No graph partitioner found - error
When I want to install dolfinx from source, I do:
PETSC_ARCH=linux-gnu-complex-32 cmake -G Ninja -DCMAKE_INSTALL_PREFIX=$CMAKE_INSTA
LL_PREFIX/dolfinx-complex -DCMAKE_BUILD_TYPE=${DOLFINX_CMAKE_BUILD_TYPE} -DCMAKE_CXX_FLAGS=${DOLFINX_CMAKE
_CXX_FLAGS} ../cpp
However I get:
-- The C compiler identification is GNU 12.2.1
-- The CXX compiler identification is GNU 12.2.1
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/gcc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/g++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Found MPI_C: /home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/installation/openmpi/lib/libmpi.so
 (found suitable version "3.1", minimum required is "3")
-- Found MPI_CXX: /home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/installation/openmpi/lib/libmpi.
so (found suitable version "3.1", minimum required is "3")
-- Found MPI: TRUE (found suitable version "3.1", minimum required is "3")
-- Performing Test HAVE_PIPE
-- Performing Test HAVE_PIPE - Success
-- Performing Test HAVE_PEDANTIC
-- Performing Test HAVE_PEDANTIC - Success
-- Performing Test HAVE_DEBUG
-- Performing Test HAVE_DEBUG - Success
-- Performing Test HAVE_O2_OPTIMISATION
-- Performing Test HAVE_O2_OPTIMISATION - Success
-- Found Boost 1.81.0 at /usr/lib/cmake/Boost-1.81.0
--   Requested configuration: QUIET REQUIRED COMPONENTS timer
-- Found boost_headers 1.81.0 at /usr/lib/cmake/boost_headers-1.81.0
-- Found boost_timer 1.81.0 at /usr/lib/cmake/boost_timer-1.81.0
--   [x] libboost_timer.so.1.81.0
--   [ ] libboost_timer.a
-- Adding boost_timer dependencies: chrono;headers
-- Found boost_chrono 1.81.0 at /usr/lib/cmake/boost_chrono-1.81.0
--   [x] libboost_chrono.so.1.81.0
--   [ ] libboost_chrono.a
-- Adding boost_chrono dependencies: headers
-- Found Boost: /usr/lib/cmake/Boost-1.81.0/BoostConfig.cmake (found suitable version "1.81.0", minimum re
quired is "1.70") found components: timer
-- Found Python3: /home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/bin/python3.10 (found version "3
.10.10") found components: Interpreter
-- Adding /home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/lib/python3.10/site-packages/basix to Ba
six search hints
-- Found PkgConfig: /usr/bin/pkg-config (found version "1.8.1")
-- Checking for one of the modules 'PETSc>=3.15;petsc>=3.15'
-- Looking for PETSC_USE_COMPLEX
-- Looking for PETSC_USE_COMPLEX - found
-- Found PETSc version 3.17.2, prefix: /home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/installatio
n/petsc/linux-gnu-complex-32
-- HDF5: Using hdf5 compiler wrapper to determine C configuration
-- Found HDF5: /home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/installation/hdf5/lib/libhdf5.so;/u
sr/lib/libz.so;/usr/lib/libdl.a;/usr/lib/libm.so (found version "1.12.2") found components: C
-- HDF5_DIR: HDF5_DIR-NOTFOUND
-- HDF5_DEFINITIONS:
-- HDF5_INCLUDE_DIRS: /home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/installation/hdf5/include
-- HDF5_LIBRARIES: /home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/installation/hdf5/lib/libhdf5.s
o;/usr/lib/libz.so;/usr/lib/libdl.a;/usr/lib/libm.so
-- HDF5_HL_LIBRARIES:
-- HDF5_C_DEFINITIONS:
-- HDF5_C_INCLUDE_DIR:
-- HDF5_C_INCLUDE_DIRS: /home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/installation/hdf5/include
-- HDF5_C_LIBRARY:
-- HDF5_C_LIBRARIES: /home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/installation/hdf5/lib/libhdf5
.so;/usr/lib/libz.so;/usr/lib/libdl.a;/usr/lib/libm.so
-- HDF5_C_HL_LIBRARY:
-- HDF5_C_HL_LIBRARIES:
-- Defined targets (if any):
-- ... hdf5::hdf5
-- Asking Python module FFCx for location of UFC... (Python executable: /home/ufuk/venvs/fenicsx-src-test/
fenicsx-src-test-venv/bin/python3.10)
-- Found UFCx: /home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/lib/python3.10/site-packages/ffcx/c
odegeneration (found suitable version "0.6.0", minimum required is "0.6")
 (found version "3.1")
so (found version "3.1")
-- Found MPI: TRUE (found version "3.1")
-- Found ADIOS2: /home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/installation/adios2/lib/cmake/adi
os2/adios2-config.cmake (found suitable version "2.8.2", minimum required is "2.8.1") found components: C
CXX MPI
-- Checking for one of the modules 'slepc>=3.15'
-- Found SLEPc version 3.17.1, prefix: /home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/installatio
n/slepc/linux-gnu-complex-32
-- Checking for package 'SCOTCH-PT'
-- Found SCOTCH (version 6.1.2)
-- Performing test SCOTCH_TEST_RUNS
-- Performing test SCOTCH_TEST_RUNS - Failed
-- Found ZLIB: /usr/lib/libz.so (found version "1.2.13")
-- Performing test SCOTCH_ZLIB_TEST_RUNS
-- Performing test SCOTCH_ZLIB_TEST_RUNS - Failed
-- SCOTCH could not be found. Be sure to set SCOTCH_ROOT. (missing: SCOTCH_TEST_RUNS)
-- ParMETIS could not be found/configured. (missing: PARMETIS_TEST_RUNS PARMETIS_INCLUDE_DIRS PARMETIS_VER
SION PARMETIS_VERSION_OK) (Required is at least version "4.0.2")
CMake Error at CMakeLists.txt:356 (message):
  No graph partitioner found.  SCOTCH, ParMETIS or KaHIP is required.
-- Configuring incomplete, errors occurred!
OS: Archlinux
Linux kernel version: 6.2.12-arch1-1
Python3 version: 3.10.10
I would appreciate if you could give any suggestions.
Best,
Ufuk
To me it seems like something is up with your scotch installation (it usually comes installed with petsc).
It seems like it is failing somewhere inside
You could add the following flag if you believe it is set up correctly even if the test is failing: https://github.com/FEniCS/dolfinx/blob/64592ab73344b41fb1dbf3b34d14ff0b97d6a75a/cpp/CMakeLists.txt#L58
Thanks a lot for the solution. It works by skipping the tests in your suggested code.
Yet,
CXXFLAGS=${DOLFINX_CMAKE_CXX_FLAGS} PETSC_ARCH=linux-gnu-complex-32 pip3 install -
v --target $VENV_DIR/lib/python3.10/dist-packages --no-dependencies --no-cache-dir .
gives
Using pip 23.1.2 from /home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/lib/python3.10/site-packages
/pip (python 3.10)
Processing /home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/repos/src/dolfinx/python
  Running command python setup.py egg_info
  running egg_info
  creating /tmp/pip-pip-egg-info-s7a6_h5k/fenics_dolfinx.egg-info
  writing /tmp/pip-pip-egg-info-s7a6_h5k/fenics_dolfinx.egg-info/PKG-INFO
  writing dependency_links to /tmp/pip-pip-egg-info-s7a6_h5k/fenics_dolfinx.egg-info/dependency_links.txt
  writing requirements to /tmp/pip-pip-egg-info-s7a6_h5k/fenics_dolfinx.egg-info/requires.txt
  writing top-level names to /tmp/pip-pip-egg-info-s7a6_h5k/fenics_dolfinx.egg-info/top_level.txt
  writing manifest file '/tmp/pip-pip-egg-info-s7a6_h5k/fenics_dolfinx.egg-info/SOURCES.txt'
  reading manifest file '/tmp/pip-pip-egg-info-s7a6_h5k/fenics_dolfinx.egg-info/SOURCES.txt'
  Preparing metadata (setup.py) ... done
Building wheels for collected packages: fenics-dolfinx
  Running command python setup.py bdist_wheel
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build/lib.linux-x86_64-3.10
  creating build/lib.linux-x86_64-3.10/dolfinx
  copying dolfinx/plot.py -> build/lib.linux-x86_64-3.10/dolfinx
  copying dolfinx/la.py -> build/lib.linux-x86_64-3.10/dolfinx
  copying dolfinx/mesh.py -> build/lib.linux-x86_64-3.10/dolfinx
  copying dolfinx/geometry.py -> build/lib.linux-x86_64-3.10/dolfinx
  copying dolfinx/graph.py -> build/lib.linux-x86_64-3.10/dolfinx
  copying dolfinx/log.py -> build/lib.linux-x86_64-3.10/dolfinx
  copying dolfinx/__init__.py -> build/lib.linux-x86_64-3.10/dolfinx
  copying dolfinx/common.py -> build/lib.linux-x86_64-3.10/dolfinx
  copying dolfinx/jit.py -> build/lib.linux-x86_64-3.10/dolfinx
copying dolfinx/pkgconfig.py -> build/lib.linux-x86_64-3.10/dolfinx
  creating build/lib.linux-x86_64-3.10/dolfinx/fem
  copying dolfinx/fem/function.py -> build/lib.linux-x86_64-3.10/dolfinx/fem
  copying dolfinx/fem/forms.py -> build/lib.linux-x86_64-3.10/dolfinx/fem
  copying dolfinx/fem/dofmap.py -> build/lib.linux-x86_64-3.10/dolfinx/fem
  copying dolfinx/fem/__init__.py -> build/lib.linux-x86_64-3.10/dolfinx/fem
  copying dolfinx/fem/assemble.py -> build/lib.linux-x86_64-3.10/dolfinx/fem
  copying dolfinx/fem/petsc.py -> build/lib.linux-x86_64-3.10/dolfinx/fem
  copying dolfinx/fem/bcs.py -> build/lib.linux-x86_64-3.10/dolfinx/fem
  creating build/lib.linux-x86_64-3.10/dolfinx/io
  copying dolfinx/io/gmshio.py -> build/lib.linux-x86_64-3.10/dolfinx/io
  copying dolfinx/io/utils.py -> build/lib.linux-x86_64-3.10/dolfinx/io
  copying dolfinx/io/__init__.py -> build/lib.linux-x86_64-3.10/dolfinx/io
  creating build/lib.linux-x86_64-3.10/dolfinx/nls
  copying dolfinx/nls/__init__.py -> build/lib.linux-x86_64-3.10/dolfinx/nls
  copying dolfinx/nls/petsc.py -> build/lib.linux-x86_64-3.10/dolfinx/nls
  creating build/lib.linux-x86_64-3.10/dolfinx/wrappers
  copying dolfinx/wrappers/__init__.py -> build/lib.linux-x86_64-3.10/dolfinx/wrappers
  copying dolfinx/py.typed -> build/lib.linux-x86_64-3.10/dolfinx
  copying dolfinx/fem/py.typed -> build/lib.linux-x86_64-3.10/dolfinx/fem
  copying dolfinx/nls/py.typed -> build/lib.linux-x86_64-3.10/dolfinx/nls
  copying dolfinx/wrappers/caster_petsc.h -> build/lib.linux-x86_64-3.10/dolfinx/wrappers
  copying dolfinx/wrappers/caster_mpi.h -> build/lib.linux-x86_64-3.10/dolfinx/wrappers
  copying dolfinx/wrappers/array.h -> build/lib.linux-x86_64-3.10/dolfinx/wrappers
  copying dolfinx/wrappers/MPICommWrapper.h -> build/lib.linux-x86_64-3.10/dolfinx/wrappers
  running build_ext
  -- Found MPI_C: /usr/lib/libmpi.so (found suitable version "3.1", minimum required is "3")
  -- Found MPI_CXX: /usr/lib/libmpi_cxx.so (found suitable version "3.1", minimum required is "3")
Basix search hints
ion/petsc/linux-gnu-complex-32
e
  -- HDF5_C_LIBRARY:
f5.so;/usr/lib/libz.so;/usr/lib/libdl.a;/usr/lib/libm.so
  -- ... hdf5::hdf5
t/fenicsx-src-test-venv/bin/python)
  -- Found MPI_C: /usr/lib/libmpi.so (found version "3.1")
  -- Found MPI_CXX: /usr/lib/libmpi_cxx.so (found version "3.1")
ion/slepc/linux-gnu-complex-32
  -- Found SCOTCH (version 6)
  -- ParMETIS could not be found/configured. (missing: PARMETIS_INCLUDE_DIRS) (Required is at least versio
n "4.0.2")
  -- The following features have been enabled:
   * BUILD_SHARED_LIBS, Build DOLFINx with shared libraries.
   * DOLFINX_SKIP_BUILD_TESTS, Skip build tests for testing usability of dependency packages.
   * CMAKE_INSTALL_RPATH_USE_LINK_PATH, Add paths to linker search and installed rpath.
   * DOLFINX_UFCX_PYTHON, Enable UFCx discovery using Python. Disable if UFCx should be found using a CMak
e config file.
  -- The following OPTIONAL packages have been found:
   * ADIOS2 (required version >= 2.8.1), Adaptable Input/Output (I/O) System., <https://adios2.readthedocs
.io/en/latest/>
     IO, including in parallel
   * SCOTCH, Programs and libraries for graph, mesh and hypergraph partitioning, <https://www.labri.fr/per
so/pelegrin/scotch>
     Parallel graph partitioning
  -- The following RECOMMENDED packages have been found:
   * SLEPc, Scalable Library for Eigenvalue Problem Computations, <http://slepc.upv.es/>
     Eigenvalue computation
  -- The following REQUIRED packages have been found:
   * pugixml
   * boost_chrono (required version == 1.81.0)
   * boost_headers (required version == 1.81.0)
   * boost_timer (required version == 1.81.0)
   * Boost (required version >= 1.70), Boost C++ libraries, <http://www.boost.org>
   * Basix (required version >= 0.6)
   * PETSc, Portable, Extensible Toolkit for Scientific Computation (PETSc), <https://www.mcs.anl.gov/pets
c/>
     PETSc linear algebra backend
   * HDF5, Hierarchical Data Format 5 (HDF5), <https://www.hdfgroup.org/HDF5>
   * Python3
   * UFCx (required version >= 0.6), Interface for form-compilers (part of FFCx), <https://github.com/feni
cs/ffcx>
   * MPI
   * PkgConfig
  -- The following RECOMMENDED packages have not been found:
   * ParMETIS (required version >= 4.0.2), Parallel Graph Partitioning and Fill-reducing Matrix Ordering,
<http://glaros.dtc.umn.edu/gkhome/metis/parmetis/overview>
  -- Configuring done (3.4s)
  -- Generating done (0.0s)
  -- Build files have been written to: /home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/repos/src/d
olfinx/python
  Error: could not load cache
    File "<string>", line 2, in <module>
    File "<pip-setuptools-caller>", line 34, in <module>
    File "/home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/repos/src/dolfinx/python/setup.py", line
 69, in <module>
      setup(name='fenics-dolfinx',
    File "/home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/lib/python3.10/site-packages/setuptools/
__init__.py", line 153, in setup
      return distutils.core.setup(**attrs)
    File "/usr/lib/python3.10/distutils/core.py", line 148, in setup
      dist.run_commands()
    File "/usr/lib/python3.10/distutils/dist.py", line 966, in run_commands
      self.run_command(cmd)
    File "/usr/lib/python3.10/distutils/dist.py", line 985, in run_command
      cmd_obj.run()
    File "/home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/lib/python3.10/site-packages/wheel/bdist
_wheel.py", line 343, in run
      self.run_command("build")
    File "/usr/lib/python3.10/distutils/cmd.py", line 313, in run_command
      self.distribution.run_command(command)
      cmd_obj.run()
    File "/usr/lib/python3.10/distutils/command/build.py", line 135, in run
      self.run_command(cmd_name)
      cmd_obj.run()
 41, in run
      self.build_extension(ext)
 66, in build_extension
      subprocess.check_call(['cmake', '--build', '.'] + build_args, cwd=self.build_temp, env=env)
    File "/usr/lib/python3.10/subprocess.py", line 369, in check_call
      raise CalledProcessError(retcode, cmd)
  subprocess.CalledProcessError: Command '['cmake', '--build', '.', '--config', 'Release']' returned non-z
ero exit status 1.
  error: subprocess-exited-with-error
  × python setup.py bdist_wheel did not run successfully.
  │ exit code: 1
  ╰─> See above for output.
  note: This error originates from a subprocess, and is likely not a problem with pip.
  full command: /home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/bin/python -u -c '
  exec(compile('"'"''"'"''"'"'
  # This is <pip-setuptools-caller> -- a caller that pip uses to run setup.py
  # - It imports setuptools before invoking setup.py, to enable projects that directly
  #   import from `distutils.core` to work with newer packaging standards.
  # - It provides a clear error message when setuptools is not installed.
  # - It sets `sys.argv[0]` to the underlying `setup.py`, when invoking `setup.py` so
  #   setuptools doesn'"'"'t think the script is `-c`. This avoids the following warning:
  #     manifest_maker: standard file '"'"'-c'"'"' not found".
  # - It generates a shim setup.py, for handling setup.cfg-only projects.
  import os, sys, tokenize
  try:
      import setuptools
  except ImportError as error:
      print(
          "ERROR: Can not execute `setup.py` since setuptools is not available in "
          "the build environment.",
          file=sys.stderr,
      sys.exit(1)
  __file__ = %r
  sys.argv[0] = __file__
  if os.path.exists(__file__):
      filename = __file__
      with tokenize.open(__file__) as f:
          setup_py_code = f.read()
      filename = "<auto-generated setuptools caller>"
      setup_py_code = "from setuptools import setup; setup()"
  exec(compile(setup_py_code, filename, "exec"))
  '"'"''"'"''"'"' % ('"'"'/home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/repos/src/dolfinx/python
/setup.py'"'"',), "<pip-setuptools-caller>", "exec"))' bdist_wheel -d /tmp/pip-wheel-mza6wvdr
  cwd: /home/ufuk/venvs/fenicsx-src-test/fenicsx-src-test-venv/repos/src/dolfinx/python/
  Building wheel for fenics-dolfinx (setup.py) ... error
  ERROR: Failed building wheel for fenics-dolfinx
  Running setup.py clean for fenics-dolfinx
  Running command python setup.py clean
  running clean
  removing 'build/temp.linux-x86_64-3.10' (and everything under it)
  removing 'build/lib.linux-x86_64-3.10' (and everything under it)
  'build/bdist.linux-x86_64' does not exist -- can't clean it
  'build/scripts-3.10' does not exist -- can't clean it
  removing 'build'
Failed to build fenics-dolfinx
ERROR: Could not build wheels for fenics-dolfinx, which is required to install pyproject.toml-based projec
ts
I would be happy if you could suggest a solution.
Best,
Ufuk
Ive never encountered this error, and a quick Google search does not give a clear culprit.
My best guess would be to clear the build cache (in the build folder, dolfinx/python/build).
You could have a look at
https://aur.archlinux.org/cgit/aur.git/tree/PKGBUILD?h=dolfinx
and
https://aur.archlinux.org/cgit/aur.git/tree/PKGBUILD?h=python-fenics-dolfinx
