Not understanding error
Dear sir,
I am getting errors regularly when I will use nedelec element inside the integral.
/usr/lib/python3/dist-packages/FIAT/check_format_variant.py:9: DeprecationWarning: Variant of Nedelec element will change from point evaluation to integral evaluation. You should project into variant="integral"
  warnings.warn('Variant of ' + element + ' element will change from point evaluation to integral evaluation.'
/usr/lib/python3/dist-packages/scipy/special/orthogonal.py:81: DeprecationWarning: `np.int` is a deprecated alias for the builtin `int`. To silence this warning, use `int` by itself. Doing this will not modify any behavior and is safe. When replacing `np.int`, you may wish to use e.g. `np.int64` or `np.int32` to specify the precision. If you wish to review your current use, check the release note link for additional information.
Deprecated in NumPy 1.20; for more details and guidance: https://numpy.org/devdocs/release/1.20.0-notes.html#deprecations
  from numpy import (exp, inf, pi, sqrt, floor, sin, cos, around, int,
/usr/lib/python3/dist-packages/scipy/linalg/__init__.py:217: DeprecationWarning: The module numpy.dual is deprecated.  Instead of using dual, use the functions directly from numpy or scipy.
  from numpy.dual import register_func
Solving linear variational problem.
This is not an error, but a warning (regarding scipy), Updating scipy should fix this, as it was removed in: MAINT: remove last uses of numpy.dual by rgommers · Pull Request #12013 · scipy/scipy · GitHub
