Navier Stokes simulation getting slower with time
I am trying to implement a large eddy simulation with the Smagorinsky turbulence model. Nevertheless, I encounter that my simulation is much slower than the one from the Navier-Stokes tutorial from Dokken, which I am using to validate my implementation. The results are almost identical (see images below) but Dokken’s code runs very fast and mine is incredibly slow.
For 200 iterations using 8 MPI threads, Dokken’s code performs at an average of ~49 iter/s.
With the same number of threads and iterations, mine starts at ~1.5 iter/s, and keeps getting slower until reaching about 0.15 iter/s at iteration 200 (6 seconds per iteration :skull:).
The only explanation I can think of is that the calculation of |S| is very expensive, but it doesen’t seem argument enough to get a simulation 300 times slower.
The details of the model:
  • Equations
\frac{\partial u}{\partial t} + (u\cdot\nabla)u = -\frac{1}{\rho}\nabla p^{\star} + (\nu + \nu_T) \nabla^2u \\ \nu_T = C_s^2 \Delta^2 |S| \\ S_{ij} = \frac{1}{2}\left( \frac{\partial u_i}{\partial x_j} + \frac{\partial u_j}{\partial x_i} \right)
where |S| = (2S_{ij}S_{ij})^{1/2} and \Delta is the mesh size.
  • Code (the mesh generation is the same as in the tutorial with the exception of some modifications to L, H). Sorry for the comments in Spanish, they are not too meaningfull
import os
import tqdm.autonotebook
from dolfinx.fem import (Constant, Function, FunctionSpace,
                         assemble_scalar, dirichletbc, form, locate_dofs_topological, set_bc)
                               create_vector, create_matrix, set_bc)
from dolfinx.io import (VTXWriter, distribute_entity_data, gmshio)
from ufl import (FacetNormal, FiniteElement, Identity, Measure, TestFunction, TrialFunction, VectorElement,
                 as_vector, div, dot, ds, dx, inner, lhs, grad, nabla_grad, rhs, sym)
from ufl import sqrt, sin
#                 PARÁMETROS Y DOMINIO DE LA SIMULACIÓN
# Parámetros espaciales
L = 2.0
H = 0.5
c_x = c_y = 0.25
r = 0.05
gdim = 2
fdim = gdim - 1
# Mesh
mesh, _, ft = gmshio.read_from_msh("cyllinder.msh", MPI.COMM_WORLD, rank=0, gdim=gdim)
inlet_marker, outlet_marker, wall_marker, obstacle_marker = 2, 3, 4, 5
# Parámetros temporales y físicos
t = 0.0
T = 2.0
num_steps = 2000
dt = T / num_steps
dt = Constant(mesh, PETSc.ScalarType(dt))
mu = Constant(mesh, PETSc.ScalarType(1.0e-4))  # Viscosidad dinámica (cambiar)
rho = Constant(mesh, PETSc.ScalarType(1.0))   # Densidad (cambiar)
nu = Constant(mesh, PETSc.ScalarType(mu/rho))  # Viscosidad cinemática
f = Constant(mesh, PETSc.ScalarType((0, 0)))  # Body forces
resolution = PETSc.ScalarType(r)
Cs = PETSc.ScalarType(0.035)  # Constante de Smagorinsky
#        ESPACIOS DE FUNCIONES Y FUNCIONES: ELEMENTOS TAYLOR-HOOD
vector_element = VectorElement("CG", mesh.ufl_cell(), 2)
scalar_element = FiniteElement("CG", mesh.ufl_cell(), 1)
V = FunctionSpace(mesh, vector_element)
Q = FunctionSpace(mesh, scalar_element)
#                          CONDICIONES DE CONTORNO
class InletVelocity():
    def __init__(self, t):
        self.t = t
        self.tol = 1e-4
        self.alpha_atm = 0.3
    def __call__(self, x):
        values = np.zeros((gdim, x.shape[1]),dtype=PETSc.ScalarType)
        values[0] = 4 * 1.5 * sin(self.t * np.pi/8) * x[1] * (H - x[1])/H**2
        # values[0] = 4.0 * ((x[1] + self.tol) / H)**self.alpha_atm
        return values
# # # Condiciones de contorno de la velocidad
# Inlet
u_inlet = Function(V)
inlet_velocity = InletVelocity(t)
u_inlet.interpolate(inlet_velocity)
bcu_inflow = dirichletbc(u_inlet, locate_dofs_topological(V, fdim, ft.find(inlet_marker)))
# Walls
u_nonslip = np.array((0,) * mesh.geometry.dim, dtype=PETSc.ScalarType)
bcu_walls = dirichletbc(u_nonslip, locate_dofs_topological(V, fdim, ft.find(wall_marker)), V)
# Obstacle
bcu_obstacle = dirichletbc(u_nonslip, locate_dofs_topological(V, fdim, ft.find(obstacle_marker)), V)
bcu = [bcu_inflow, bcu_obstacle, bcu_walls]
# # # Condiciones de contorno de la presión
# Outlet
bcp_outlet = dirichletbc(PETSc.ScalarType(0.0), locate_dofs_topological(Q, fdim, ft.find(outlet_marker)), Q)
bcp = [bcp_outlet]
#                 DEFINICIÓN DE FUNCIONES Y PARÁMETROS
def Sij(w):
        # Strain-rate tensor
    return sym(nabla_grad(w))
def nu_T(w):
        Viscosidad turbulenta
    return resolution**2 * Cs**2 * sqrt(2.0 * inner(Sij(w), Sij(w)))
#                        FORMULACIÓN VARIACIONAL
# Funciones para la velocidad
u_tent = TrialFunction(V)
u_ = Function(V)  # u_tent disponible como función
u_.name = "u"
u_n = Function(V)  # Función para almacenar el timestep anterior
# Funciones para la presión
p = TrialFunction(Q)
q = TestFunction(Q)
p_ = Function(Q)  # p disponible como función
# # # PASO 1: VELOCIDAD APROXIMADA (NO INCOMPRESIBLE)
F1 = dot(u_tent - u_n, v) * dx + \
    dt * inner(dot(u_n, nabla_grad(u_n)), v) * dx + \
    dt * (nu + nu_T(u_n)) * inner(grad(u_tent), grad(v)) * dx #+ \
    # dt * inner(Sij(u_tent), Sij(u_tent)) * inner(grad(u_tent), grad(v))
    # 2.0 * dt * nu_T(u_n) * inner(Sij(u_tent), Sij(v)) * dx
a1 = form(lhs(F1))
L1 = form(rhs(F1))
A1 = create_matrix(a1)
b1 = create_vector(L1)
# # # PASO 2: CÁLCULO DE LA PRESIÓN
a2 = form(dot(grad(p), grad(q)) * dx)
L2 = form(-rho/dt * dot(div(u_), q) * dx)
A2.assemble()
b2 = create_vector(L2)
# PASO 3: INCOMPRESIBILIDAD DE LA VELOCIDAD
a3 = form(dot(u_tent, v) * dx)
L3 = form(dot(u_, v) * dx - dt/rho * dot(grad(p_), v) * dx)
A3 = assemble_matrix(a3)
A3.assemble()
b3 = create_vector(L3)
#                                   SOLVERS
# Solver for step 1
solver1 = PETSc.KSP().create(mesh.comm)
solver1.setOperators(A1)
pc1 = solver1.getPC()
pc1.setType(PETSc.PC.Type.JACOBI)
# Solver for step 2
solver2 = PETSc.KSP().create(mesh.comm)
solver2.setOperators(A2)
solver2.setType(PETSc.KSP.Type.MINRES)
pc2 = solver2.getPC()
pc2.setHYPREType("boomeramg")
# Solver for step 3
solver3 = PETSc.KSP().create(mesh.comm)
solver3.setOperators(A3)
pc3 = solver3.getPC()
# # # Archivos de salida
vtx_u = VTXWriter(mesh.comm, "./outputs/u-les.bp", [u_])
vtx_p = VTXWriter(mesh.comm, "./outputs/p-lens.bp", [p_])
vtx_u.write(t)
vtx_p.write(t)
progress = tqdm.tqdm(desc="Solving PDE", total=num_steps)
for i in range(num_steps):
    progress.update(1)
    inlet_velocity.t = t
    # PASO 1
    A1.zeroEntries()
    assemble_matrix(A1, a1, bcs=bcu)
    A1.assemble()
    with b1.localForm() as loc:
        loc.set(0)
    assemble_vector(b1, L1)
    set_bc(b1, bcu)
    solver1.solve(b1, u_.vector)
    u_.x.scatter_forward()
    # PASO 2
    with b2.localForm() as loc:
        loc.set(0)
    assemble_vector(b2, L2)
    set_bc(b2, bcp)
    solver2.solve(b2, p_.vector)
    p_.x.scatter_forward()
    # PASO 3
    with b3.localForm() as loc:
        loc.set(0)
    assemble_vector(b3, L3)
    solver3.solve(b3, u_n.vector)
    u_n.x.scatter_forward()
    # # # ESCRIBIR EN ARCHIVO
    vtx_u.write(t)
    vtx_p.write(t)
vtx_u.close()
vtx_p.close()
  • Results: in the left window is the solution obtained with direct numerical simulation (aka Dokken’s wonderful tutorial) and in the right one is the output of my slow ass simulation.
I just figured it out and it is kind of blowing my mind. It seems that adding a dolfinx Constant with a regular python float is extremely slow. Since I defined dt as a Constant, the operation
at each iteration consumes a lot of time. Changing dt = Constant(...) for k = Constant(...) (and obviously every line where it appears) solves the issue.
Well you’ve found the issue. Symbolic algebra is not intended for the operation you’re attempting. Consider t += dt.value which will update t with the current value wrapped by the symbolic Constant.
Dear @NoelGK :
I have a small question in your formula.
In my understanding of LES subgrid stress 𝜏_𝑖𝑗 is written as:
𝜏_𝑖𝑗 =2𝜈_𝑡 * 𝑆_𝑖𝑗 +1/3 𝛿_𝑖𝑗 * 𝜏_𝑘𝑘
In your formula, I can only see the first term 2𝜈_𝑡 * 𝑆_𝑖𝑗. Could you tell me why the second term 1/3 𝛿_𝑖𝑗 * 𝜏_𝑘𝑘 is neglected here?
Best regards
Dear @RunzeZHANG ,
The answer is simple: since the pressure termp p is (implicitly) multiplied by \delta_{ij}, it has been modified to p^\star = p + \tau_{kk} / 3. That way, the trace of the SGS tensor \tau does not need to be calculated.
Dear @NoelGK
Thanks for your reply. Do you mean what we got for the result of the pressure field p in the steady state will become the new pressure field p^\star = p + \tau_{kk} / 3 in the turbulent condition?
And then, can we use this new p^\star to go on calculate the lift or drag?
Best regards
Dear @RunzeZHANG ,
Not exactly, excuse my lack of clarity. I just meant that, to solve for velocity, we do not calculate the pressure, but a new quantity defined as p^\star, that appears as a result of the manipulations of the equation. Thus, it can’t be interpreted as the pressure neither can it be used to calculate drag nor lift. To do so, you shoud first calculate the components of \tau_{ij} and then its trace \tau_{kk}, to be able to calculate pressure (actually I don’t know if there is an easier way to acces the pressure value, but this is solid with the physics of the LES approximation).
Dear @NoelGK:
Thanks. I understand now what you explained for the difference of value p and p^*.
But I still have one confusion, as the \tau_{ij} is in fact related to its trace \tau_{kk}:
\tau_{ij} = 2 \nu_{ij} * S_{ij} +1/3 \delta_{ij}* \tau_{kk}
How can we apply the procedure you proposed:
first calculate the components of \tau_{ij} and then its trace \tau_{kk}?
Best ragards
