Normal vector computation after refine
I want to use an adaptive refinement. Dolfinx offers a refinement based on markers. After refining a 3D surface triangle mesh I found, that the vertex ordering of the refined triangles is not preserved. As consequence the sign of normal vectors depends on the ordering of the vertices and changes it sign with refinements. Below you can find a small piece of code demonstrating my observation. From my opinion the cell normals should always point into the same direction since the surface is just a part of the xy-plane.
Best,
Markus
import numba
import dolfinx as dfx
from ufl import ds, dx, grad, inner, FiniteElement, Cell, Mesh, VectorElement
import math
def extract_geometricial_data(msh, dim, entities):
    """For a set of entities in a mesh, return the coordinates of the
    vertices"""
    mesh_nodes = []
    geom = msh.geometry
    g_indices = _cpp.mesh.entities_to_geometry(msh, dim, np.array(entities, dtype=np.int32), False)
    for cell in g_indices:
        nodes = np.zeros((len(cell), 3), dtype=np.float64)
        for j, entity in enumerate(cell):
            nodes[j] = geom.x[entity]
        mesh_nodes.append(nodes)
    return mesh_nodes
@numba.njit(fastmath=True)
def mark_all(x):
    return np.ones(x.shape[1])
def get_marked_edges(dim, edges, h, hmax):
    marked_edges = []
    dist_min = 1.0e12
    dist_max = -1.0e12
    for e in edges:
        dist = h[e]
        if dist > dist_max:
            dist_max = dist
        if dist < dist_min:
            dist_min = dist
        if  dist > hmax:
            marked_edges.append(e)
    return dist_min, dist_max, np.array(marked_edges)
def mark_large_edges(msh, dim, hmax):
    """For a set of edge entities in a mesh, return the list of the
    edges largen than hmax"""
    edges = mesh.locate_entities(msh, dim-1, mark_all)
    h = _cpp.mesh.h(msh, dim-1, edges)
    return get_marked_edges(dim, edges, h, hmax)
def get_node_normals(cell_indices, cell_normals, num_nodes):
    node_normals = np.zeros((num_nodes,3))
    node_counts  = np.zeros(num_nodes)
    for cell_id, cell in enumerate(cell_indices):
        for node_id in cell:
            node_counts[node_id]  += 1
            node_normals[node_id] += cell_normals[cell_id]
    for node in range(num_nodes):
        node_normals[node] /= node_counts[node]
    return node_normals
# set up mesh
l0 = 1
points = [
    [-l0, -l0, 0.0],
    [l0, -l0, 0.0],
    [l0, l0, 0.0],
    [-l0, l0, 0.0]
triangles = [("triangle", [[0, 1, 2], [0, 2, 3]])]
mshio = meshio.Mesh(points, triangles)
shape = "triangle"
degree = 1
cell = Cell(shape)
domain = Mesh(VectorElement("Lagrange", cell, degree))
msh = mesh.create_mesh(MPI.COMM_WORLD, mshio.cells_dict['triangle'], mshio.points, domain)
cell_dim = msh.topology.dim
msh.topology.create_entities(cell_dim)
# get some properties and calculate cell normals for first mesh
cells = dfx.mesh.locate_entities(msh, cell_dim, mark_all)
edges = mesh.locate_entities(msh, cell_dim-1, mark_all)
nodes = mesh.locate_entities(msh, cell_dim-2, mark_all)
print("number of cells ", cells.size, ", number of edges ", edges.size, ", number of nodes ", nodes.size )
cell_normals = _cpp.mesh.cell_normals(msh, cell_dim, cells)
print(cell_normals)
cell_nodes = extract_geometricial_data(msh,cell_dim,cells)
facet_nodes = extract_geometricial_data(msh,cell_dim-1,edges)
# refine some times and calculate cell normals for refined meshes
hmin = 0.8
dist_min, dist_max, marked = mark_large_edges(msh,cell_dim,hmin)
while marked.size > 0:
    print("dist_min ", dist_min, ", dist_max", dist_max, ", number of edges to be refined: ", marked.size )
    if marked.size > 0:
        msh = mesh.refine(msh, marked, redistribute=False)
        num_cells = cells.size
        num_edges = edges.size
        num_nodes = nodes.size
        cell_indices = _cpp.mesh.entities_to_geometry(msh, cell_dim, np.array(cells, dtype=np.int32), False)
        node_normals = get_node_normals(cell_indices, cell_normals, num_nodes)
        print(cell_normals)
