])
   y = np.array(hf['y'])
   def model(x,b):
        D = b[0]
        Cm = b[1]
        xsim,ysim = simulate_pnp(D,Cm,args)
        f = interpolate.interp1d(xsim,ysim)
        return f(x)
   def fobj(x,b)
       yinterp = model(x,b)
       return yinterp - y
   res = optimize.least_squares(fobj,[1E-1,2],kwargs)
   save_result(res)
I tried the code with just one datafile and it does work. But dijitso seems to mess with the cache files…
