Parallel Processing_error
Hello
I am using Fenics on Docker Windows
when i run a code with simple command python3 it runs properly, but issue is my system use only 1 or 2 logical processors and simulation is very slow but code run properly
when i try to use multi processor it produce errors
mpirun -n <no. of processors > python3
My Question is when code is running properly on single processor, than how i can run a code by using multiprocessors .???
Regards
You would need to provide a minimal code example that produces this error for anyone to give you any guidance.
def g(v,n):
return (1.0 - (1.0 - exp(-Re)) * n ) / (1.0 - exp(-Re)) *
conditional(ge(v,vn),1.0,0.0)
- (1.0 - conditional(ge(v,vn),1.0,0.0))*n
def f(v,n):
return (-v+(vstar-pow(n,M))*(1.0-ufl.tanh(v-vh))*pow(v,2)*0.5)
def hr(xi,n):
return K1 * xi*xi / (1 + n) - K2 * n
Magnetic field
def mg(v,mf):
return Km1*v - Km2 * mf +mfe
def In(v,mf):
return Km0pow(alp,mfbet)lamln(alp)* v
def varAngle(s):
return ((thetaEpi - thetaEndo) * s + thetaEndo)/ 180.0 * pi
def normalizeAndProj_vec(u):
return project(u/sqrt(dot(u,u)),FiberSpace)
def normalize_vec(u):
return u/sqrt(dot(u,u))
def comptauv(T,Ta,beta,tauv):
return tauv/(1+beta*(T-Ta))
def comptaun(T,Q10,Ta,taun):
return taun*pow(Q10,(Ta-T)/10.0)
def comptauxi(T,Q10,Ta,tauxi):
return tauxi*pow(Q10,(Ta-T)/10.0)
def comptaumf(T,Q10,Ta,taumf):
return taumf*pow(Q10,(Ta-T)/10.0)
t = 0.0; dt = 0.1; Tfinal=750;
freqSave = 1; inc = 0
stim_t0 = dt; stim_t2 = 350; stim_dur = 2.0; stim_amp = 2.0
******* Create mesh and define function spaces **********
mesh = Mesh(“square.xml”)
bdry = MeshFunction(“size_t”, mesh, “square_facet_region.xml”)
ds = Measure(“ds”, subdomain_data=bdry)
nn = FacetNormal(mesh)
its the error
First of all, you need to make sure the code is reproducable for others, i.e. avoid having external meshes as import.
Secondly, make sure you format the code in markdown syntax, i.e.
```python
def f(x):
    return x[0]
Thirdly, it is not adviced to use xml files when running in parallel. You should use xdmf files.
thank you, i try with xdmf, and i will take care next time regarding your instructions
