Speeding up Navier Stokes code
Hey guys, I want to carry out fluid flow simulations in FEniCS. Here are the version specs:
DOLFINx version: 0.10.0.post2
PETSc version: (3, 15, 5)
petsc4py version: 3.15.1
Basix version: 0.10.0
UFL version: 2025.2.0.post0
MPI Vendor: (‘Open MPI’, (4, 1, 2))
To begin with I am trying to setup simple benchmarks. I am a complete noob at FEniCS at the moment and I have very less idea of the inner workings. Presently, I am trying to translate my MATLAB or non-PETSc C++ FEM code into it. Below is a 3d driven cavity example using gamg. The krylov iterations and picard iterations are converging as expected. I am unsure if the code is reassembling the non-convective terms in the loop at the moment; or does it recognise the repeating work automatically? I tried explicitly assembling the linear parts separately and adding them but I am running into PETSc issues. It seems as if the structure of the matrix changes while assembling and the linear parts do not simply add correctly to the nonlinear newly assembled pieces. Are there any tutorials, examples, suggestions which can help me in running the code faster? Thanks
import os
from pathlib import Path
# DOLFINx Imports
from dolfinx.fem import (
    Constant, Function, functionspace, dirichletbc,
    locate_dofs_geometrical, form, extract_function_spaces
from dolfinx.fem.petsc import (
    create_matrix, create_vector, assemble_matrix, assemble_vector,
    apply_lifting, set_bc
from dolfinx.mesh import create_unit_cube, CellType
from dolfinx.io import VTKFile, XDMFFile
from ufl import (
    TestFunctions, TrialFunctions, split, dot, div, grad, dx, inner,
    sqrt, CellDiameter, lhs, rhs
# 1. Simulation Parameters
N = 16
Re = 1000.0
T_end = 10.0
# --- IO Controls ---
output_freq = 5
results_folder = Path("results_3d_cavity_final")
checkpoint_xdmf_path = results_folder / "checkpoint.xdmf"
checkpoint_meta_path = results_folder / "checkpoint_meta.npy"
# --- Adaptive Time Stepping ---
Target_CFL = 1
Max_dt = 0.1
Min_dt = 1e-5
WARMUP_STEPS = 3
WARMUP_DT_START = 1e-5
# Ramp the lid velocity over the first 0.1 seconds to prevent shock
RAMP_DURATION = 0.1
# --- Solver Tolerances ---
PROD_MAX_PICARD = 10
PROD_MAX_KSP = 100
PROD_KSP_TOL = 1e-8
# Convergence Criteria
STAGNATION_TOL = 1e-4
NONLIN_RES_TOL = 1e-4
picard_relaxation = 1
ENABLE_SUPG = 1.0
ENABLE_PSPG = 1.0
comm = MPI.COMM_WORLD
# 2. Mesh & Functions
if comm.rank == 0:
    print(f"Generating 3D Mesh ({N}x{N}x{N})...", flush=True)
mesh = create_unit_cube(comm, N, N, N, cell_type=CellType.tetrahedron)
h_min = 1.0 / N
dt_init = 0.5 * h_min
# Spaces
P2_v = element("Lagrange", mesh.basix_cell(), 2, shape=(mesh.geometry.dim,))
P1_s = element("Lagrange", mesh.basix_cell(), 1)
Mixed_Elem = mixed_element([P2_v, P1_s])
W = functionspace(mesh, Mixed_Elem)
# Functions
w = Function(W)
w_k = Function(W)
w0 = Function(W)
w00 = Function(W)
(u_trial, p_trial) = TrialFunctions(W)
(v, q) = TestFunctions(W)
u_k, p_k = split(w_k)
u0, p0 = split(w0)
u00, p00 = split(w00)
# Physical Constants
rho = 1.0
mu = 1.0 / Re
nu = Constant(mesh, PETSc.ScalarType(mu / rho))
dt = Constant(mesh, PETSc.ScalarType(WARMUP_DT_START))
f_body = Constant(mesh, PETSc.ScalarType((0.0, 0.0, 0.0)))
# 3. Boundary Conditions
V_sub, _ = W.sub(0).collapse()
Q_sub, _ = W.sub(1).collapse()
# A. Wall BC (Value = 0.0)
u_walls = Function(V_sub)
u_walls.x.array[:] = 0.0
dofs_walls = locate_dofs_geometrical((W.sub(0), V_sub),
    lambda x: np.logical_or(np.isclose(x[0],0)|np.isclose(x[0],1), np.isclose(x[2],0)|np.isclose(x[2],1) | np.isclose(x[1],0)))
bc_walls = dirichletbc(u_walls, dofs_walls, W.sub(0))
# B. Lid BC (Value = Ramped from 0.0 to 1.0)
u_lid = Function(V_sub)
u_lid.interpolate(lambda x: np.vstack((np.ones_like(x[0]), np.zeros_like(x[0]), np.zeros_like(x[0]))))
dofs_lid = locate_dofs_geometrical((W.sub(0), V_sub), lambda x: np.isclose(x[1], 1.0))
bc_lid = dirichletbc(u_lid, dofs_lid, W.sub(0))
# C. Pressure Pin (Value = 0.0)
dofs_p = locate_dofs_geometrical((W.sub(1), Q_sub), lambda x: (np.isclose(x[0],0)&np.isclose(x[1],0)&np.isclose(x[2],0)))
bc_p = dirichletbc(Function(Q_sub), dofs_p, W.sub(1))
# --- REAL BCs (Applied to System) ---
bcs = [bc_lid, bc_walls, bc_p]
# --- ZERO BCs (Applied ONLY to Residual Vector check) ---
# We need a BC that targets the Lid DOFs but forces them to 0.0
u_zero_func = Function(V_sub)
u_zero_func.x.array[:] = 0.0
bc_lid_zero = dirichletbc(u_zero_func, dofs_lid, W.sub(0))
# The walls and pin are already 0.0, so we can reuse them.
# This list is used solely to zero out the "Reaction Forces" in the residual check.
bcs_zero = [bc_lid_zero, bc_walls, bc_p]
# 4. Form Helper Functions
h = CellDiameter(mesh)
def get_tau(u_vec, dt_val):
    u_mag = sqrt(dot(u_vec, u_vec) + 1e-10)
    return 1.0 / sqrt( (2.0/dt_val)**2 + (2.0*u_mag/h)**2 + (4.0*nu/h**2)**2 )
# 5. Linearized System Forms
tau_lin = get_tau(u_k, dt)
# --- BDF1 Linear ---
dt_inv = 1.0/dt
mom_lhs_bdf1 = dt_inv * u_trial + dot(grad(u_trial),u_k) + grad(p_trial)
mom_rhs_bdf1 = f_body + dt_inv * u0
F_lin_bdf1 = inner(dt_inv * u_trial, v)*dx \
           + inner(dot(grad(u_trial),u_k), v)*dx \
           + nu * inner(grad(u_trial), grad(v))*dx \
           - inner(p_trial, div(v))*dx + inner(div(u_trial), q)*dx \
           - inner(f_body + dt_inv * u0, v)*dx
F_lin_bdf1 += ENABLE_SUPG * inner(mom_lhs_bdf1 - mom_rhs_bdf1, tau_lin * dot(grad(v),u_k)) * dx
F_lin_bdf1 += ENABLE_PSPG * inner(mom_lhs_bdf1 - mom_rhs_bdf1, tau_lin * grad(q)) * dx
# --- BDF2 Linear ---
bdf2_fac = 1.0 / (2.0*dt)
mom_lhs_bdf2 = 3.0*bdf2_fac * u_trial + dot(grad(u_trial),u_k) + grad(p_trial)
mom_rhs_bdf2 = f_body + bdf2_fac * (4.0*u0 - u00)
F_lin_bdf2 = inner(3.0*bdf2_fac * u_trial, v)*dx \
           - inner(f_body + bdf2_fac * (4.0*u0 - u00), v)*dx
F_lin_bdf2 += ENABLE_SUPG * inner(mom_lhs_bdf2 - mom_rhs_bdf2, tau_lin * dot(grad(v),u_k)) * dx
F_lin_bdf2 += ENABLE_PSPG * inner(mom_lhs_bdf2 - mom_rhs_bdf2, tau_lin * grad(q)) * dx
# Use standard 'form' and imported 'lhs/rhs'
a_bdf1, L_bdf1 = form(lhs(F_lin_bdf1)), form(rhs(F_lin_bdf1))
a_bdf2, L_bdf2 = form(lhs(F_lin_bdf2)), form(rhs(F_lin_bdf2))
# 6. NON-LINEAR Residual Forms
u_curr, p_curr = split(w)
tau_nonlin = get_tau(u_curr, dt)
# --- BDF1 ---
mom_strong_bdf1 = dt_inv*(u_curr - u0) + dot(grad(u_curr),u_curr) + grad(p_curr) - f_body
R_bdf1 = inner(dt_inv*(u_curr - u0), v)*dx + inner(dot(grad(u_curr),u_curr), v)*dx + nu * inner(grad(u_curr), grad(v))*dx \
       - inner(p_curr, div(v))*dx + inner(div(u_curr), q)*dx - inner(f_body, v)*dx
R_bdf1 += ENABLE_SUPG * inner(mom_strong_bdf1, tau_nonlin * dot(grad(v),u_curr)) * dx
R_bdf1 += ENABLE_PSPG * inner(mom_strong_bdf1, tau_nonlin * grad(q)) * dx
# --- BDF2 ---
mom_strong_bdf2 = bdf2_fac*(3.0*u_curr - 4.0*u0 + u00) + dot(grad(u_curr),u_curr) + grad(p_curr) - f_body
R_bdf2 = inner(bdf2_fac*(3.0*u_curr - 4.0*u0 + u00), v)*dx + inner(dot(grad(u_curr),u_curr), v)*dx + nu * inner(grad(u_curr), grad(v))*dx \
R_bdf2 += ENABLE_SUPG * inner(mom_strong_bdf2, tau_nonlin * dot(grad(v),u_curr)) * dx
R_bdf2 += ENABLE_PSPG * inner(mom_strong_bdf2, tau_nonlin * grad(q)) * dx
Res_Form_BDF1 = form(R_bdf1)
Res_Form_BDF2 = form(R_bdf2)
# 7. Solver Setup
A = create_matrix(a_bdf1)
b = create_vector(extract_function_spaces(L_bdf1))
res_vector = create_vector(extract_function_spaces(L_bdf1))
ksp = PETSc.KSP().create(mesh.comm)
ksp.setOperators(A)
ksp.setType("gmres")
ksp.setTolerances(rtol=PROD_KSP_TOL, max_it=PROD_MAX_KSP)
pc = ksp.getPC()
pc.setType("gamg")
pc.setGAMGType("agg")
opts = PETSc.Options()
opts["pc_gamg_sym_graph"] = True       # Fixes "un-symmetric graph" error
opts["pc_gamg_square_graph"] = 1       # Improves robustness for non-symmetric/convective systems
opts["pc_gamg_agg_nsmooths"] = 1       # (Optional) Smoothens aggregation
ksp.setFromOptions()
# IO
results_folder.mkdir(exist_ok=True, parents=True)
file_u = VTKFile(comm, results_folder / "velocity.pvd", "w")
file_s = VTKFile(comm, results_folder / "pressure.pvd", "w")
u_vis = Function(V_sub, name="Velocity")
p_vis = Function(Q_sub, name="Pressure")
# 8. Optimized Time Loop
t = 0.0
step = 0
# Helper to scale lid velocity
def update_lid_bc(current_time):
    scale = min(current_time / RAMP_DURATION, 1.0)
    # 1. Update the Function used by the Real BC
    u_lid.x.array[:] = 0.0
    u_lid.interpolate(lambda x: np.vstack((np.full_like(x[0], scale), np.zeros_like(x[0]), np.zeros_like(x[0]))))
    u_lid.x.scatter_forward()
if comm.rank == 0:
    print(f"{'Step':<5} | {'Time':<7} | {'dt':<9} | {'Mode':<6} | {'Picard':<6} | {'KSP':<4} | {'Diff(Rel)':<10} | {'NL-Res(Abs)':<11}", flush=True)
while t < T_end:
    step += 1
    # 1. Update Time Step & Mode
    if step <= WARMUP_STEPS:
        current_a, current_L = a_bdf1, L_bdf1
        current_Res_Form = Res_Form_BDF1
        ramp = step / WARMUP_STEPS
        dt.value = WARMUP_DT_START + ramp * (dt_init - WARMUP_DT_START)
        min_picard = 1
        solver_mode = "Warm"
        current_a, current_L = a_bdf2, L_bdf2
        current_Res_Form = Res_Form_BDF2
        # CFL Update
        u_vis.interpolate(w.sub(0))
        u_flat = u_vis.x.array.reshape((-1, 3))
        u_max = comm.allreduce(np.max(np.linalg.norm(u_flat, axis=1)), op=MPI.MAX)
        dt.value = max(min(Target_CFL * h_min / max(u_max, 1e-6), Max_dt), Min_dt)
        min_picard = 2
        solver_mode = "BDF2"
    t += dt.value
    # 2. Ramp BCs
    update_lid_bc(t)
    # Predictor
    w_k.x.array[:] = w0.x.array[:]
    w_k.x.scatter_forward()
    rel_diff = 1.0
    nonlin_res_norm = 1.0
    # --- Picard Loop ---
    for i in range(PROD_MAX_PICARD):
        # A. Linear Solve
        A.zeroEntries()
        assemble_matrix(A, current_a, bcs=bcs)
        with b.localForm() as loc_b: loc_b.set(0)
        assemble_vector(b, current_L)
        apply_lifting(b, [current_a], [bcs])
        set_bc(b, bcs)
        ksp.solve(b, w.x.petsc_vec)
        w.x.scatter_forward()
        # B. Calculate Relative Update Difference
        diff_sq = comm.allreduce(np.sum((w.x.array - w_k.x.array)**2), op=MPI.SUM)
        norm_sq = comm.allreduce(np.sum(w.x.array**2), op=MPI.SUM)
        rel_diff = np.sqrt(diff_sq) / (np.sqrt(norm_sq) + 1e-10)
        # C. Calculate True Non-Linear Residual
        # 1. Assemble the vector (Integral of the Strong Form)
        with res_vector.localForm() as loc_r: loc_r.set(0)
        assemble_vector(res_vector, current_Res_Form)
        # 2. Ghost Update (Sum contributions from parallel partitions)
        res_vector.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
        # 3. Force Boundary Residuals to Zero
        set_bc(res_vector, bcs_zero)
        nonlin_res_norm = res_vector.norm()
        # D. Update Guess
        w_k.x.array[:] = picard_relaxation * w.x.array[:] + (1.0 - picard_relaxation) * w_k.x.array[:]
        # E. Check Convergence
        if i >= (min_picard - 1):
            if (rel_diff < STAGNATION_TOL) and (nonlin_res_norm < NONLIN_RES_TOL):
                break
            # Stagnation Safety (If solution stops changing, we trust it)
            if rel_diff < 1e-9:
                break
    # Update History
    w00.x.array[:] = w0.x.array[:]
    w0.x.array[:] = w.x.array[:]
    if comm.rank == 0:
        print(f"{step:<5} | {t:<7.4f} | {dt.value:<9.2e} | {solver_mode:<6} | {i+1:<6} | {ksp.getIterationNumber():<4} | {rel_diff:<10.2e} | {nonlin_res_norm:<11.2e}", flush=True)
    # Output
    if step % output_freq == 0 or step == WARMUP_STEPS:
        p_vis.interpolate(w.sub(1))
        file_u.write_function([u_vis], t)
        file_s.write_function([p_vis], t)
        with XDMFFile(comm, checkpoint_xdmf_path, "w") as xdmf:
            xdmf.write_mesh(mesh)
            u_out = Function(functionspace(mesh, ("Lagrange", 1, (mesh.geometry.dim,))))
            u_out.interpolate(w.sub(0))
            u_out.name = "velocity"
            xdmf.write_function(u_out)
            p_out = w.sub(1).collapse()
            p_out.name = "pressure"
            xdmf.write_function(p_out)
        if comm.rank == 0:
            np.save(checkpoint_meta_path, {'t': t, 'step': step, 'dt': dt.value})
if comm.rank == 0:
    print("Done.", flush=True)
This is a nice resource: Efficient usage of the Unified Form Language — FEniCS Workshop
Looking briefly at your code, I don’t see any glaringly obvious performance problems. You’re nicely defining your forms outside of your loops, have an output_freq flag, etc.
I’d do a little profiling; wrap a timer around the solve step and confirm that >95% of your time is spent there. If this is not the case, then there may be some FEniCS code to optimize. If this is the case, then you can consider one of three things:
  1. Are the number of nonlinear iterations maybe excessive? For mild physical/discrete parameters (timestep, Reynolds number, geometrical complexity, mesh regularity/refinement), I’d expect you’d need around 4 iterations. If you need significantly more…
1-a: This could be because you’re using home-made Picard iterations as opposed to the FEniCS-ported Scalable Nonlinear Equation Solver (SNES) from PETSc. With the latter you can use Newton with linesearch. This likely reduces iteration numbers.
1-b: Or because your weak form may not be entirely appropriate. I’m seeing you’re using Taylor-Hood elements and SUPG, so the basic ingredients are there. I’d recommend making the stabilization parameter in SUPG explicit. That way, non-linearities don’t proliferate.
  1. If each solve is just taking too long, then you’ll have to go back to the drawing board for preconditioning you iterative solver. Indeed, I’d not expect gamg to perform all that well for saddle point problems. See FEniCSx4Flow / Projects / Preconditioning · GitLab for some snippets of preconditioning code, and the README for some theory. This is quite a rabbit hole though…
Hi Stein, thanks for your detailed answer.
The Picard/Newton iterations and gamg iterations are as expected. About 5-6 Picard iterations for Re = 2000 at 10 CFL, and 10 or less GAMG iterations per Picard iteration.
It seems I pasted in the P2-P1 Taylor hood version; I have various versions of this. Yes indeed GAMG will not work on a P2-P1 workflow as is: it’s the PSPG filling up the otherwise null matrix with a pressure Poisson like term. Additionally SUPG helps in clustering the eigen modes: overall both make the matrix symmetric and invertible.
It seems the RAM is the big issue: the RAM consumed is for example in a P1-P1 case also very high, almost 10 times the RAM requirement for a similar FVM code. The deal ii implementation of matrix free is faster but I find FEniCS has some benefits: mainly the ease of setup. If the code isn’t the issue I believe I will have to eventually go back to deal ii
Those are indeed the numbers I’d hope for. I don’t think you can do much better than that. Did you confirm most of the execution time is in those 10 solves? That’s something that’s going to be a challenge to improve on (maybe Boomeramg? I don’t know how their performance compares)
Hmm, this is comparing apples and oranges a bit though. Compared to FVM on the same grid, FEM is definitely more expensive, but likely also way more accurate. That’s often difficult to appreciate; the practicioner’s perspective is to just throw the most refined mesh possible at a problem.
Of course, comparing to a matrix free implementation is quite tricky on multiple fronts. This is possible in FEniCS too (Matrix-free conjugate gradient solver for the Poisson equation — DOLFINx 0.10.0.post1 documentation)
With respect to matrix free solvers, one can consider the PR: Add matrix free demo using PETSc by jorgensd · Pull Request #3938 · FEniCS/dolfinx · GitHub
the which has a demo showing how to use dolfinx with a matrix free solver wrapped in PETSc
Thanks Stein,
I wasn’t aware about the matrix-free in FEniCS. In deal ii this took 3x the RAM and 2x the time of FVM for my industry problems which is workable sweet spot. I find it quite flexible and certainly more accurate, as you mentioned. I will also profile the code in more depth as you suggested.
That said, I thank you for the help, sir :folded_hands:. I didn’t recognise it was the same person whose youtube lectures helped me so much​:folded_hands: I am really honoured and privileged to meet you, if nothing, on a chat.
Thanks Dokken, that clears it I suppose :+1:. I have what I was looking for :slight_smile:
I you end up porting your code to matrix free, then let us know your findings! I’d be very curious.
Hello Professor,
I did try a matrix free approach for FEniCS but it seems I have to use AMG which blows up the RAM anyways. Firedrake has a very similar UFL but a built-in ‘matfree’ and ‘meshhierarchy’. It is easy to port the FEniCS code to Firedrake. A geometric multigrid with monolithic semi-implicit approach with 1 M dof P1-P1 tets on a unit cube lands in the zone of 6 GB RAM for 16 cores; which is pretty decent since the operator split OpenFOAM takes about 2.3 GB RAM with a hex mesh (though it is using AMG). Firedrake with AMG will land in 15 GB for the same problem.
I am not sure about the difference in the core architecture of FEniCS and Firedrake for a beginner like me, since both use the same UFL. Does FEniCS have a ready function that prepares a mesh hierarchy for geometric multigrid function? I am sure someone must have implemented it.
I actually believe that it does not… I believe that a plan was in place, but did not get completed.
In any case, thanks for making your code openly accessible! I’ll be sure to study your implementation at some point.
