Error in Solving Steady Navier Stokes Equation
I’m trying to convert my legacy FEniCS codes to FEniCSx to solve steady incompressible NSE with the Newton method for a Lid-Driven Cavity. I’m not able to set up the nonlinear solver properly.
The FEniCS code is:
# Define function spaces (Taylor-Hood)
V = VectorElement("Lagrange", mesh.ufl_cell(), 2)
Q = FiniteElement("Lagrange", mesh.ufl_cell(), 1)
# Make a mixed space
TH = V * Q
W = FunctionSpace(mesh, TH)
# Define unknown and test function(s)
(v, q) = TestFunctions(W)
w = Function(W)
(u, p) = (as_vector((w[0], w[1])), w[2])
# Tentative velocity step
F =   inner(grad(u)*u, v)*dx + nu*inner(grad(u), grad(v))*dx \
    - div(v)*p*dx \
    - q*div(u)*dx
dw = TrialFunction(W)
dF = derivative(F, w, dw)
nsproblem = NonlinearVariationalProblem(F, w, bc, dF)
solver = NonlinearVariationalSolver(nsproblem)
solver.solve()
# Extract solutions:
(u, p) = w.split()
The FEniCSx code is:
msh = mesh.create_unit_square(MPI.COMM_WORLD, 40, 40, mesh.CellType.triangle)
nu = 0.001
# Function to mark x = 0, x = 1 and y = 0
def noslip_boundary(x):
    return np.logical_or(np.logical_or(np.isclose(x[0], 0.0), np.isclose(x[0], 1.0)), np.isclose(x[1], 0.0))
# Function to mark the lid (y = 1)
def lid(x):
    return np.isclose(x[1], 1.0)
# Lid velocity
def lid_velocity_expression(x):
    return np.stack((np.ones(x.shape[1]), np.zeros(x.shape[1])))
P2 = ufl.VectorElement("Lagrange", msh.ufl_cell(), 2)
P1 = ufl.FiniteElement("Lagrange", msh.ufl_cell(), 1)
V, Q = fem.FunctionSpace(msh, P2), fem.FunctionSpace(msh, P1)
# Create the function space
TH = P2 * P1
W = fem.FunctionSpace(msh, TH)
W0, _ = W.sub(0).collapse()
# No slip boundary condition
noslip = fem.Function(V)
facets = mesh.locate_entities_boundary(msh, 1, noslip_boundary)
dofs = fem.locate_dofs_topological((W.sub(0), V), 1, facets)
bc0 = fem.dirichletbc(noslip, dofs, W.sub(0))
# Driving velocity condition u = (1, 0) on top boundary (y = 1)
lid_velocity = fem.Function(W0)
lid_velocity.interpolate(lid_velocity_expression)
facets = mesh.locate_entities_boundary(msh, 1, lid)
bc1 = fem.dirichletbc(lid_velocity, dofs, W.sub(0))
# Since for this problem the pressure is only determined up to a constant, we pin the pressure at the point (0, 0)
zero = fem.Function(Q)
zero.x.set(0.0)
dofs = fem.locate_dofs_geometrical((W.sub(1), Q), lambda x: np.isclose(x.T, [0, 0, 0]).all(axis=1))
bc2 = fem.dirichletbc(zero, dofs, W.sub(1))
bcs = [bc0, bc1, bc2]
(v, q) = ufl.TestFunctions(W)
F = inner(grad(u)*u, v)*dx + nu*inner(grad(u), grad(v))*dx - div(v)*p*dx - q*div(u)*dx
w = fem.Function(W)
dw = ufl.TrialFunction(W)
dF = ufl.derivative(F, w, dw)
problem = fem.petsc.NonlinearProblem(F, w, bcs=[bcs], J=dF)
solver = nls.petsc.NewtonSolver(MPI.COMM_WORLD, problem)
solver.rtol = 1e-6
solver.report = True
ksp = solver.krylov_solver
opts = PETSc.Options()
ksp.setFromOptions()
# Compute the solution
ksp.solve(w.vector)
u = w.sub(0).collapse()
p = w.sub(1).collapse()
This produces an error:
  File "/Users/varunkumar/Downloads/FEniCSx v0.6/SteadyNSE-Lid.py", line 67, in <module>
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/fem/petsc.py", line 683, in __init__
    self._L = _create_form(F, form_compiler_options=form_compiler_options,
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 176, in form
    return _create_form(form)
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 171, in _create_form
    return _form(form)
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 145, in _form
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/jit.py", line 56, in mpi_jit
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/jit.py", line 204, in ffcx_jit
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ffcx/codegeneration/jit.py", line 186, in compile_forms
    impl = _compile_objects(decl, forms, form_names, module_name, p, cache_dir,
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ffcx/codegeneration/jit.py", line 250, in _compile_objects
    _, code_body = ffcx.compiler.compile_ufl_objects(ufl_objects, prefix=module_name, options=options)
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ffcx/compiler.py", line 97, in compile_ufl_objects
    analysis = analyze_ufl_objects(ufl_objects, options)
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ffcx/analysis.py", line 86, in analyze_ufl_objects
    form_data = tuple(_analyze_form(form, options) for form in forms)
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ffcx/analysis.py", line 86, in <genexpr>
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ffcx/analysis.py", line 164, in _analyze_form
    form_data = ufl.algorithms.compute_form_data(
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ufl/algorithms/compute_form_data.py", line 407, in compute_form_data
    check_form_arity(preprocessed_form, self.original_form.arguments(), complex_mode)  # Currently testing how fast this is
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ufl/algorithms/check_arities.py", line 177, in check_form_arity
    check_integrand_arity(itg.integrand(), arguments, complex_mode)
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ufl/algorithms/check_arities.py", line 159, in check_integrand_arity
    arg_tuples = map_expr_dag(rules, expr, compress=False)
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ufl/corealg/map_dag.py", line 36, in map_expr_dag
    result, = map_expr_dags(function, [expression], compress=compress,
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ufl/corealg/map_dag.py", line 99, in map_expr_dags
    r = handlers[v._ufl_typecode_](v, *[vcache[u] for u in v.ufl_operands])
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ufl/algorithms/check_arities.py", line 63, in product
    raise ArityMismatch("Multiplying expressions with overlapping form argument number {0}, argument is {1}.".format(x[0].number(), _afmt(x)))
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ufl/algorithms/check_arities.py", line 19, in _afmt
    return tuple("conj({0})".format(arg) if conj else str(arg)
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ufl/algorithms/check_arities.py", line 20, in <genexpr>
    for arg, conj in atuple)
ValueError: too many values to unpack (expected 2)
I think there are mistakes in the nonlinear solver setup and in the trial functions u & p. Any help will be much appreciated.
These should not be trial-functions. They should be a function,
i.e.
w = Function(W)
u, p = ufl.split(w)
I changed u & p to functions just as you instructed. Now I’m getting an error in the compute statement:
w = fem.Function(W)
u, p = ufl.split(w)
solver.rtol = 1e-6
ksp.solve(w)
This gives an error:
    ksp.solve(w)
  File "PETSc/KSP.pyx", line 398, in petsc4py.PETSc.KSP.solve
TypeError: solve() takes exactly 2 positional arguments (1 given)
In the tutorial solve() had one argument. Please let me know how to correct this.
You shouldn’t call the ksp solver directly, you should call the Newton solver, ie, solver.solve(w)
I did precisely that earlier but that didn’t work either. When I ran this:
n = solver.solve(w)
It gave out an error:
    n = solver.solve(w)
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/nls/petsc.py", line 41, in solve
    n, converged = super().solve(u.vector)
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/fem/petsc.py", line 730, in F
    apply_lifting(b, [self._a], bcs=[self.bcs], x0=[x], scale=-1.0)
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/fem/petsc.py", line 494, in apply_lifting
    assemble.apply_lifting(b_local.array_w, a, bcs, x0_r, scale, constants, coeffs)
  File "/Users/varunkumar/opt/anaconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/fem/assemble.py", line 307, in apply_lifting
    _cpp.fem.apply_lifting(b, a, constants, coeffs, bcs, x0, scale)
TypeError: apply_lifting(): incompatible function arguments. The following argument types are supported:
    1. (b: numpy.ndarray[numpy.float32], a: List[dolfinx::fem::Form<float>], constants: List[numpy.ndarray[numpy.float32]], coeffs: List[Dict[Tuple[dolfinx::fem::IntegralType, int], numpy.ndarray[numpy.float32]]], bcs1: List[List[dolfinx::fem::DirichletBC<float>]], x0: List[numpy.ndarray[numpy.float32]], scale: float) -> None
    2. (b: numpy.ndarray[numpy.float64], a: List[dolfinx::fem::Form<double>], constants: List[numpy.ndarray[numpy.float64]], coeffs: List[Dict[Tuple[dolfinx::fem::IntegralType, int], numpy.ndarray[numpy.float64]]], bcs1: List[List[dolfinx::fem::DirichletBC<double>]], x0: List[numpy.ndarray[numpy.float64]], scale: float) -> None
    3. (b: numpy.ndarray[numpy.complex64], a: List[dolfinx::fem::Form<std::__1::complex<float> >], constants: List[numpy.ndarray[numpy.complex64]], coeffs: List[Dict[Tuple[dolfinx::fem::IntegralType, int], numpy.ndarray[numpy.complex64]]], bcs1: List[List[dolfinx::fem::DirichletBC<std::__1::complex<float> >]], x0: List[numpy.ndarray[numpy.complex64]], scale: float) -> None
    4. (b: numpy.ndarray[numpy.complex128], a: List[dolfinx::fem::Form<std::__1::complex<double> >], constants: List[numpy.ndarray[numpy.complex128]], coeffs: List[Dict[Tuple[dolfinx::fem::IntegralType, int], numpy.ndarray[numpy.complex128]]], bcs1: List[List[dolfinx::fem::DirichletBC<std::__1::complex<double> >]], x0: List[numpy.ndarray[numpy.complex128]], scale: float) -> None
Invoked with: array([0., 0., 0., ..., 0., 0., 0.]), [<dolfinx.fem.forms.Form object at 0x1343608b0>], [array([], dtype=float64)], [{(<IntegralType.cell: 0>, -1): array([[0., 0., 0., ..., 0., 0., 0.],
       [0., 0., 0., ..., 0., 0., 0.]])}], [[[<dolfinx.fem.bcs.DirichletBC object at 0x100b6afc0>, <dolfinx.fem.bcs.DirichletBC object at 0x1342cf240>, <dolfinx.fem.bcs.DirichletBC object at 0x1342cf420>]]], [array([0., 0., 0., ..., 0., 0., 0.])], -1.0
Did you forget to `#include <pybind11/stl.h>`? Or <pybind11/complex.h>,
<pybind11/functional.h>, <pybind11/chrono.h>, etc. Some automatic
conversions are optional and require extra headers to be included
when compiling your pybind11 module.
I also tried (u, p) = (ufl.as_vector((w[0], w[1])), w[2]) but that didn’t work either. I tried this from the tutorial:
n, converged = solver.solve(uh)
assert(converged)
but this too gave the same error. Please help me.
Replace bcs=[bcs] with bcs=bcs.
Full working code:
from dolfinx import mesh, fem, nls
from ufl import inner, div, grad, dx
nu = 0.001
def lid(x):
# Lid velocity#
TH = P2 * P1
zero.x.set(0.0)
w = fem.Function(W)
(u, p) = ufl.split(w)
F = inner(grad(u)*u, v)*dx + nu*inner(grad(u), grad(v)) * \
problem = fem.petsc.NonlinearProblem(F, w, bcs=bcs, J=dF)
solver.rtol = 1e-6
solver.solve(w)
Hi @dokken, can you elaborate why (u,p) should not be trial functions?
A TrialFunction is an instruction that tells FEniCS (and the underlying code compiler FFCx) that one should create an integration tensor where one chooses each of the basis-functions \phi_i(x), i=1,\dots, N to integrate against.
For a non-linear problem, you want to solve a problem of the form
Find u_h\in V such that
F(u,v) = 0\qquad \forall v\in V
where u_h=\sum_{i=0}^Nc_i \phi_i(x).
To solve this potentially non-linear equation, you set up a Newton-type algorithm, as described in:
