Trying to disguise sphere with the Navier-Stokes equations
good day
I have tried to reproduce the results of [1], but I get the following error:
TypeError                                 Traceback (most recent call last)
File /usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/function.py:492, in Function.interpolate(self, u, cells, cell_map, expr_mesh, nmm_interpolation_data)
    490 try:
    491     # u is a Function or Expression (or pointer to one)
--> 492     _interpolate(u, cells)
    493 except TypeError:
    494     # u is callable
File /usr/lib/python3.10/functools.py:889, in singledispatch.<locals>.wrapper(*args, **kw)
    886     raise TypeError(f'{funcname} requires at least '
    887                     '1 positional argument')
--> 889 return dispatch(args[0].__class__)(*args, **kw)
File /usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/function.py:455, in Function.interpolate.<locals>._interpolate(u, cells)
    454 """Interpolate a cpp.fem.Function"""
--> 455 self._cpp_object.interpolate(u, cells, nmm_interpolation_data)
TypeError: interpolate(): incompatible function arguments. The following argument types are supported:
    1. interpolate(self, f: ndarray[dtype=float64, writable=False, shape=(*), order='C'], cells: ndarray[dtype=int32, writable=False, shape=(*), order='C']) -> None
    2. interpolate(self, f: ndarray[dtype=float64, writable=False, shape=(*, *), order='C'], cells: ndarray[dtype=int32, writable=False, shape=(*), order='C']) -> None
    3. interpolate(self, u: dolfinx.cpp.fem.Function_float64, cells: ndarray[dtype=int32, writable=False, shape=(*), order='C'], cell_map: ndarray[dtype=int32, writable=False, shape=(*), order='C'], nmm_interpolation_data: tuple[ndarray[dtype=int32, writable=False, shape=(*), order='C'], ndarray[dtype=int32, writable=False, shape=(*), order='C'], ndarray[dtype=float64, writable=False, shape=(*), order='C'], ndarray[dtype=int32, writable=False, shape=(*), order='C']]) -> None
    4. interpolate(self, expr: dolfinx.cpp.fem.Expression_float64, cells: ndarray[dtype=int32, writable=False, order='C'], expr_mesh: dolfinx.cpp.mesh.Mesh_float64, cell_map: ndarray[dtype=int32, writable=False, order='C']) -> None
Invoked with types: dolfinx.cpp.fem.Function_float64, function, ndarray, dolfinx.fem.function.PointOwnershipData
Cell In[13], line 60
     57     return values
     59 u_in = fem.Function(V)
---> 60 u_in.interpolate(inflow_profile)
     62 u_zero = fem.Function(V)
     63 u_zero.x.array[:] = 0
File /usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/function.py:497, in Function.interpolate(self, u, cells, cell_map, expr_mesh, nmm_interpolation_data)
    495 assert callable(u)
    496 x = _cpp.fem.interpolation_coords(self._V.element, self._V.mesh.geometry, cells)
--> 497 self._cpp_object.interpolate(np.asarray(u(x), dtype=self.dtype), cells)
RuntimeError: Interpolation data has the wrong shape/size.
I have tried to update the code with the new updates and this is the error I continue to have. I attach the updated code:
from dolfinx.cpp.mesh import CellType
from dolfinx.io import (XDMFFile)
from dolfinx.fem import (Constant, DirichletBC, Function, FunctionSpace, apply_lifting, assemble_matrix,
                         assemble_scalar, assemble_vector, create_vector, locate_dofs_topological, set_bc)
from ufl import (FacetNormal, Identity, Measure, TestFunction, TrialFunction,
                 as_vector, div, dot, ds, dx, inner, lhs, grad, nabla_grad, rhs, sym)
print(f"DOLFINx version: {dolfinx.__version__} is installed")
filename="sphere-4.xdmf"
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "sphere-4.xdmf", "r") as xdmf:
#### local mesh ####
## mesh = UnitCubeMesh(MPI.COMM_WORLD, 10, 10, 10)
t = 0.00
T = 1. #8                    # Final time
dt = 1./1600.                # Time step size
num_steps = int(T/dt)
k = Constant(mesh, dt)
mu = Constant(mesh, 0.001)  # Dynamic viscosity
rho = Constant(mesh, 0.5)     # Density
import dolfinx.fem as fem
Q = fem.functionspace(mesh, ("CG", 1))
eps=1e-14
def Inflow(x):
    return np.abs(x[0] - 0.) < eps
def Outflow(x):
    return np.abs(x[0] - 10.0) < eps
def Walls(x):
    result = np.logical_or(np.abs(x[1] + 0.) < eps, np.abs(x[1] - 5.) < eps)
    result2 = np.logical_or(np.abs(x[2] - 0.) < eps, np.abs(x[2] - 5.) < eps)
    return np.logical_or(result, result2)
def Sphere(x):
    result = np.logical_and(x[0] > 2.0 - eps, x[0] < 4.0 + eps)
    result2 = np.logical_and(x[1] > 2.0 - eps, x[1] < 4.0 + eps)
    result3 = np.logical_and(x[2] > 2.0 - eps, x[2] < 4.0 + eps)
    return np.logical_and(np.logical_and(result, result2), result3)
def inflow_profile(x):
    values = np.zeros((3, x.shape[1]), dtype=PETSc.ScalarType)
    values[0, :] = 1.0
    return values
#def inflow_profile(x):
#    values = np.zeros(x.shape)
#    values[0,:]=1
#    return values
V = fem.functionspace(mesh, ("CG", 2))
p_zero = fem.Function(Q)
p_zero.x.array[:] = 0
print("Forma de x:", x.shape)
print("Forma de valores:", values.shape)
inflow_boundary_dofs = fem.locate_dofs_geometrical(V, Inflow)
outflow_boundary_dofs = fem.locate_dofs_geometrical(Q, Outflow)
walls_boundary_dofs = fem.locate_dofs_geometrical(V, Walls)
sphere_boundary_dofs = fem.locate_dofs_geometrical(V, Sphere)
bcu_inflow = fem.DirichletBC(u_in, inflow_boundary_dofs)
bcp_outflow = fem.DirichletBC(p_zero, outflow_boundary_dofs)
bcu_walls = fem.DirichletBC(u_zero, walls_boundary_dofs)
bcu_sphere = fem.DirichletBC(u_zero, sphere_boundary_dofs)
bcu = [bcu_inflow, bcu_walls, bcu_sphere]
bcp = [bcp_outflow]
p = TrialFunction(Q)
q = TestFunction(Q)
# Define functions for solutions at previous and current time steps
u_n = Function(V)
u_ = Function(V)
p_n = Function(Q)
p_ = Function(Q)
U = 0.5 * (u_n + u)
f = Constant(mesh, PETSc.ScalarType((0,0,0)))
mu = Constant(mesh, PETSc.ScalarType(.001))
rho = Constant(mesh, PETSc.ScalarType(1))
# Define symmetric gradient
    return sym(nabla_grad(u))
# Define stress tensor
def sigma(u, p):
    return 2 * mu * epsilon(u) - p * Identity(len(u))
# Define variational problem for step 1
F1 = rho * dot((u - u_n) / k, v) * dx \
     + rho * dot(dot(u_n, nabla_grad(u_n)), v) * dx \
     + inner(sigma(U, p_n), epsilon(v)) * dx \
     + dot(p_n * n, v) * ds - dot(mu * nabla_grad(U) * n, v) * ds \
     - dot(f, v) * dx
a1 = lhs(F1)
L1 = rhs(F1)
a2 = dot(nabla_grad(p), nabla_grad(q)) * dx
L2 = dot(nabla_grad(p_n), nabla_grad(q)) * dx - (1 / k) * div(u_) * q * dx
a3 = dot(u, v) * dx
L3 = dot(u_, v) * dx - k * dot(nabla_grad(p_ - p_n), v) * dx
# Assemble matrices
#A1 = assemble(a1)
#A2 = assemble(a2)
#A3 = assemble(a3)
A1 = assemble_matrix(a1, bcs=bcu)
A1.assemble()
b1 = create_vector(L1)
A2.assemble()
b2 = create_vector(L2)
A3 = assemble_matrix(a3)
A3.assemble()
b3 = create_vector(L3)
# Solver for step 1
solver1 = PETSc.KSP().create(MPI.COMM_WORLD)
solver1.setOperators(A1)
pc1 = solver1.getPC()
pc1.setType(PETSc.PC.Type.JACOBI)
# Solver for step 2
solver2 = PETSc.KSP().create(MPI.COMM_WORLD)
solver2.setOperators(A2)
solver2.setType(PETSc.KSP.Type.MINRES)
pc2 = solver2.getPC()
pc2.setHYPREType("boomeramg")
# Solver for step 3
solver3 = PETSc.KSP().create(MPI.COMM_WORLD)
solver3.setOperators(A3)
pc3 = solver3.getPC()
import dolfinx.io
xdmf = dolfinx.io.XDMFFile(MPI.COMM_WORLD, "solution-4.xdmf", "w")
xdmf.write_mesh(mesh)
xdmf.write_function(u_n, t)
xdmf.write_function(p_n, t)
for i in range(num_steps):
    # Update current time step
    # Step 1: Tentative veolcity step
    with b1.localForm() as loc_1:
        loc_1.set(0)
    assemble_vector(b1, L1)
    set_bc(b1, bcu)
    solver1.solve(b1, u_.vector)
    u_.x.scatter_forward()
    # Step 2: Pressure corrrection step
    with b2.localForm() as loc_2:
        loc_2.set(0)
    assemble_vector(b2, L2)
    set_bc(b2, bcp)
    solver2.solve(b2, p_.vector)
    p_.x.scatter_forward()
    with b3.localForm() as loc_3:
        loc_3.set(0)
    assemble_vector(b3, L3)
    solver3.solve(b3, u_.vector)
    u_n.x.array[:] = u_.x.array[:]
    p_n.x.array[:] = p_.x.array[:]
    # Write solutions to file
# Close xmdf file
xdmf.close()
Can you help me with this error, please, I have already tried several solutions but none have worked. Also, I attach files from the old version with .h5 and .xdmf files [2]
DOLFINx version: 0.8.0 is installed
The issue is in defining the function space, as you are here defining a second order scalar element, while you want a vector element:
V = fem.functionspace(mesh, ("CG", 2, (mesh.geometry.dim, )))
Please also note that you need to change
to
bcu_inflow = fem.dirichletbc(u_in, inflow_boundary_dofs)
bcp_outflow = fem.dirichletbc(p_zero, outflow_boundary_dofs)
bcu_walls = fem.dirichletbc(u_zero, walls_boundary_dofs)
bcu_sphere = fem.dirichletbc(u_zero, sphere_boundary_dofs)
and
to
     - dot(f, v) * dx
a1 = dolfinx.fem.form(lhs(F1))
L1 = dolfinx.fem.form(rhs(F1))
a2 = dolfinx.fem.form(dot(nabla_grad(p), nabla_grad(q)) * dx)
L2 = dolfinx.fem.form(dot(nabla_grad(p_n), nabla_grad(q)) * dx - (1 / k) * div(u_) * q * dx)
a3 = dolfinx.fem.form(dot(u, v) * dx)
L3 = dolfinx.fem.form(dot(u_, v) * dx - k * dot(nabla_grad(p_ - p_n), v) * dx)
I would also change the imports
to
from dolfinx.fem import (Constant, Function, )
from dolfinx.fem.petsc import (apply_lifting, assemble_matrix, set_bc, assemble_vector, create_vector)
You should also change the outputting to VTXWriter.
Please note that an up to date splitting scheme for DOLFINx is available at: Test problem 2: Flow past a cylinder (DFG 2D-3 benchmark) — FEniCSx tutorial
Thank you very much for your help. The program works well, but it consumes a lot of computational resources. Therefore, I wanted to know how to do the same code but now with the steady-state Navier-Stokes equations. If you can help me with a guide, please. Regards.
Steady-state Navier-Stokes means that you need to remove the time derivative from your problem. However, you should ensure that the splitting scheme makes sense for this.
The code shouldn’t change too much, as you can simply remove some temporal loops.
