Optimizing Performance for System of Strongly Nonlinear Coupled Equations
Hi everyone,
I’m using FEniCS 2019.1.0 to simulate Poiseuille flow by solving the lattice Boltzmann equations,
\frac{\partial f_i}{\partial t} + \mathbf{c}_i\cdot\nabla f_i = -\frac{1}{\tau} (f_i - f_i^{eq}) + F_i, \quad i \in\{1,...,Q\} \tag{1}
where f_i^{eq} (a bit of misnomer actually) and F_i are (strongly) nonlinear functions of f_1,...,f_Q. Each so-called distribution f_i is associated with a velocity \mathbf{c}_i. We then have a set of Q coupled hyperbolic equations. The macroscopic fluid velocity \mathbf{u} is recovered from the distributions by
\mathbf{u} = \frac{ \sum_{i = 1}^{Q} \mathbf{c}_i f_i }{\sum_{i=1}^{Q} f_i }.
I first discretize the above in time using an operator-splitting method and an explicit Taylor-Galerkin scheme -
\frac{f_i^{*} - f_i^n}{\Delta t} = - \frac{1}{\tau}(f_i^n - f_i^{n,eq}) \tag{2}
\frac{ f_i^{n+1} - f_i^{*} }{\Delta t} = \mathbf{c}_i\cdot\nabla f_i^{\star} - F_i^{n} + \frac{\Delta t}{2} \mathbf{c}_i \cdot\nabla(\mathbf{c}_i \cdot\nabla f_i^{*} - F_i^n). \tag{3}
The above are referred to as the so-called collision and streaming steps. Boundary conditions on the incoming distributions (ie those distributions f_i for which \mathbf{c}_i \cdot \mathbf{n} < 0 on some part of the boundary) are usually defined in terms of the conjugate distribution at the previous timestep. That is, we will have, for example
f_i^{n+1}\bigl|_{\partial\Omega} \gets f_{\bar{i}}^{n}\bigl|_{\partial\Omega}
where \mathbf{c}_i and \mathbf{c}_{\bar{i}} are anti-parallel.
I think I’ve exhausted just about all options to get easy performance increases. Right now, compute time is dominated by the assembly of the RHS vectors for (2) and (3) in each timestep. Is there a way I can speed this up? Find attached a MWE below. Linear forms are defined in the for loop from lines 267 to 287.
import fenics as fe
import os
import matplotlib
matplotlib.use('Agg')
import time
start_time = time.time()
comm = fe.MPI.comm_world
rank = fe.MPI.rank(comm)
plt.close('all')
T = 100000
dt = 0.0001
num_steps = int(np.ceil(T/dt))
Re = 0.96
L_x = 32
L_y = 32
nx = 5
ny = 5
h = L_x/nx
Force_density = np.array([2.6014e-5, 0.0])
# Where to save the plots
WORKDIR = os.getcwd()
outDirName = os.path.join(WORKDIR, "dataDir")
os.makedirs(outDirName, exist_ok=True)
# Lattice speed of sound
c_s = np.sqrt(1/3)
tau = 1
# Number of discrete velocities
Q = 9
# Density on wall
rho_wall = 1.0
# Initial density
rho_init = 1.0
u_wall = (0.0, 0.0)
u_max = Force_density[0]*L_y**2/(8 * rho_init * tau/3)
# D2Q9 lattice velocities
xi = [
    fe.Constant((0.0,  0.0)),
    fe.Constant((1.0,  0.0)),
    fe.Constant((0.0,  1.0)),
    fe.Constant((-1.0,  0.0)),
    fe.Constant((0.0, -1.0)),
    fe.Constant((1.0,  1.0)),
    fe.Constant((-1.0,  1.0)),
    fe.Constant((-1.0, -1.0)),
    fe.Constant((1.0, -1.0)),
# Corresponding weights
w = np.array([
    4/9,
    1/9, 1/9, 1/9, 1/9,
    1/36, 1/36, 1/36, 1/36
# Set up domain. For simplicity, do rectangular mesh.
mesh = fe.RectangleMesh(comm, fe.Point(0, 0), fe.Point(L_x, L_y), nx, nx)
# Set periodic boundary conditions at left and right endpoints
class PeriodicBoundaryX(fe.SubDomain):
    def inside(self, point, on_boundary):
        return fe.near(point[0], 0.0) and on_boundary
    def map(self, right_bdy, left_bdy):
        left_bdy[0] = right_bdy[0] - L_x
        left_bdy[1] = right_bdy[1]
pbc = PeriodicBoundaryX()
V = fe.FunctionSpace(mesh, "P", 1, constrained_domain=pbc)
Vvec = fe.VectorFunctionSpace(mesh, "DG", 0, constrained_domain=pbc)
vel_n = fe.Function(Vvec)
# Define trial and test functions, as well as
# finite element functions at previous timesteps
f_trial = fe.TrialFunction(V)
f_n = []
for idx in range(Q):
    f_n.append(fe.Function(V))
v = fe.TestFunction(V)
# Define FE functions to hold post-streaming solution at nP1 timesteps
f_nP1 = []
    f_nP1.append(fe.Function(V))
# Define FE functions to hold post-collision distributions
f_star = []
    f_star.append(fe.Function(V))
# Define density
def getDens(f_list):
    return f_list[0] + f_list[1] + f_list[2] + f_list[3] + f_list[4]\
        + f_list[5] + f_list[6] + f_list[7] + f_list[8]
# Define velocity
def getVel(f_list):
    distr_fn_sum = f_list[0]*xi[0] + f_list[1]*xi[1] + f_list[2]*xi[2]\
        + f_list[3]*xi[3] + f_list[4]*xi[4] + f_list[5]*xi[5]\
        + f_list[6]*xi[6] + f_list[7]*xi[7] + f_list[8]*xi[8]
    density = getDens(f_list)
    vel_term1 = distr_fn_sum/density
    F = fe.Constant((Force_density[0], Force_density[1]))
    vel_term2 = F * dt / (2 * density)
    return vel_term1 + vel_term2
# Define initial equilibrium distributions
def f_equil_init(vel_idx, Force_density):
    rho_init = fe.Constant(1.0)
    rho_expr = fe.Constant(1.0)
    vel_0 = -fe.Constant((Force_density[0]*dt/(2*rho_init),
                          Force_density[1]*dt/(2*rho_init)))
    # u_expr = fe.project(V_vec, vel_0)
    ci = xi[vel_idx]
    ci_dot_u = fe.dot(ci, vel_0)
    return w[vel_idx] * rho_expr * (
        1
        + ci_dot_u / c_s**2
        + ci_dot_u**2 / (2*c_s**4)
        - fe.dot(vel_0, vel_0) / (2*c_s**2)
# Define equilibrium distribution
def f_equil(f_list, vel_idx):
    rho = getDens(f_list)
    u   = getVel(f_list)
    ci       = xi[vel_idx]
    cu = fe.dot(ci, u)
    u2 = fe.dot(u, u)
    feq = w[vel_idx] * rho * (1 + 3*cu + 4.5*cu**2 - 1.5*u2)
    return feq
def body_Force(vel, vel_idx, Force_density):
    prefactor = w[vel_idx]
    inverse_cs2 = 1 / c_s**2
    inverse_cs4 = 1 / c_s**4
    xi_dot_prod_F = xi[vel_idx][0]*Force_density[0]\
        + xi[vel_idx][1]*Force_density[1]
    u_dot_prod_F = vel[0]*Force_density[0] + vel[1]*Force_density[1]
    xi_dot_u = xi[vel_idx][0]*vel[0] + xi[vel_idx][1]*vel[1]
    Force = prefactor*(inverse_cs2*(xi_dot_prod_F - u_dot_prod_F)
                       + inverse_cs4*xi_dot_u*xi_dot_prod_F)
    return Force
# # Initialize distribution functions. We will use
# f_i^{0} \gets f_i^{0, eq}( \rho_0, \bar{u}_0 ),
# where \bar{u}_0 = u_0 - F\Delta t/( 2 \rho_0 ).
# Here we will take u_0 = 0.
    f_n[idx] = (fe.project(f_equil_init(idx, Force_density), V))
# Define boundary conditions. Here we will use bounceback BCs
# For distributions 5, 2, and 6, the conjugate distributions
# are 7, 4, and 8, respectively.
tol = 1e-8
def Bdy_Lower(x, on_boundary):
    if on_boundary:
        if fe.near(x[1], 0, tol):
            return True
            return False
        return False
f5_lower = f_n[7]
f2_lower = f_n[4]
f6_lower = f_n[8]
f5_lower_func = fe.Function(V)
f2_lower_func = fe.Function(V)
f6_lower_func = fe.Function(V)
fe.project(f5_lower, V, function=f5_lower_func)
fe.project(f2_lower, V, function=f2_lower_func)
fe.project(f6_lower, V, function=f6_lower_func)
bc_f5 = fe.DirichletBC(V, f5_lower_func, Bdy_Lower)
bc_f2 = fe.DirichletBC(V, f2_lower_func, Bdy_Lower)
bc_f6 = fe.DirichletBC(V, f6_lower_func, Bdy_Lower)
# Similarly, we will define boundary conditions for f_7, f_4, and f_8
# at the upper wall. Here, the conjugate distributions are
# 5, 2, and 6.
tol = 1e-8
def Bdy_Upper(x, on_boundary):
    if on_boundary:
        if fe.near(x[1], L_y, tol):
            return True
            return False
        return False
f7_upper = f_n[5]
f4_upper = f_n[2]
f8_upper = f_n[6]
f7_upper_func = fe.Function(V)
f4_upper_func = fe.Function(V)
f8_upper_func = fe.Function(V)
fe.project(f7_upper, V, function=f7_upper_func)
fe.project(f4_upper, V, function=f4_upper_func)
fe.project(f8_upper, V, function=f8_upper_func)
bc_f7 = fe.DirichletBC(V, f7_upper_func, Bdy_Upper)
bc_f4 = fe.DirichletBC(V, f4_upper_func, Bdy_Upper)
bc_f8 = fe.DirichletBC(V, f8_upper_func, Bdy_Upper)
# Define variational problems
bilinear_forms_stream = []
bilinear_forms_collision = []
# Define linear and bilinear forms for the collision and streaming steps
    bilinear_forms_stream.append(f_trial * v * fe.dx)
    bilinear_forms_collision.append(f_trial*v*fe.dx)
    double_dot_product_term = -0.5*dt**2 * fe.dot(xi[idx], fe.grad(f_star[idx]))\
        * fe.dot(xi[idx], fe.grad(v)) * fe.dx
    dot_product_force_term = 0.5*dt**2 * fe.dot(xi[idx], fe.grad(v))\
        * body_Force(getVel(f_star), idx, Force_density) * fe.dx
    lin_form_stream = f_star[idx]*v*fe.dx\
        - dt*v*fe.dot(xi[idx], fe.grad(f_star[idx]))*fe.dx\
        + dt*v*body_Force(getVel(f_star), idx, Force_density)*fe.dx\
        + double_dot_product_term\
        + dot_product_force_term
    lin_form_coll = (f_n[idx] - dt/tau * (f_n[idx] - f_equil(f_n, idx)) )*v*fe.dx
    linear_forms_stream.append(lin_form_stream)
    linear_forms_collision.append(lin_form_coll)
# Assemble matrices for first step
sysMatStream = []
sysMatColl = []
solverListStream = []
solverListColl = []
rhsVecStreaming = []
rhsVecCollision = []
    sysMatStream.append(fe.assemble(bilinear_forms_stream[idx]))
    sysMatColl.append(fe.assemble(bilinear_forms_collision[idx]))
    rhsVecStreaming.append( fe.assemble(linear_forms_stream[idx]) )
    rhsVecCollision.append( fe.assemble(linear_forms_collision[idx]) )
    A = sysMatStream[idx]
    solver = fe.LUSolver(A)
    solverListStream.append(solver)
    A2 = sysMatColl[idx]
    solver2 = fe.LUSolver(A2)
    solverListColl.append(solver2)
vel_file = fe.XDMFFile(comm, f"{outDirName}/vel.xdmf")
vel_file.parameters["flush_output"] = True
vel_file.parameters["functions_share_mesh"] = True
vel_file.parameters["rewrite_function_mesh"] = False
# Apply BCs to matrices for distribution functions 5, 2, and 6
bc_f5.apply(sysMatStream[5])
bc_f2.apply(sysMatStream[2])
bc_f6.apply(sysMatStream[6])
# Apply BCs to matrices for distribution functions 7, 4, 8
bc_f7.apply(sysMatStream[7])
bc_f4.apply(sysMatStream[4])
bc_f8.apply(sysMatStream[8])
# Timestepping
t = 0.0
for n in range(num_steps):
    # Assemble RHS vector for collision step
    pre_collision_time = time.time()
        fe.assemble(linear_forms_collision[idx], tensor=rhsVecCollision[idx])
    post_collision_time = time.time()
    # Solve linear system for collision step, gives us f*
    pre_solve_coll_time = time.time()
        solverListColl[idx].solve(f_star[idx].vector(), rhsVecCollision[idx])
    post_solve_coll_time = time.time()
    solve_coll_time = post_solve_coll_time - pre_solve_coll_time
    # Assemble RHS vectors for streaming step
    pre_stream_time = time.time()
        fe.assemble(linear_forms_stream[idx], tensor=rhsVecStreaming[idx])
    post_assemble_stream_time = time.time()
    pre_assign_time = time.time()
    f5_lower_func.assign(f_star[7] )
    f2_lower_func.assign(f_star[4] )
    f6_lower_func.assign(f_star[8] )
    f7_upper_func.assign(f_star[5] )
    f4_upper_func.assign(f_star[2] )
    f8_upper_func.assign(f_star[6] )
    post_assign_time = time.time()
    #print("assign time = ", post_assign_time - pre_assign_time)
    pre_apply_time = time.time()
    # Apply BCs for distribution functions 5, 2, and 6
    bc_f5.apply(rhsVecStreaming[5])
    bc_f2.apply(rhsVecStreaming[2])
    bc_f6.apply(rhsVecStreaming[6])
    # Apply BCs for distribution functions 7, 4, 8
    bc_f7.apply(rhsVecStreaming[7])
    bc_f4.apply(rhsVecStreaming[4])
    bc_f8.apply(rhsVecStreaming[8])
    post_apply_time = time.time()
    #print("time to apply BCs ", post_apply_time - pre_apply_time)
    # Solve linear system for streaming step
        solverListStream[idx].solve(f_nP1[idx].vector(), rhsVecStreaming[idx])
    post_stream_time = time.time()
    #print("time to solve stream sys ", post_stream_time - pre_stream_time, "\n\n\n\n")
    # Update previous solutions
        f_n[idx].assign(f_nP1[idx])
    if n % 10000 == 0:
        vel_expr = getVel(f_n)
        fe.project(vel_expr, Vvec, function=vel_n)
        vel_file.write(vel_n, t)
Do you use any compilation options? According to this page:
we get most speedup by using “-O3” or “-Ofast” combined with “-march=native”.
I would strongly advice you to switch to dolfinx (and dolfinx_mpc for periodic conditions GitHub - jorgensd/dolfinx_mpc: Extension for dolfinx to handle multi-point constraints. · GitHub)
I’ll here give you a initial conversion of some core aspects of the code:
import dolfinx_mpc
from time import perf_counter
import os
T = 0.1
dt = 0.0001
num_steps = 10
Re = 0.96
L_x = 32
L_y = 32
nx = 5
ny = 5
h = L_x/nx
c_s = np.sqrt(1/3)
tau = 1
Q = 9
# Density on wall
rho_wall = 1.0
# Initial density
rho_init = 1.0
u_wall = (0.0, 0.0)
xi = [
    (0.0,  0.0),
    (1.0,  0.0),
    (0.0,  1.0),
    (-1.0,  0.0),
    (0.0, -1.0),
    (1.0,  1.0),
    (-1.0,  1.0),
    (-1.0, -1.0),
    (1.0, -1.0),
w = np.array([
    4/9,
    1/9, 1/9, 1/9, 1/9,
mesh = dolfinx.mesh.create_rectangle(MPI.COMM_WORLD, np.array([(0, 0), (L_x, L_y)]), (nx, ny))
class PeriodicBoundaryX():
    def indicator(self, x):
        return np.isclose(x[0], L_x)
    def map(self, x):
        left_bdy = np.zeros_like(x)
        left_bdy[0] = L_x - x[0]
        left_bdy[1] = x[1]
        return left_bdy
Vvec = dolfinx.fem.functionspace(mesh, ("DG", 0, (mesh.geometry.dim, )))
    rho_init = dolfinx.fem.Constant(mesh, 1.0)
    rho_expr = dolfinx.fem.Constant(mesh, 1.0)
    vel_0 = -dolfinx.fem.Constant(mesh, np.asarray([Force_density[0]*dt/(2*rho_init),
                                          Force_density[1]*dt/(2*rho_init)], dtype=np.float64))
    ci = dolfinx.fem.Constant(mesh, np.asarray(xi[vel_idx], dtype=np.float64))
    ci_dot_u = ufl.dot(ci, vel_0)
        1
        + ci_dot_u / c_s**2
        - ufl.dot(vel_0, vel_0) / (2*c_s**2)
f_n = [dolfinx.fem.Function(V, name = f"f_{i}") for i in range(Q)]
    f_n[idx].interpolate(dolfinx.fem.Expression(f_equil_init(idx, Force_density), V.element.interpolation_points))
# Define bcs
tol = 1e-8
f5_lower_func = dolfinx.fem.Function(V, name="f5_lower")
f5_lower_func.interpolate(f_n[7])
f2_lower_fuc = dolfinx.fem.Function(V, name="f2_lower")
f2_lower_fuc.interpolate(f_n[4])
f6_lower_func = dolfinx.fem.Function(V, name="f6_lower")
f6_lower_func.interpolate(f_n[8])
lower_facets = dolfinx.mesh.locate_entities_boundary(mesh, mesh.topology.dim-1, lambda x: np.isclose(x[1], 0.0, tol))
lower_dofs = dolfinx.fem.locate_dofs_topological(V, mesh.topology.dim-1, lower_facets)
bc_f5 = dolfinx.fem.dirichletbc(f5_lower_func, lower_dofs)
bc_f2 = dolfinx.fem.dirichletbc(f2_lower_fuc, lower_dofs)
bc_f6 = dolfinx.fem.dirichletbc(f6_lower_func, lower_dofs)
upper_facets = dolfinx.mesh.locate_entities_boundary(mesh, mesh.topology.dim-1, lambda x: np.isclose(x[1], L_y, tol))
upper_dofs = dolfinx.fem.locate_dofs_topological(V, mesh.topology.dim-1, upper_facets)
f7_upper_func = dolfinx.fem.Function(V, name="f7_upper")
f7_upper_func.interpolate(f_n[5])
f4_upper_func = dolfinx.fem.Function(V, name="f4_upper")
f4_upper_func.interpolate(f_n[2])
f8_upper_func = dolfinx.fem.Function(V, name="f8_upper")
f8_upper_func.interpolate(f_n[6])
bc_f7 = dolfinx.fem.dirichletbc(f7_upper_func, upper_dofs)
bc_f4 = dolfinx.fem.dirichletbc(f4_upper_func, upper_dofs)
bc_f8 = dolfinx.fem.dirichletbc(f8_upper_func, upper_dofs)
mpc_with_bc = dolfinx_mpc.MultiPointConstraint(V)
mpc_with_bc.create_periodic_constraint_geometrical(V, pbc.indicator, pbc.map, bcs=[bc_f5, bc_f7])
mpc_with_bc.finalize()
mpc_wo_bc = dolfinx_mpc.MultiPointConstraint(V)
mpc_wo_bc.create_periodic_constraint_geometrical(V, pbc.indicator, pbc.map, bcs=[])
mpc_wo_bc.finalize()
# Define variational forms as usual with V.
See the DOLFINx_MPC demos for more info on this.
If you really don’t want to change to DOLFINx, you should turn on optimization of the compiled forms in legacy fenics (remember to delete the compiled code cache first), i.e. turn on
parameters["form_compiler"]["optimize"]     = True
I believe these options are only available for FEniCSx.
Yes, in legacy FEniCS, you have fewer ways to tweak performance.
There are some arguments like
that can be used in legacy. However, I would again strongly advice to shift to DOLFINx, as it has a massive upgrade with respect to performance and flexibility.
