Issue with marking an inner boundary
I have a 2D mesh which consists of a square with several disk-shaped holes. I want to mark the boundaries according to whether a point lies on the square’s boundaries (id=0) or the i-th hole boundary (id=i,…)
I got this to work for polygon-shaped holes but I can’t figure out why a similar approach is not working for the circular boundaries
Here’s a MWE
import dolfin as FEM
# MESHING A UNIT SQUARE FROM WHIC HOLES WILL BE SUBTRACTED
domain = mshr.Rectangle(FEM.Point(0., 0.,), FEM.Point(1., 1.))
# THE LIST OF (RADIUS, X_CENTER, Y_CENTER) DATA
circles = [[0.1, 0.5, 0.5]]; circles = np.array(circles)
# PERFORM THE BOOLEAN DIFFERENCES
for circle in circles:
    domain -= mshr.Circle(FEM.Point(circle[1:]), circle[0], 60)
# GENERATE MESH
mesh = mshr.generate_mesh(domain, 30)
# A CLASS FOR ID'ING AN INNER CIRCULAR BOUNDARY
class InnerBoundary_circle(FEM.SubDomain):
    def __init__(self, r, x0, y0):
        self.r  = r
        self.x0 = x0
        self.y0 = y0
        super().__init__()
    def on_circle_condition(self, x, y):
        return np.power(x-self.x0, 2) + \
               np.power(y-self.y0, 2) - \
               np.power(self.r, 2)
    def point_belongs_to_circle(self, x):
        x_, y_ = x[:]
        if FEM.near(self.on_circle_condition(x_, y_), 0., eps= 3.e-15):
            return True
        else: return False
        if not on_boundary:
            return on_boundary
            return self.point_belongs_to_circle(x)
# A FUNCTION TO ID ALL BOUNDARIES
def mark_boundaries_circle(meshfn, circle_data):
    for i, circle in enumerate(circle_data):
        r, x, y = circle[:]
        active_boundary = InnerBoundary_circle(r, x, y)
        active_boundary.mark(meshfn, i+1)
    print('THE SET OF INDICES IN MESHFN IS', set(meshfn.array()))
    print('IT SHOULD BE', set(range(len(circle_data)+1)))
    assert len(set(meshfn.array())) == len(circle_data) + 1
# ON TO MARK THE BOUNDARIES
meshfn = FEM.MeshFunction("size_t", mesh, mesh.topology().dim()-1)
meshfn.set_all(0)
try:
    mark_boundaries_circle(meshfn, circles) # FAILS
    print('MARKING SUCCESFUL!')
except:
    print('MARKING UNSUCCESFUL...')
# HOWEVER, THIS SEEMS TO SHOW THAT MARKING SHOULD BE SUCCESFUL...
bmesh = FEM.BoundaryMesh(mesh, 'exterior')
def which_circle(x, y, circles_data):
    for i, circle in enumerate(circles_data):
        r, x0, y0 = circle
        if FEM.near(np.power(x-x0, 2) + np.power(y-y0, 2) - np.power(r, 2), 0., eps= 3.e-15):
            return i+1
    return 0
with plt.style.context('seaborn-bright'):
    colors = ('k', 'r')
    fig, ax = plt.subplots(figsize= (10, 10))
    FEM.plot(mesh)
    for i, (x, y) in enumerate(bmesh.coordinates()):
        plt.scatter((x,), (y,), color= colors[which_circle(x, y, circles)])
    plt.xlabel('x', fontsize = 'xx-large')
    plt.ylabel('y', fontsize = 'xx-large', rotation='horizontal')
    ax.set_aspect('equal')
This produces the output:
THE SET OF INDICES IN MESHFN IS {0}
IT SHOULD BE {0, 1}
and the plot which shows that the boundary points can be identified:
I will appreciate your thoughts on why my InnerBoundary class and my mark_boundaries_circle function don’t seem to work
Using fenics 2019.1.0 installed from the ppa on a google.colab notebook
Thank you,
M.
Setting the eps kwarg in FEM.near() to 1e-3 yields the desired output for me. Maybe consider a mesh size dependent tolerance.
And by the way: Nicely written and very clean code. You don’t see that too often :slight_smile:
…let me advertise vtkplotter.dolfin :slight_smile:
from vtkplotter.dolfin import plot
plot(bmesh, style=1, lc='r', lw=4)
plot(mesh,  wireframe=True, c='k', add=True)
#import matplotlib.pyplot as plt
#def which_circle(x, y, circles_data):
#    for i, circle in enumerate(circles_data):
#        r, x0, y0 = circle
#        if FEM.near(np.power(x-x0, 2) + np.power(y-y0, 2) - np.power(r, 2), 0., eps= 1e-3):
#            return i+1
#    return 0
#with plt.style.context('seaborn-bright'):
#    colors = ('k', 'r')
#    fig, ax = plt.subplots(figsize= (10, 10))
#    FEM.plot(mesh)
#    for i, (x, y) in enumerate(bmesh.coordinates()):
#        plt.scatter((x,), (y,), color= colors[which_circle(x, y, circles)])
#    plt.xlabel('x', fontsize = 'xx-large')
#    plt.ylabel('y', fontsize = 'xx-large', rotation='horizontal')
#    ax.set_aspect('equal')
#    plt.show()
Thank you for your reply. Indeed, drastically relaxing the tolerance does the trick. It’s odd though, I’m still wondering why the “manual” marking (plot-thing) does work with the strict tolerance? Would love to get to the bottom of this
That’s great, thank you for letting us know about it.
I have two questions, though:
  1. Can I choose different colors for different boundaries?
  2. I’m trying to run vtkplotter on a google.colab jupyter notebook, the installation seems to run smoothly but actually trying to plot seems to crash the whole thing, have you tried this?
As your bmesh is a single object so you cannot do it with the plot() shorcut. Still you can do it with
from vtkplotter import Points
colors = ('k', 'r')
cols, coords = [], []
for x,y in bmesh.coordinates():
    cols.append(colors[which_circle(x, y, circles)])
    coords.append([x,y,0])
pts = Points(coords, c=cols)
plot(mesh, pts, style=1, wireframe=True, c='k')
I have no experience with that! But it looks from the debug dump , as it is running on a server, you cannot pop up a rendering window and the webGL backend is not working as expected… I will investigate if there is possible fix…
Okay, it seems, that by default the optional parameter check_midpoint to the SubDomain.mark() method is set to true. If the midpoint between two vertices does not meet your criterion (which it won’t since the midpoints aren’t exactly on the circle) then also the vertices won’t be recognized as being inside your subdomain. Of course, if you set the tolerance large, at some point also the midpoints will fit the criterion.
Calling the mark method as
active_boundary.mark(meshfn, i+1,False)
in your function mark_boundaries_circle() works even with the small eps you first used.
Thanks, @klunkean
that works and it’s nice to know why it does! marking your answer as solution
(for future ref. a good tolerance is around 1e-12)
Cheers!
M
Thanks for your reply. Very good, it will be very interesting to see if/when you get that working
Cheers,
M.
Thank you for this code, it was very helpful for me.
I tried to generate something similar, where instead of having holes, I just have a circular domain in the existing domain, so let’s say a cell in a channel.
With this code and the changes, I still haven’t achieved the marking part… The only differences in our codes is that I define a SubDomain as
    r,x0,y0=0.25,-0.5,0.5
    #Define geometries
    domain = Rectangle(Point(-1,0),Point(1,1))
    circles = [[r,x0, y0]]; circles = np.array(circles)
        circleD = Circle(Point(circle[1:]), circle[0], 60)
    # Set subdomains
    domain.set_subdomain(1,circleD)
    # Create mesh
    mesh=generate_mesh(domain,30)
I would like to have the boundary marked so I can track the surface evolution of that cell.
Any suggestions? Thank you!
