I am trying to solve an ODE of the form
\dot{x} = Ax + Bu
I discritise in time to get the following
(x - x_n)/dt = A\hat{x} + Bu
Where \hat{x} depends on the integration scheme. For Explicit Euler \hat{x} = x_n and for Implicit Euler \hat{x} = x.
I want to use a scheme that has \hat{x} = [x_0, x_1, x_{n2}]. I.e a combination of explicit variables and implicit variables. (Symplectic Euler Scheme). However when I try to implement this I receive the following error…
File "/home/finbar/Documents/git_projects/portHamiltonian_FEM/fenics_projects/wave_eqn/electroMechanical_forDiscourse.py", line 114, in <module>
a = lhs(F)
File "/usr/lib/python3/dist-packages/ufl/formoperators.py", line 79, in lhs
return compute_form_lhs(form)
File "/usr/lib/python3/dist-packages/ufl/algorithms/formtransformations.py", line 379, in compute_form_lhs
return compute_form_with_arity(form, 2)
File "/usr/lib/python3/dist-packages/ufl/algorithms/formtransformations.py", line 345, in compute_form_with_arity
return map_integrands(_transform, form)
File "/usr/lib/python3/dist-packages/ufl/algorithms/map_integrands.py", line 39, in map_integrands
for itg in form.integrals()]
File "/usr/lib/python3/dist-packages/ufl/algorithms/map_integrands.py", line 39, in <listcomp>
File "/usr/lib/python3/dist-packages/ufl/algorithms/map_integrands.py", line 46, in map_integrands
return itg.reconstruct(function(itg.integrand()))
File "/usr/lib/python3/dist-packages/ufl/algorithms/formtransformations.py", line 341, in _transform
e, provides = pe.visit(e)
File "/usr/lib/python3/dist-packages/ufl/algorithms/transformer.py", line 114, in visit
r = h(o)
File "/usr/lib/python3/dist-packages/ufl/algorithms/formtransformations.py", line 145, in sum
part, term_provides = self.visit(term)
r = h(o)
r = h(o)
File "/usr/lib/python3/dist-packages/ufl/algorithms/formtransformations.py", line 275, in linear_indexed_type
part, provides = self.visit(expression)
File "/usr/lib/python3/dist-packages/ufl/algorithms/transformer.py", line 110, in visit
r = h(o, *[self.visit(op) for op in o.ufl_operands])
File "/usr/lib/python3/dist-packages/ufl/algorithms/transformer.py", line 110, in <listcomp>
r = h(o)
r = h(o)
r = h(o)
r = h(o)
File "/usr/lib/python3/dist-packages/ufl/algorithms/formtransformations.py", line 309, in list_tensor
error("PartExtracter does not know how to handle list_tensors with non-zero components providing fewer arguments")
File "/usr/lib/python3/dist-packages/ufl/log.py", line 172, in error
ufl.log.UFLException: PartExtracter does not know how to handle list_tensors with non-zero components providing fewer arguments
Process finished with exit code 1
Using Implict Euler or Explicit Euler works perfectly, I am not sure why the combination mix of the two doesn’t work?
Here is my code which works when timeIntScheme ='IE' or 'EE' for Implict or Explicit Euler respectively, but does not work when timeIntScheme ='SE' for Symplectic Euler
if __name__ == '__main__':
timeIntScheme = 'IE' # WORKS
# timeIntScheme = 'EE' # WORKS
# timeIntScheme = 'SE' # DOESNT WORK
# domain params
nx = 1
ny = 1
xLength = 1.0
yLength = 0.25
# final time and steps
tFinal = 20
numSteps = 2000
# ------------------------------# Create Mesh #-------------------------------#
mesh = RectangleMesh(Point(xLength, 0.0), Point(0.0, yLength), nx, ny)
# time and time step
dt_value = tFinal/numSteps
dt = Constant(dt_value)
# long as the boundary between the two models are the same
Bl_em = 1
R1_em = 0.0
R2_em = 0.0
K_em = 1
m_em = 2
L_em = 0.1
J_em = np.array([[0, Bl_em, 0], [-Bl_em, 0, -1], [0, 1, 0]])
R_em = np.array([[R1_em, 0, 0], [0, R2_em, 0], [0, 0, 0]])
A_conv_em = np.array([[1/L_em, 0, 0], [0, 1/m_em, 0], [0, 0, K_em]])
A_em = Constant((J_em - R_em).dot(A_conv_em))
# ------------------------------# Create Function Spaces and functions#-------------------------------#
# create function spaces for mesh and for Electromechanical ODE variables
odeSpace = FiniteElement('R', triangle, 0) #order 0, 1 variable
element = MixedElement([odeSpace, odeSpace, odeSpace])
U = FunctionSpace(mesh, element)
xode_0, xode_1, xode_2 = TrialFunctions(U)
xode = as_vector([xode_0, xode_1, xode_2])
v_xode_0, v_xode_1, v_xode_2 = TestFunctions(U)
v_xode = as_vector([v_xode_0, v_xode_1, v_xode_2])
# Define functions for solutions at previous and current time steps
u_n = Function(U)
xode_0_n, xode_1_n, xode_2_n = split(u_n)
xode_n = as_vector([xode_0_n, xode_1_n, xode_2_n])
u_ = Function(U)
xode_0_, xode_1_, xode_2_ = split(u_)
# -------------------------------# Boundary Conditions #---------------------------------#
# Left edge boundary condition for marking
class LeftMarker(SubDomain):
return on_boundary and near(x[0], 0.0)
# Initialise mesh function for neumann boundary. Facets are dim()-1, initialise subdomains to index 0
boundaryDomains = MeshFunction('size_t', mesh, mesh.topology().dim() - 1)
boundaryDomains.set_all(0)
leftMark= LeftMarker()
leftMark.mark(boundaryDomains, 0)
# redefine ds so that ds[0] is the dirichlet boundaries and ds[1] are the neumann boundaries
ds = Measure('ds', domain=mesh, subdomain_data=boundaryDomains)
# Forced input
uInput = Expression('sin(3.14159*t)', degree=2, t=0)
# -------------------------------# Problem Definition #---------------------------------#
if timeIntScheme == 'SE':
# THIS DOESNT WORK
#implement Symplectic Euler integration
xode_int = as_vector([xode[0], xode[1], xode_n[2]])
elif timeIntScheme == 'EE':
# THIS WORKS
#implement Explicit Euler integration
xode_int = as_vector([xode_n[0], xode_n[1], xode_n[2]])
elif timeIntScheme == 'IE':
# THIS WORKS
#implement Implicit Euler integration
xode_int = as_vector([xode[0], xode[1], xode[2]])
# Create residual function
F = (-dot(v_xode, xode - xode_n)/dt + dot(v_xode, A_em*xode_int) + \
v_xode[0]*uInput )*ds(0)
a = lhs(F)
L = rhs(F)
# Assemble matrices
A = assemble(a)
B = assemble(L)
# Create vector for output displacement
disp_vec = [0]
# -------------------------------# Solve Loop #---------------------------------#
t = 0
for n in range(numSteps):
set_log_level(LogLevel.ERROR)
t += dt_value
uInput.t = t
B = assemble(L)
#solve for this time step
solve(A, u_.vector(), B)
#output displacement
disp = assemble(xode_2_*ds(0))/yLength # divide by yLength because
#I integrate along the boundary length
disp_vec.append(disp)
# Update previous solution
u_n.assign(u_)
Does anyone know why I am getting this error?
p.s This ODE will eventually be coupled with the boundary of a PDE. If anyone knows a better way to implement an ODE in Fenics I would be delighted to know!
Many thanks!
