I am developing a Jupyter notebook based exercise for a remote lab course that uses FEniCS/dofin and some associated packages. Unfortunately it runs impossibly slow on the university’s datahub. It seems this could be an issue with the installation on the server, the configuration of the server, or the solver options selected.
Are there any known issues for installing FEniCS using a conda-forge on a JupyterHub?
When I run the notebook on my local machine (MacBookPro - 1 processor, 2.3 GHz, 8GB) it runs in about 3 minutes. When I run the same script on my university’s kubernetes configured JupyterHub, the program gets stuck at the linear solve. Each Newton iteration takes ~10 minutes on the Jupyterhub whereas they take only seconds on my local machine.
I am installing FEniCS using conda-forge, and I am using the same yml file for my local machine and the JupyterHub.
I have tried increasing the CPU and memory available on the Jupyterhub, but it did not fix the problem. A simple problems (ft01_poisson.py) solves successfully to completion. Both systems have similar logs during the solve. Below is an example from the first solve step. The linear solver appears to by umfpack.
Should I try changing the linear solver or solver parameters?
Newton iteration 0: r (abs) = 4.607e-03 (tol = 1.000e-10) r (rel) = 1.000e+00 (tol = 1.000e-09)
Solving linear system of size 7633 x 7633 (PETSc LU solver, umfpack).
PETSc Krylov solver starting to solve 7633 x 7633 system.
Newton iteration 1: r (abs) = 1.527e-03 (tol = 1.000e-10) r (rel) = 3.314e-01 (tol = 1.000e-09)
Thank you for any suggestions or guidance.
