Dear Fenics community,
My goal is to simulate kirigami/origami-like unfolding of structures. This is in principle a small deformation, large displacement problem. I’ve tried a few examples from the solid mechanics examples of Fenics and landed on Hyperelasticity.
I am encountering issues when trying to deform my structures: the newton solver diverges.
I provide below a fully working (until the divergence) minimal example (I run it in jupyter notebook):
Simple shape generation:
#mesh = UnitSquareMesh(32, 32)
#!dolfin-convert meshbase.msh meshbase.xml
#mesh = Mesh('meshbase.xml');
import math
radius=1
n_pts=20
angles=np.linspace(0,2*np.pi,n_pts)
x=radius*np.cos(angles)
y=radius*np.sin(angles)
polygon=[]
for n in range(n_pts):
polygon.append(Point(x[n],y[n]))
#the outside_circle
Big_circle=Polygon(polygon)
#making the inset holes
ri=0.1
ro=0.8
off_center=0.05
angles_small=np.linspace(0,np.pi/2.,5)
angles_large=np.linspace(0,np.pi/2.,20)
x=ri*np.cos(angles_small)
x=np.hstack((x,np.ones(10)*x[-1]))
x=np.hstack((x,ro*np.cos(angles_large[::-1])))
x=np.hstack((x,np.linspace(ro,ri,10)))+off_center
y=ri*np.sin(angles_small)
y=np.hstack((y,np.linspace(ri,ro,10)))
y=np.hstack((y,ro*np.sin(angles_large[::-1])))
y=np.hstack((y,np.ones(10)*y[-1]))+off_center
holes=[]
for flip_x in [-1,1]:
for flip_y in [-1,1]:
hole=[]
for n in range(len(x)):
hole.append(Point(flip_x*x[n],flip_y*y[n]))
try:
inset_hole=Polygon(hole[::-1])
except:
inset_hole=Polygon(hole)
Big_circle=Big_circle-inset_hole
to3d=Extrude2D(Big_circle,0.01)
mesh=generate_mesh(to3d,1)
By this point, I have a circular shape with 4 large holes inside. I want the outside rim to be fixed, and only the inside structure to unfold vertically under weight (pay attention to the z-scale : it is thin!)
So I proceed with the model, adapted from the fenics page on neo-hookean solids:
"eliminate_zeros": True, \
"precompute_ip_const": True}
# Mark boundary subdomians
def round_boundary(x, on_boundary):
r = math.sqrt((x[0]*x[0]+x[1]*x[1]))
return r > 0.9
bcs = [DirichletBC(V, Constant((0.0, 0.0, 0.0)), round_boundary)]
# Define functions
du = TrialFunction(V) # Incremental displacement
v = TestFunction(V) # Test function
u = Function(V) # Displacement from previous iteration
B = Constant((0.0, -0.5, 0.0)) # Body force per unit volume
#T = Constant((0.1, 0.0, 0.0)) # Traction force on the boundary
# Kinematics
d = u.geometric_dimension()
I = Identity(d) # Identity tensor
Ic = tr(C)
J = det(F)
# Elasticity parameters
E, nu = 1e5, 0.3
mu, lmbda = Constant(E/(2*(1 + nu))), Constant(E*nu/((1 + nu)*(1 - 2*nu)))
psi = (mu/2)*(Ic - 3) - mu*ln(J) + (lmbda/2)*(ln(J))**2
# Total potential energy
Pi = psi*dx - dot(B, u)*dx #- dot(T, u)*ds
# Compute first variation of Pi (directional derivative about u in the direction of v)
F = derivative(Pi, u, v)
# Compute Jacobian of F
J = derivative(F, u, du)
I took out the traction force, and I defined the boundary condition such that the rim is fixed.
Finally, I call the solver:
problem = NonlinearVariationalProblem(F, u, bcs, J,form_compiler_parameters=ffc_options)
solver.solve()
Looking at my console:
Newton iteration 0: r (abs) = 2.021e-05 (tol = 1.000e-10) r (rel) = 1.000e+00 (tol = 1.000e-09)
Newton iteration 1: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-09)
I have tried to change the body force, the elasticity, etc. I simply run out of ideas. Any help is appreciated. Thanks !
