I am running into a bizarre, unpredictable behaviour I cannot understand.
A py.script runs fine, on the command line or VS Code, but it freezes (9 out of 10 times, totally erratically) when ran on a Jupyter notebook.
It seems the last extract_deflection function is causing all the fuss when ran on a Jupyter notebook. I was wondering if anything obvious sprung to mind.
I have also doubts about how I set the solve_inplace function. I append the intermediate solutions to a list u_hist which the function returns, while the last solution is saved inplace. I wonder if I am doing something funny with the memory.
Second question: My aim is to run plenty of these solve_inplace calls over a wholegrid of input parameters. Do I need to delete the Nonlinear Problem before creating a new one? I noticed for example here, projection.py that the professionals “delete” PETSc object as they become useless. I see a method __del__ exist for NewtonSolver, but I get the error message 'NewtonSolver' object has no attribute '__del__'. Thank you so much
A MWE is attached.The main file is
from dolfinx import fem, mesh, plot
from utils_copy import create_mesh
from utils_copy import solve_inplace
from utils_copy import extract_deflection
domain = create_mesh(20,1,5,3)
V = fem.VectorFunctionSpace(domain, ("CG", 2))
u = fem.Function(V)
results = solve_inplace(domain, V, u, 1.0e4,0.3)
u = fem.Function(V)
results_lin = solve_inplace(domain, V, u, 1.0e4,0.3, LINEAR=True)
linear_deflection = [extract_deflection(domain, results_lin[i])[1] for i in range(9)]
nonlinear_deflection = [extract_deflection(domain, results[i])[1] for i in range(9)]
print("Made it")
and some utilities functions, basically out the Fenicsx tutorials.
from dolfinx import nls
from dolfinx import log
from dolfinx import geometry
import pyvista
pyvista.set_jupyter_backend("panel")
L = 20
def create_mesh(L, H, N_DIV_x, N_DIV_y):
domain = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([0,0]), np.array([L, H])],
[N_DIV_x, N_DIV_y], mesh.CellType.quadrilateral)
return domain
def left(x):
return np.isclose(x[0], 0)
def right(x):
return np.isclose(x[0], L)
def solve_inplace(domain, V,u, E, nu, LINEAR = False):
fdim = domain.topology.dim -1
# Concatenate and sort the arrays based on facet indices. Left facets marked with 1, right facets with two
marked_values = np.hstack([np.full(len(left_facets), 1, dtype=np.int32), np.full(len(right_facets), 2, dtype=np.int32)])
facet_tag = mesh.meshtags(domain, fdim, marked_facets[sorted_facets], marked_values[sorted_facets])
u_bc = np.array((0,) * domain.geometry.dim, dtype=PETSc.ScalarType)
left_dofs = fem.locate_dofs_topological(V, facet_tag.dim, facet_tag.indices[facet_tag.values==1])
bcs = [fem.dirichletbc(u_bc, left_dofs, V)]
B = fem.Constant(domain, PETSc.ScalarType((0, 0)))
T = fem.Constant(domain, PETSc.ScalarType((0, 0)))
# u = fem.Function(V)
# Spatial dimension
d = len(u)
# Identity tensor
I = ufl.variable(ufl.Identity(d))
# Deformation gradient
F = ufl.variable(I + ufl.grad(u))
# Right Cauchy-Green tensor
C = ufl.variable(F.T * F)
Ic = ufl.variable(ufl.tr(C))
J = ufl.variable(ufl.det(F))
# Elasticity parameters
E = PETSc.ScalarType(E)
nu = PETSc.ScalarType(nu)
mu = fem.Constant(domain, E/(2*(1 + nu)))
lmbda = fem.Constant(domain, E*nu/((1 + nu)*(1 - 2*nu)))
psi = (mu / 2) * (Ic - 3) - mu * ufl.ln(J) + (lmbda / 2) * (ufl.ln(J))**2
# Stress
# Hyper-elasticity
P = ufl.diff(psi, F)
if LINEAR:
P = 2.0 * mu * ufl.sym(ufl.grad(u)) + lmbda * ufl.tr(ufl.sym(ufl.grad(u))) * I
ds = ufl.Measure('ds', domain=domain, subdomain_data=facet_tag, metadata=metadata)
# Define form F (we want to find u such that F(u) = 0)
F = ufl.inner(ufl.grad(v), P)*dx - ufl.inner(v, B)*dx - ufl.inner(v, T)*ds(2)
#F = ufl.inner(ufl.grad(v), P)*dx - ufl.inner(v, B)*dx
problem = fem.petsc.NonlinearProblem(F, u, bcs)
solver = nls.petsc.NewtonSolver(domain.comm, problem)
# Set Newton solver options
solver.atol = 1e-8
solver.rtol = 1e-8
# log.set_log_level(None)
tval0 = -1
u_hist = []
for n in range(1, 10):
T.value[1] = n * tval0
num_its, converged = solver.solve(u)
assert(converged)
u.x.scatter_forward()
print(f"Time step {n}, Number of iterations {num_its}, Load {T.value}")
# plot_function(n, u)
u_hist.append(u.copy())
# problem.destroy()
return u_hist
### FUNCTION THAT SEEMINGLY CAUSES THE ISSUE
def extract_deflection(domain, uh):
bb_tree = geometry.BoundingBoxTree(domain, domain.topology.dim)
points = np.array([L,0.,0.]).reshape(1,-1)
cells = []
points_on_proc = []
# Find cells whose bounding-box collide with the the points
cell_candidates = geometry.compute_collisions(bb_tree, points.T)
colliding_cells = geometry.compute_colliding_cells(domain, cell_candidates, points.T)
points_on_proc = []
for i, point in enumerate(points):
if len(colliding_cells.links(i))>0:
points_on_proc.append(point)
points_on_proc = np.array(points_on_proc, dtype=np.float64)
u_values = uh.eval(points_on_proc, cells)
# displ_max.append(u_values)
return u_values
