NameError: name 'Sphere' is not defined .?
CAN ANY ONE SUGGEST A SIMPLE WAY TO CREATE A SPHERICAL MESH OF CERTAIN RADIUS?
python3
import random
Create mesh and define function space with periodic boundary conditions
sphere = Sphere(Point(0, 0, 0), 200)
mesh = generate_mesh(sphere, 50)
P1 = FiniteElement(mesh,“CG”, 1)
ME = FunctionSpace(mesh, P1*P1,)
Class representing the intial conditions
class InitialConditions(UserExpression):
def init(self, **kwargs):
random.seed(2 + MPI.rank(MPI.comm_world))
super().init(*kwargs)
def eval(self, values, x):
values[0] = 0.50 + 0.02
(0.5 - random.random())
values[1] = 0.0
def value_shape(self):
return (2,)
Class for interfacing with the Newton solver
class CahnHilliardEquation(NonlinearProblem):
def init(self, a, L):
NonlinearProblem.init(self)
self.L = L
self.a = a
def F(self, b, x):
assemble(self.L, tensor=b)
def J(self, A, x):
assemble(self.a, tensor=A)
Model parameters
lmbda = 2 # surface parameter
dt = 0.5 # time step
theta = 0.5 # time stepping family, e.g. theta=1 → backward Euler, theta=0.5 → Crank-Nicolson
Form compiler options
parameters[“form_compiler”][“optimize”] = True
parameters[“form_compiler”][“cpp_optimize”] = True
Define trial and test functions
du = TrialFunction(ME)
q, v = TestFunctions(ME)
Define functions
u = Function(ME) # current solution
u0 = Function(ME) # solution from previous converged step
Split mixed functions
dc, dmu = split(du)
c, mu = split(u)
c0, mu0 = split(u0)
Create intial conditions and interpolate
u_init = InitialConditions(degree=1)
u.interpolate(u_init)
u0.interpolate(u_init)
Compute the chemical potential df/dc
c = variable(c)
f = 5*(c-0.3)*2(0.7-c)**2
dfdc = diff(f, c)
mu_(n+theta)
mu_mid = (1.0-theta)mu0 + thetamu
Weak statement of the equations
L0 = cqdx - c0qdx + dtdot(5grad(mu_mid), grad(q))dx
L1 = mu
vdx - dfdcvdx - dot(lmbdagrad(c), grad(v))*dx
L = L0 + L1
Compute directional derivative about u in the direction of du (Jacobian)
a = derivative(L, u, du)
Create nonlinear problem and Newton solver
problem = CahnHilliardEquation(a, L)
solver = NewtonSolver()
solver.parameters[“linear_solver”] = “lu”
solver.parameters[“convergence_criterion”] = “incremental”
solver.parameters[“relative_tolerance”] = 1e-6
Output file
file = File(“sol1/output.pvd”, “compressed”)
Step in time
t = 0.0
T = 200*dt
while (t < T):
u0.vector()[:] = u.vector()
solver.solve(problem, u.vector())
file << (u.split()[0], t)
Please format your code with 3x` notation, i.e.
```python
add your code here
Also, you do not need the full code that you are showing here to get to the question you are asking.
Sphere is part of the deprecated library mshr
Thus you need to install and import mshr to use that functionality.
Ref: Bitbucket
