Dear all,
I´m trying to solve the following nonlineal problem:
dxi/dt = -L*(g'(xi) -kappa * Laplacian(xi))
- L*h'(xi)*(exp(0.5*Fa*phi/R*T)
- (c(w)/c0)*(1-h(xi))*exp(-0.5*Fa*phi/R*T))
dw/dt = (1/chi(xi,w))*[ div * [ (D(xi,w)/R*T)*(grad(w) + Fa*grad(phi)) ]
- (dxi/dt)*ft(w) ]
div*(Le1(xi)*grad(phi)) = Fa*Csm*dxi/dt
Where xi, w and phi are the variables to find.
The functions are defined in the code:
from dolfin import MPI
from datetime import datetime
# Domain dimensions
lox= 200
loy= 200
#co = 0.068 # mol/m^3
# Constants (no usadas, referencia)
Fa = 96485.3365 # C/mol
R = 8.314472 # J/(molxK)
T = 293.0 # K
R = Constant(R)
T = Constant(T)
Fa = Constant(Fa)
#Dimensional Parameters normalizados
#Define expressions used in variational form
L = Constant(6.25)
kappa = Constant(0.3) # =R*T
Ls = Constant(0.001)
alpha = Constant(0.5)
AA = Constant(38.69) # nF/RT
W = Constant(2.4)
es = Constant(-13.8)
el = Constant(2.631) # mu0 = -R*T*ln(c0),, el = ln(cl)
A = Constant(1.0) # =R*T/R*T
c0 = Constant(1.0/14.89)
dv = Constant(5.5) # Csm/Clm
M0 = Constant(317.9)
S1 = Constant(1000000)
S2 = Constant(1.19)
ft2 = Constant(0.0074)
#Mesh
nx, ny = 2000, 2000
mesh = RectangleMesh(Point(0, 0), Point(lox, loy), nx, ny)
P1 = FiniteElement('P', triangle, 2)
V = FunctionSpace(mesh, MixedElement([P1,P1,P1]))
#Define trial and test functions
v_1, v_2, v_3 = TestFunctions(V)
# Define functions for solutions at previous and at current time
u = Function(V) # At current time
u_n = Function(V)
#Split system function to access the components
xi, w, phi = split(u)
xi_n, w_n, phi_n = split(u_n)
#Parameter for initial conditions
phie= -0.45
ruido=Expression('-0.04*sin(0.1*x[1])', degree= 2)
#Create initial conditions
u_init=Expression(('0.5*(1.0-1.0*tanh((x[0]-20.0-ruido)*2))','0.0','-0.225*(1.0-tanh((x[0]-20.0-ruido)*2))'), degree= 2, ruido=ruido)
u_n = project(u_init,V)
# Define boundary condition
def boundary0(x, on_boundary):
def boundaryL(x, on_boundary):
return on_boundary and near(x[0], lox)
bc_xi1 = DirichletBC(V.sub(0), Constant(1.0), boundary0)
bc_xi2 = DirichletBC(V.sub(0), Constant(0.0), boundaryL)
bc_c2 = DirichletBC(V.sub(1), Constant(0.0), boundaryL)
bc_phi1 = DirichletBC(V.sub(2), Constant(phie), boundary0)
bc_phi2 = DirichletBC(V.sub(2), Constant(0.0), boundaryL)
bcs = [bc_xi1, bc_xi2, bc_c2, bc_phi1, bc_phi2 ] # Condiciones dirichlet
# SwitchingFunctionMaterial
def h(_x):
return _x
def dh(_x):
return 1
# BarrierFunctionMaterial
def g(_x):
return W*_x**2.0*(Constant(1.0) - _x)**2
def dg(_x):
return W*Constant(2.0)*(_x * (Constant(1.0) - _x) ** 2 - (Constant(1.0) - _x) * _x ** 2)
# Concentrarion
def cl(_x):
return exp((_x-el)/A)/(Constant(1.0)+exp((_x-el)/A))
def dcldw(_x):
return exp((_x+el)/A)/(A*(exp(_x/A)+exp(el/A))**2)
def cs(_x):
return exp((_x-es)/A)/(Constant(1.0)+exp((_x-es)/A))
def dcsdw(_x):
return exp((_x+es)/A)/(A*(exp(_x/A)+exp(es/A))**2)
def chi(_xi,_w):
return dcldw(_w)*(Constant(1.0)-h(_xi))+dcsdw(_w)*h(_xi)*dv
# Mobility defined by D*c/(R*T), whereR*T is normalized by the chemical potential
# M0*(1-h) is the effective diffusion coefficient; cl*(1-h) is the ion concentration
def D(_xi,_w):
return M0*(Constant(1.0)-h(_xi))*cl(_w)*(Constant(1.0)-h(_xi))
def ft(_w):
return cs(_w)*dv-cl(_w)
# Effective conductivity, DerivativeParsedMaterial
def Le1(_xi):
return S1*h(_xi)+S2*(Constant(1.0)-h(_xi))
#Numerical Parameters
Tf= 108.0
dt= 0.02
num_steps=int(Tf/dt)
k = Constant(dt)
#Define variational (dimensional) problem
F1 = (xi-xi_n)/k*v_1*dx + L*kappa*dot(grad(xi),grad(v_1))*dx + L*dg(xi)*v_1*dx + Ls*(exp(phi*AA/Constant(2.0))-Constant(14.89)*cl(w)*(Constant(1.0)-h(xi))*exp(-phi*AA/Constant(2.0)))*dh(xi)*v_1*dx
F2 = chi(xi,w)*(w-w_n)/k*v_2*dx + D(xi, w)*dot(grad(w),grad(v_2))*dx + D(xi, w)*AA*dot(grad(phi),grad(v_2))*dx + (h(xi)-h(xi_n))/k*ft(w)*v_2*dx
F3 = Le1(xi)*dot(grad(phi),grad(v_3))*dx + ft2*(xi-xi_n)/k*v_3*dx
F=F1+F2+F3
#Jacobian
J = derivative(F,u)
t=0.0
for n in range(num_steps):
t+=dt
#print('mpi rank', mpi_rank, 'time', t)
solve(F == 0, u, bcs, J=J, solver_parameters={"newton_solver":{"absolute_tolerance":1.0e-6, "relative_tolerance":1.0e-6, "maximum_iterations":100}})
u_n.assign(u)
the message error is the following:
File “/usr/lib/python3/dist-packages/dolfin/fem/solving.py”, line 266, in _solve_varproblem
solver.solve()
RuntimeError:
*** Error: Unable to solve nonlinear system with NewtonSolver.
*** Reason: Newton solver did not converge because maximum number of iterations reached.
*** Where: This error was encountered inside NewtonSolver.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: unknown
I have tried to increase the mesh but it doesn´t work
Anyone who can help me?
Thanks
