Numerical conductivity coefficient matrix
I wish to create a numerical conductivity coefficient matrix, C, which would be part of the variational statement
a = dot(C*grad(u),grad(v))*dx
for TrialFunction u and TestFunction v.
I have the elements of the coefficient matrix at each node in the mesh stored in files and I intend to read the data into a numpy array, for example, for the numpy array c00:
c00 = read_data(“c00.dat”)
(read_data() is just some routine to get the numbers from the file c00.dat into the numpy array c00.)
I also know that I can create the matrix C using as_matrix:
C = as_matrix(((C00,C01,C02),(C01,C11,C12),(C02,C12,C22)))
(C is symmetric).
My question is how do I convert the numpy arrays c00, etc, into the quantities C00, etc, (and what type are the quantities C00)?
Perhaps I should not be using as_matrix in this instance? If so, what is the alternative? Can I simply write
C = ((c00,c01,c02),(c01,c11,c12),(c02,c12,c22))?
Also, should I have the conductivity values specified at each node or for each element in the mesh?
Thanks very much,
Peter.
The following shows how to build components of the matrix as Function objects from the data. For P_1 functions the data are here given in mesh vertices while for P_0 they are given at cells.
mesh = UnitSquareMesh(4, 4)
# Fake data
x, y = mesh.coordinates().T
# Store and load for completness
np.savetxt('data.txt', np.c_[x, y])
c0, c1 = np.loadtxt('data.txt').T
# Want to have ci represent coefficient of P1 function
# We have data ordered by vertex id while setting dof requires dof ordering
d2v = dof_to_vertex_map(V)
C0 = Function(V); C0.vector().set_local(c0[d2v])
C1 = Function(V); C1.vector().set_local(c1[d2v])
# Now C0 is like x, and C1 is like y
x, y = SpatialCoordinate(mesh)
assert assemble(inner(x-C0, x-C0)*dx) < 1E-13 and assemble(inner(y-C1, y-C1)*dx) < 1E-13
# Finally the matrix
C = as_matrix(((C0, 0), (0, C1)))
# P0 version
V = FunctionSpace(mesh, 'DG', 0)
# Data
x, y = (interpolate(Expression(e, degree=1), V).vector().get_local() for e in ('x[0]', 'x[1]'))
# Dof to cell is here an identity, so d2c is c2d
c2d = V.dofmap().entity_dofs(mesh, mesh.topology().dim())
assert np.linalg.norm(c2d - np.arange(V.dim()), np.inf) < 1E-15
# Want to have ci represent coefficient of P0 function
C0 = Function(V); C0.vector().set_local(c0[c2d])
C1 = Function(V); C1.vector().set_local(c1[c2d])
# With 0 order quadrature these should be same
dx0 = dx(metadata={'quadrature_degree': 0})
assert abs(assemble(inner(x-C0, x-C0)*dx0)) < 1E-13 and abs(assemble(inner(y-C1, y-C1)*dx0)) < 1E-13
Dear MiroK,
That is exactly what I wanted and it works very well.
Thank you very much.
Peter.
