Thanks for answer. But I get this ERROR.
line 55, in <module>
kappa = K(subdomains, k_0, k_1, degree=0)
ufl.log.UFLException: Order "0" invalid for "Lagrange" finite element.
That’s why I write 1 and not 0.
Instead of sending in degree, you could send in element=ufl.FiniteElement("DG", mesh.ufl_cell(), 0)
Don’t get it clearly. I have to add this stroke and use this element in Function Space:
or in stroke with interpolate?
kappa_function = interpolate(kappa, element)
During my attempt, I use element in kappa_function, but I get ERROR:
File "/usr/lib/python2.7/dist-packages/ufl/cell.py", line 359, in as_cell
error("Invalid cell %s." % cell)
File "/usr/lib/python2.7/dist-packages/ufl/log.py", line 151, in error
ufl.log.UFLException: Invalid cell [[671 706 716 732]
[168 197 706 732]
[679 680 691 742]
[119 491 578 754]
[119 490 491 754]
[490 491 610 754]].
Shows that some cell invalid and it makes me confused, why only several cells and not all ('cause in this case I at least start thinking that all my mesh wrong)?
Without actually supplying a minimal reproducible example, it is really hard for me to give you any further guidance.
I also note that you are using python 2.7, which was sunset in 2.7.
I would strongly suggest you to use a newer version of Python, see: Sunsetting Python 2 | Python.org
This is link on Google Disk where I put my XML file and MED file from Salome.
And this is the whole code
import os
k_0 = 1.1
k_1 = 2.1
# Create or using mesh
mesh = Mesh("stripes.xml")
# Define subdomains
tol = 1e-14
class Omega_0(SubDomain):
return (0 <= x[0] <= 40 + tol) or (60 - tol <= x[0] <= 100 + tol)
class Omega_1(SubDomain):
return (40 - tol <= x[0] <= 60 + tol) or (100 - tol <= x[0] <= 120 + tol)
# Define conductivity for different subdomains
subdomains = CellFunction('size_t', mesh)
subdomain_0 = Omega_0()
subdomain_1 = Omega_1()
subdomain_0.mark(subdomains, 0)
subdomain_1.mark(subdomains, 1)
# Visualize the subdomains (for illustration purposes)
plot(subdomains, title='Subdomains')
file_s = File('subdomains.xml.gz') << subdomains
# use the values of the mesh function materials to define the variable coefficient kappa
class K(Expression):
def __init__(self, subdomains, k_0, k_1, **kwargs):
self.subdomains = subdomains
self.k_0 = k_0
self.k_1 = k_1
if self.subdomains[cell.index] == 0:
values[0] = self.k_0
values[0] = self.k_1
kappa = K(subdomains, k_0, k_1, degree=1) # degree 1 or 0?
V = FunctionSpace(mesh, 'DG', 0)
kappa_function = interpolate(kappa, V)
# Save file for checking how we get kappa
file_k = File('kappa_stripes.xml.gz') # 'kappa_stripes.pvd'
file_k << kappa_function
# Get the function values at mesh vertices
kappa_values = kappa_function.compute_vertex_values(mesh)
# Sava values to a txt file
np.savetxt('kappa_values.txt', kappa_values)
Unfortunately, for my simulation I need Python 2.7 and can’t use the new version. In this case, perhaps you can’t help me with it, but could you at least recommend me some literature/link where I can read more about boundary, interpolate in FEniCS and how I can make my own conditions. Thanks in advance.
