Nonlinear PDE PETSc Error 63
Good evening,
I am trying to solve a very simple 1D non linear PDE with constant Dirichlet boundary conditions (I’m a true beginner at FeniCS). After the first iteration, I always get the same error code:
Error: Unable to successfully call PETSc function ‘MatSetValuesLocal’.
*** Reason: PETSc error code is: 63 (Argument out of range).
*** Where: This error was encountered inside /usr/local/miniconda/conda-bld/fenics-pkgs_1565954444213/work/dolfin/dolfin/la/PETScMatrix.cpp.
Solutions I’ve looked around the Internet involve split functions but I can’t really understand if those apply to my problem; by the way, I’ve installed FeniCS thanks to conda-forge. Anyway here is the code:
maillage = UnitIntervalMesh(50)
H_P1 = FunctionSpace(maillage, 'P', 1)
I = Function(H_P1)
phi = TestFunction(H_P1)
F =  (d/25) * div(grad(I)) * phi * dx + (beta/alpha) * phi * (I - (I**2)/K) * dx
class Dirichlet_0(SubDomain):
        return near(x[0],0,10**(-14)) and on_boundary
class Dirichlet_1(SubDomain):
        return near(x[0],1,10**(-14)) and on_boundary
condition_0 = DirichletBC(H_P1, Constant(300), Dirichlet_0())
condition_1 = DirichletBC(H_P1, Constant(0), Dirichlet_1())
I = Function(H_P1)
J = derivative(F,I)
problem = NonlinearVariationalProblem(F, I, [condition_0, condition_1], J=J)
solver  = NonlinearVariationalSolver(problem)
solver.solve()
Could you help me fix that error?
Thank you in advance
You’ve redefined I which means you don’t have a bilinear operator when you compute the derivative J. So you’re assembling an empty LHS matrix.
Also, your FE formulation doesn’t look correct, but I’m assuming you can figure that out.
First of all, thank you very much for your quick response !
You’re completely right about the derivative J, I’ve moved that just after the definition of F.
On the topic of the variational formula, my PDE is -\frac{d}{L^2} \frac{\partial^{2}I_{\infty}}{\partial^2 x^{*}} = \frac{\beta}{\alpha}I_{\infty}(1-\frac{I_{\infty}}{K}) to be solved on ]0,1[. Have I misdefined F ?
That’s the so-called strong formulation. You need to find the weak formulation by integrating by parts the term with the second order derivative, and imposing appropriate boundary conditions.
For example
strong form: -\nabla^2 u = f, u = u_D on the Dirichlet boundary \partial\Omega_D and \nabla u \cdot n = g_N on the Neumann boundary \partial\Omega_N.
multiply by test function, v and integrate: -\int_\Omega \nabla^2 u v \mathrm{d}x = \int_\Omega f v \mathrm{d} x
and integrate by parts to get weak formulation: \int_\Omega \nabla u \cdot \nabla v \mathrm{d}x - \int_{\partial\Omega_N} g_N v \mathrm{d}s = \int_\Omega f v \mathrm{d} x
Let \phi \in \mathcal{H}^1(0,1) and I \in \mathcal{C}^2(0,1) solution of the PDE.
We have \frac{d}{L^2}(\int_{]0,1[} I' \phi'dx - \int_{\delta(]0,1[)} I' \phi dS) = \frac{\beta}{\alpha}\int_{]0,1[} I(1-\frac{I}{K}) \phi dx so
F = d/(L**2) * dot(grad(I),grad(phi)) * dx - grad(I)[0] * phi * ds - (b/a) * I * (1-I/K) * phi * dx
Do you agree with that expression?
If Neumann boundary conditions were to be respected (for example I'(0) = c and I'(1) = d), how would I define ds1 and ds2 in FeniCS to make the following code work?
F = d/(L**2) * dot(grad(I),grad(phi)) * dx - d * phi * ds1 + c * phi * ds2 - (b/a) * I * (1-I/K) * phi * dx
