Navier stokes lid driven cavity flow
I am trying to run this older example of a lid driven cavity
I was able to replace the element definitions by using basix:
# the same as old ufl.VectorElement
# the same as old ufl.FiniteElement
P2 = basix.ufl.element("Lagrange", msh.topology.cell_name(), 2, shape=(msh.geometry.dim, ))
P1 = basix.ufl.element("Lagrange", msh.topology.cell_name(), 1)
but I can’t find how to create a function space by combining elements in the current version of fenicsx.
This line:
TH = P2 * P1
Generates this error:
TypeError: unsupported operand type(s) for *: '_BlockedElement' and '_BasixElement'
Thank you,
Alex
The code I’m trying to update is here:
from dolfinx import mesh, fem, nls
from ufl import inner, div, grad, dx
import basix
msh = mesh.create_unit_square(MPI.COMM_WORLD, 40, 40, mesh.CellType.triangle)
nu = 0.001
# Function to mark x = 0, x = 1 and y = 0
def noslip_boundary(x):
    return np.logical_or(np.logical_or(np.isclose(x[0], 0.0), np.isclose(x[0], 1.0)), np.isclose(x[1], 0.0))
# Function to mark the lid (y = 1)
def lid(x):
    return np.isclose(x[1], 1.0)
# Lid velocity#
def lid_velocity_expression(x):
    return np.stack((np.ones(x.shape[1]), np.zeros(x.shape[1])))
V, Q = fem.functionspace(msh, P2), fem.functionspace(msh, P1)
# Create the function space
TH = P2 * P1
W = fem.FunctionSpace(msh, TH)
W0, _ = W.sub(0).collapse()
# No slip boundary condition
noslip = fem.Function(V)
facets = mesh.locate_entities_boundary(msh, 1, noslip_boundary)
dofs = fem.locate_dofs_topological((W.sub(0), V), 1, facets)
bc0 = fem.dirichletbc(noslip, dofs, W.sub(0))
# Driving velocity condition u = (1, 0) on top boundary (y = 1)
lid_velocity = fem.Function(W0)
lid_velocity.interpolate(lid_velocity_expression)
facets = mesh.locate_entities_boundary(msh, 1, lid)
bc1 = fem.dirichletbc(lid_velocity, dofs, W.sub(0))
# Since for this problem the pressure is only determined up to a constant, we pin the pressure at the point (0, 0)
zero = fem.Function(Q)
zero.x.set(0.0)
dofs = fem.locate_dofs_geometrical(
    (W.sub(1), Q), lambda x: np.isclose(x.T, [0, 0, 0]).all(axis=1))
bc2 = fem.dirichletbc(zero, dofs, W.sub(1))
bcs = [bc0, bc1, bc2]
w = fem.Function(W)
(u, p) = ufl.split(w)
(v, q) = ufl.TestFunctions(W)
# Tentative velocity step
F = inner(grad(u)*u, v)*dx + nu*inner(grad(u), grad(v)) * \
    dx - div(v)*p*dx - q*div(u)*dx
dw = ufl.TrialFunction(W)
dF = ufl.derivative(F, w, dw)
problem = fem.petsc.NonlinearProblem(F, w, bcs=bcs, J=dF)
solver = nls.petsc.NewtonSolver(MPI.COMM_WORLD, problem)
solver.rtol = 1e-6
solver.report = True
ksp = solver.krylov_solver
opts = PETSc.Options()
ksp.setFromOptions()
# Compute the solution
solver.solve(w)
u = w.sub(0).collapse()
p = w.sub(1).collapse()
Ok I solved it using basix.ufl.mixed_element
See
which instructs you that you can use basix.ufl.mixed_element
I just found it thank you!
The other issue was this line:
zero.x.set(0.0)
I solved it by using:
zero.x.array[:] = 0
Now the code runs but it doesn’t converge,
RuntimeError: Newton solver did not converge because maximum number of iterations reached
The viscosity and all other parameters are the same as the original code, the latest code is the following:
import basix
nu = 0.001
def lid(x):
# Lid velocity#
TH = basix.ufl.mixed_element([P2, P1])
W = fem.functionspace(msh, TH)
zero.x.array[:] = 0
w = fem.Function(W)
solver.rtol   = 1e-6
solver.solve(w)
Ok, its working now, had to make the (kinematic?) viscosity ten times higher, and took out the
PETSc options. For the xdmf files, is it possible to store both velocity and pressure in the same xdmf file using XDMFFile? How can you name them so they show the names in ParaView?
The full running code is here:
import basix
msh = mesh.create_unit_square(MPI.COMM_WORLD, 100, 100, mesh.CellType.triangle)
nu = 0.01
def lid(x):
# Lid velocity#
zero.x.array[:] = 0
w = fem.Function(W)
problem = NonlinearProblem(F, w, bcs=bcs, J=dF)
solver.rtol   = 1e-6
solver.error_on_nonconvergence = True
#solver.max_it = 10
solver.solve(w)
# Write the solution to file
with io.XDMFFile(MPI.COMM_WORLD, "pressure.xdmf", "w") as pfile_xdmf:
    p.x.scatter_forward()
    pfile_xdmf.write_mesh(msh)
    pfile_xdmf.write_function(p)
with io.XDMFFile(MPI.COMM_WORLD, "velocity.xdmf", "w") as ufile_xdmf:
    u.x.scatter_forward()
    P1 = basix.ufl.element("Lagrange", msh.basix_cell(), 1, shape=(msh.geometry.dim,))
    u1 = fem.Function(fem.functionspace(msh, P1))
    u1.interpolate(u)
    ufile_xdmf.write_mesh(msh)
    ufile_xdmf.write_function(u1)
