P1isoP2 elements
Is it possible to implement “P1isoP2” elements in fenicsx, where one has a mixed element on a grid and a refined version of that same grid?
I’m interested in trying this in the context of solving the Navier-Stokes equations, with linear elements for the pressure on a regular triangular grid, and linear elements for velocity on a refined triangulation. My naïve approach using two meshes didn’t get very far:
mesh = create_unit_square(MPI.COMM_WORLD, h//2, h//2, CellType.triangle)
mesh_refined = create_unit_square(MPI.COMM_WORLD, h, h, CellType.triangle)
P2v = ufl.VectorElement("P", mesh.ufl_cell(), 1)
P1 = ufl.FiniteElement("P", mesh_refined.ufl_cell(), 1)
TH = ufl.MixedElement([P2v, P1])
W = fem.FunctionSpace(mesh_refined, TH)
Which leads to odd but not surprising errors when attempting to construct the forms:
TypeError: '<' not supported between instances of 'Mesh' and 'Mesh'
I don’t think this is possible yet, but it may be possible in the (quite distant) future once we’ve looked at supporting macro elements (eg Guzmán-Neilan elements).
Are there any advances on the topic ?
P1 iso P2 elements are now supported, you can create them with:
import basix
import basix.ufl
element = basix.ufl.element(basix.ElementFamily.iso, basix.CellType.triangle, 1)
mesh = create_unit_square(MPI.COMM_WORLD, 10, 10, CellType.triangle)
W = fem.FunctionSpace(mesh, element)
Thank you for your answer, I didn’t know this was available. However in addition to the velocity I would need to define tensors on the same refined grid which would be of order 0. I tried to pass 0 as order in your code but I got an error “Cannot create a continuous order 0 Lagrange basis function”. It seems that it forces the elements to be continuous. Is there any workaround ?
This should work:
element = basix.ufl.element(basix.ElementFamily.P, basix.CellType.triangle, 0, discontinuous=true)
Did you mean basix.ElementFamily.iso ?
Also this does not provide a tensor but only a scalar, I wanted to plug this into ufl.TensorElement but the family name ‘iso’ does not exist (that’s actually why I thought it was not implemented). I thought using “ufl.finiteelement.elementlist.register_element” would solve the problem but depending on the order of the element, the sobolev space varies from H1 to L2, but the basix family name remains ‘iso’, so I can’t register both order 1 and order 0 in the same script. Did I miss anything ?
ufl.TensorElement and ufl.finiteelement.elementlist.register_element are deprecated and will be removed in the next UFL release, so we recommend moving away from using these.
The functions in basix.ufl should be able to do everything that you used to do with these. You can create a tensor element by passing a shape into the element function, for example:
    discontinuous=true, shape=(2, 2))
There’s no need to use an iso element here as it would be the same as a DP0 element
Okay thank you ! In that case I guess that ufl.VectorElement should also be replaced by something like
vector = basix.ufl.element(
basix.ElementFamily.iso,basic.CellType.triangle,1,shape=(2,))
Concerning the use of basix.ElementFamily.iso, I don’t understand why this is the same as basix.ElementFamily.P when the degree is 0. For me the latter designates the use of Lagrange elements, so if we consider the order 0 this makes only one degree of freedom per triangle. What I want is Lagrange elements of order 0 but on the refined grid, so this makes 3 degrees of freedom per triangle on the coarse mesh. Is there any way to get that ?
Yes, that’s exactly how to create a vector element.
In Basix, the basis functions of an iso element are always continuous across the boundaries between edges on the fine mesh (that are not edges in the coarse mesh), so there’s currently no way to make this element. I’ve opened an issue for this: Add discontinuous iso element · Issue #794 · FEniCS/basix · GitHub
Yes.
I’ll let @mscroggs comment on the other part of the question.
Okay I see, thank you
Hi, @mscroggs, I am also trying to use P1-iso-P2 element. But I have difficulties plotting results like P2 element. I get the following error
     97 if V.ufl_element().family_name not in [
     98     "Discontinuous Lagrange",
     99     "Lagrange",
    103     "P",
    104 ]:
--> 105     raise RuntimeError(
    106         "Can only create meshes from continuous or discontinuous Lagrange spaces"
    107     )
    109 degree = V.ufl_element().degree
    110 if degree == 0:
RuntimeError: Can only create meshes from continuous or discontinuous Lagrange spaces"
The plotting code is modified from a Taylor-Hood element example.
P2 = element(basix.ElementFamily.iso, msh.topology.cell_name(), 1, shape=(2,))
P1 = element("Lagrange", msh.topology.cell_name(), 1)
mixed = mixed_element([P2, P1])
V, Q = functionspace(msh, P2), functionspace(msh, P1)
pyvista.start_xvfb()
topology, cell_types, geometry = plot.vtk_mesh(V)
values = np.zeros((geometry.shape[0], 3), dtype=np.float64)
values[:, :len(outcome)] = outcome.x.array.real[0:geometry.shape[0]*2].reshape((geometry.shape[0], len(outcome)))
# Create a point cloud of glyphs
function_grid = pyvista.UnstructuredGrid(topology, cell_types, geometry)
function_grid["u"] = values
glyphs = function_grid.glyph(orient="u", factor=0.5)
# Create a pyvista-grid for the mesh
msh.topology.create_connectivity(msh.topology.dim, msh.topology.dim)
# Create plotter
plotter = pyvista.Plotter()
plotter.add_mesh(function_grid, style="wireframe", color="k")
plotter.add_mesh(glyphs)
plotter.view_xy()
plotter.show("glyphs.png")
You would have to interpolate the P1-iso-P2 into an appropriate continuous or discontinuous Lagrange space to visualize it with Pyvista.
Thanks @dokken, after interpolate we can view the output now. But I find the results from p1-iso-p2/p1 is not matching the results as p2/p1.
The first problem I had is that create_mesh doesn’t seem to work with iso element?
domain = basix.ufl.element(basix.ElementFamily.iso, "triangle", 1, shape=(2,))
x = [[0., 0.], [1., 0.], [0., 1.], [1., 1.]]
cells = cells = [[0, 3, 1], [0, 2, 3]]
msh = create_mesh(MPI.COMM_WORLD, cells, x, domain)
This will lead to error
munmap_chunk(): invalid pointer
[ca1ee4a86145:30195] *** Process received signal ***
[ca1ee4a86145:30195] Signal: Aborted (6)
[ca1ee4a86145:30195] Signal code:  (-6)
[ca1ee4a86145:30195] [ 0] /usr/lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7b457e13a520]
[ca1ee4a86145:30195] [ 1] /usr/lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7b457e18e9fc]
[ca1ee4a86145:30195] [ 2] /usr/lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7b457e13a476]
[ca1ee4a86145:30195] [ 3] /usr/lib/x86_64-linux-gnu/libc.so.6(abort+0xd3)[0x7b457e1207f3]
[ca1ee4a86145:30195] [ 4] /usr/lib/x86_64-linux-gnu/libc.so.6(+0x89676)[0x7b457e181676]
[ca1ee4a86145:30195] [ 5] /usr/lib/x86_64-linux-gnu/libc.so.6(+0xa0cfc)[0x7b457e198cfc]
[ca1ee4a86145:30195] [ 6] /usr/lib/x86_64-linux-gnu/libc.so.6(+0xa0fdc)[0x7b457e198fdc]
[ca1ee4a86145:30195] [ 7] /usr/lib/x86_64-linux-gnu/libc.so.6(free+0xba)[0x7b457e19d49a]
[ca1ee4a86145:30195] [ 8] /usr/lib/x86_64-linux-gnu/libmpi.so.40(ompi_comm_free+0x273)[0x7b4570058ea3]
[ca1ee4a86145:30195] [ 9] /usr/lib/x86_64-linux-gnu/libmpi.so.40(PMPI_Comm_free+0x76)[0x7b4570097246]
[ca1ee4a86145:30195] [10] /usr/lib/x86_64-linux-gnu/libdolfinx_real.so.0.9(_ZN7dolfinx3MPI4CommD2Ev+0x19)[0x7b455d71fca9]
[ca1ee4a86145:30195] [11] /usr/lib/petsc/lib/python3/dist-packages/dolfinx/cpp.cpython-310-x86_64-linux-gnu.so(+0x215a47)[0x7b455da67a47]
[ca1ee4a86145:30195] [12] /usr/lib/petsc/lib/python3/dist-packages/dolfinx/cpp.cpython-310-x86_64-linux-gnu.so(+0x25e4b2)[0x7b455dab04b2]
[ca1ee4a86145:30195] [13] /usr/lib/petsc/lib/python3/dist-packages/dolfinx/cpp.cpython-310-x86_64-linux-gnu.so(+0x29f8f9)[0x7b455daf18f9]
[ca1ee4a86145:30195] [14] python3(+0x169b87)[0x5d02e7575b87]
[ca1ee4a86145:30195] [15] python3(+0x1a2751)[0x5d02e75ae751]
[ca1ee4a86145:30195] [16] python3(+0x169bc7)[0x5d02e7575bc7]
[ca1ee4a86145:30195] [17] python3(+0x1a2751)[0x5d02e75ae751]
[ca1ee4a86145:30195] [18] python3(+0x15b797)[0x5d02e7567797]
[ca1ee4a86145:30195] [19] python3(_PyEval_EvalFrameDefault+0x1be5)[0x5d02e7582eb5]
[ca1ee4a86145:30195] [20] python3(+0x25ae56)[0x5d02e7666e56]
[ca1ee4a86145:30195] [21] python3(PyEval_EvalCode+0x86)[0x5d02e7666d26]
[ca1ee4a86145:30195] [22] python3(+0x281ae8)[0x5d02e768dae8]
[ca1ee4a86145:30195] [23] python3(+0x27c2ef)[0x5d02e76882ef]
[ca1ee4a86145:30195] [24] python3(+0x281885)[0x5d02e768d885]
[ca1ee4a86145:30195] [25] python3(_PyRun_SimpleFileObject+0x1a8)[0x5d02e768ce68]
[ca1ee4a86145:30195] [26] python3(_PyRun_AnyFileObject+0x47)[0x5d02e768cb47]
[ca1ee4a86145:30195] [27] python3(Py_RunMain+0x2be)[0x5d02e768102e]
[ca1ee4a86145:30195] [28] python3(Py_BytesMain+0x2d)[0x5d02e765ad6d]
[ca1ee4a86145:30195] [29] /usr/lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7b457e121d90]
[ca1ee4a86145:30195] *** End of error message ***
Aborted (core dumped)
Then I also can’t get good results with p1-iso-p2 element, while change the element to P2 will work out just fine. I attach my complete code below for your review.
import time
import pyvista
import basix
import dolfinx.fem.petsc
from dolfinx.fem.petsc import assemble_matrix_block, assemble_vector_block
from dolfinx import fem
from dolfinx import plot
from dolfinx.fem import (Constant, Function, functionspace, dirichletbc,
                         extract_function_spaces, form, Expression,
                         locate_dofs_geometrical, locate_dofs_topological,
                         create_interpolation_data, assemble_scalar)
from dolfinx.mesh import (CellType, GhostMode, create_rectangle, locate_entities,
                          locate_entities_boundary, meshtags, DiagonalType, refine,
                          create_mesh)
from dolfinx import geometry
from ufl import div, dx, grad, inner, Measure
domain = basix.ufl.element("Lagrange", "triangle", 2, shape=(2,))
# domain = basix.ufl.element(basix.ElementFamily.iso, "triangle", 1, shape=(2,))
# x = [[0., 0.], [1., 0.], [0., 1.], [1., 1.]]
# cells = cells = [[0, 3, 1], [0, 2, 3]]
# msh = create_mesh(MPI.COMM_WORLD, cells, x, domain)
# for i in range(2):
#     msh.topology.create_entities(1)
#     msh, _, _ = refine(msh)
msh = create_rectangle(MPI.COMM_WORLD,
                        [np.array([0, 0]), np.array([1., 1.])],
                        [8, 8],
                        CellType.triangle, ghost_mode=GhostMode.none,
                        diagonal=DiagonalType.left_right)
# P2 = element(basix.ElementFamily.iso, msh.topology.cell_name(), 1, shape=(2,))
P2 = element("Lagrange", msh.topology.cell_name(), 2, shape=(2,))
(u, p) = ufl.TrialFunction(V), ufl.TrialFunction(Q)
(v, q) = ufl.TestFunction(V), ufl.TestFunction(Q)
f = Constant(msh, (PETSc.ScalarType(0.0), PETSc.ScalarType(0.0)))
a = form([[inner(grad(u), grad(v)) * dx, inner(p, div(v)) * dx], [inner(div(u), q) * dx, Constant(msh, PETSc.ScalarType(0))*p*q*dx]])
L = form([inner(f, v) * dx, inner(Constant(msh, PETSc.ScalarType(0)), q) * dx])  # type: ignore
#-----------------SET THE BOUNDARY CONDITIONS FOR THE PROBLEM----------------------------------------------
def inlet_profile_expression(x):
    return np.stack((x[0]*0, x[0]**2-x[0]))
# Function to mark x = 0, x = 1 and y = 0
def noslip_boundary(x):
    return np.isclose(x[0], 0.0) | np.isclose(x[0], 1.0)
# Function to mark the lid (y = 1)
def inlet(x):
    return np.isclose(x[1], 1.0)
# No-slip condition on boundaries where x = 0, x = 1, and y = 0
noslip = np.zeros(msh.geometry.dim, dtype=PETSc.ScalarType)  # type: ignore
facets = locate_entities_boundary(msh, 1, noslip_boundary)
bc0 = dirichletbc(noslip, locate_dofs_topological(V, 1, facets), V)
# Driving (lid) velocity condition on top boundary (y = 1)
inlet_profile = Function(V)
inlet_profile.interpolate(inlet_profile_expression)
facets = locate_entities_boundary(msh, 1, inlet)
bc1 = dirichletbc(inlet_profile, locate_dofs_topological(V, 1, facets))
bcs = [bc0, bc1]
# Assemble LHS matrix and RHS vector
a,L = form(a),form(L)
A = assemble_matrix_block(a, bcs=bcs)
b = assemble_vector_block(L, a, bcs=bcs)
# Create a solver
ksp.setOperators(A)
ksp.setType("preonly")
# Set the solver type to MUMPS (LU solver) and configure MUMPS to
# handle pressure nullspace
pc = ksp.getPC()
pc.setType("lu")
pc.setFactorSetUpSolverType()
pc.getFactorMatrix().setMumpsIcntl(icntl=24, ival=1)  # For pressure nullspace
pc.getFactorMatrix().setMumpsIcntl(icntl=25, ival=0)  # For pressure nullspace
# Create a block vector (x) to store the full solution, and solve
x = A.createVecLeft()
ksp.solve(b, x)
# Create Functions and scatter x solution
u, p = Function(V), Function(Q)
offset = V.dofmap.index_map.size_local * V.dofmap.index_map_bs
u.x.array[:offset] = x.array_r[:offset]
p.x.array[: (len(x.array_r) - offset)] = x.array_r[offset:]
# P2iso = element(basix.ElementFamily.iso, msh.topology.cell_name(), 1, shape=(2,))
# P2lag = element("Lagrange", "triangle", 1, shape=(2,))
# Vlag = functionspace(msh, P2lag)
# Viso = functionspace(msh, P2iso)
# cells_lag_map = Vlag.mesh.topology.index_map(Vlag.mesh.topology.dim)
# num_cells_lag = cells_lag_map.size_local + cells_lag_map.num_ghosts
# cells_lag = np.arange(num_cells_lag, dtype=np.int32)
# ulag = Function(Vlag)
# interpolation_data = create_interpolation_data(Vlag, Viso, cells_lag)
# ulag.interpolate_nonmatching(u, cells_lag, interpolation_data=interpolation_data)
# ulag.x.scatter_forward()
# pyvista.start_xvfb()
# topology, cell_types, geometry = plot.vtk_mesh(Vlag)
# values = np.zeros((geometry.shape[0], 3), dtype=np.float64)
# values[:, :len(u)] = u.x.array.real[0:geometry.shape[0]*2].reshape((geometry.shape[0], len(u)))
# Create plotter
plotter = pyvista.Plotter(off_screen=True)
plotter.view_xy()
fig_as_array = plotter.screenshot("glyphs.png")
Results from iso
Results from P2
The current design of DOLFINx doesn’t allow for other elements than Lagrange as the coordinate element.
I guess to visualize a P1-iso-P2 element, one should really refine the grid and interpolate onto an appropriate space, for instance (DG, 2):
import basix.ufl
msh = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 1, 1)
iso = basix.ufl.element(basix.ElementFamily.iso, msh.topology.cell_name(), 1)
V = dolfinx.fem.functionspace(msh, iso)
u = dolfinx.fem.Function(V)
visualizing_mesh, _,_ = dolfinx.mesh.refine(msh)
Q = dolfinx.fem.functionspace(visualizing_mesh, ("DG", 2))
q = dolfinx.fem.Function(Q)
num_cells_out = visualizing_mesh.topology.index_map(2).size_local
ipd = dolfinx.fem.create_interpolation_data(Q, V, np.arange(num_cells_out, dtype=np.int32), padding=1e-10)
with dolfinx.io.XDMFFile(msh.comm,"output.xdmf", "w") as xdmf:
    xdmf.write_mesh(msh)
with dolfinx.io.VTXWriter(visualizing_mesh.comm, "output.bp", [q]) as bp:
    for i in range(len(u.x.array)):
        u.x.array[:] = 0.0
        u.x.array[i] = 1.0
        q.x.array[:] = 0.0
        q.interpolate_nonmatching(u, np.arange(num_cells_out, dtype=np.int32), interpolation_data=ipd)
        q.x.scatter_forward()
        bp.write(i)
Maybe @mscroggs has a clever idea for visualizing them.
You can interpolation in to (DG, 1) on the refined mesh as P1-iso-P2 is linear on each sub-triangle. Other than that, your suggestion is the only way I can think of of visualising this
Hi, @mscroggs ,
May I ask you more about the iso elements. I’m still trying to learn about it. I’m testing the element by comparing the P1 element with refined mesh and P1-iso-P2 element. I’m expecting them to have the same results, but the assembled matrix is different.
import basix
from dolfinx.fem.petsc import assemble_matrix, assemble_vector
from dolfinx import mesh
from dolfinx.fem import (Constant, Function, functionspace, dirichletbc,form)
from dolfinx.mesh import (CellType, GhostMode, create_rectangle, DiagonalType, refine, create_mesh)
from ufl import dx, grad, inner
# msh1 = create_rectangle(MPI.COMM_WORLD,
#                         [np.array([0, 0]), np.array([1., 1.])],
#                         [2, 2],
#                         CellType.triangle, ghost_mode=GhostMode.none,
#                         diagonal=DiagonalType.left)
msh2 = create_rectangle(MPI.COMM_WORLD,
                        [1, 1],
msh2.topology.create_entities(1)
msh1, _, _ = refine(msh2)
P1 = element("Lagrange", msh1.topology.cell_name(), 1)
P1_iso_P2 = element(basix.ElementFamily.iso, msh2.topology.cell_name(), 1)
V1, V2 = functionspace(msh1, P1), functionspace(msh2, P1_iso_P2)
(u1, u2) = ufl.TrialFunction(V1), ufl.TrialFunction(V2)
(v1, v2) = ufl.TestFunction(V1), ufl.TestFunction(V2)
f1 = Constant(msh1, PETSc.ScalarType(0.0))
f2 = Constant(msh2, PETSc.ScalarType(0.0))
a1 = inner(grad(u1), grad(v1)) * dx
L1 = inner(f1, v1) * dx
a1,L1 = form(a1),form(L1)
A1 = assemble_matrix(a1)
A1.assemble()
b1 = assemble_vector(L1)
A1.view()
b1.view()
a2 = inner(grad(u2), grad(v2)) * dx
L2 = inner(f2, v2) * dx
a2,L2 = form(a2),form(L2)
A2 = assemble_matrix(a2)
A2.assemble()
b2 = assemble_vector(L2)
A2.view()
b2.view()
outputs:
Mat Object: 1 MPI processes
  type: seqaij
row 0: (0, 4.)  (1, 0.)  (2, -1.)  (3, -1.)  (4, 0.)  (5, 0.)  (6, -1.)  (7, -1.)  (8, 0.)
row 1: (0, 0.)  (1, 1.)  (2, -0.5)  (3, -0.5)
row 2: (0, -1.)  (1, -0.5)  (2, 2.)  (4, -0.5)
row 3: (0, -1.)  (1, -0.5)  (3, 2.)  (5, -0.5)
row 4: (0, 0.)  (2, -0.5)  (4, 1.)  (6, -0.5)
row 5: (0, 0.)  (3, -0.5)  (5, 1.)  (7, -0.5)
row 6: (0, -1.)  (4, -0.5)  (6, 2.)  (8, -0.5)
row 7: (0, -1.)  (5, -0.5)  (7, 2.)  (8, -0.5)
row 8: (0, 0.)  (6, -0.5)  (7, -0.5)  (8, 1.)
Vec Object: 1 MPI processes
  type: mpi
Process [0]
0.
0.
0.
0.
0.
0.
0.
0.
0.
  type: seqaij
row 0: (0, 0.)  (1, 0.)  (2, 0.)  (3, 0.)  (4, 0.)  (5, 0.)
row 1: (0, 0.)  (1, 0.)  (2, 0.)  (3, 0.)  (4, 0.)  (5, 0.)  (6, 0.)  (7, 0.)  (8, 0.)
row 2: (0, 0.)  (1, 0.)  (2, 0.)  (3, 0.)  (4, 0.)  (5, 0.)  (6, 0.)  (7, 0.)  (8, 0.)
row 3: (0, 0.)  (1, 0.)  (2, 0.)  (3, 8.)  (4, -2.)  (5, -2.)  (6, 0.)  (7, -2.)  (8, -2.)
row 4: (0, 0.)  (1, 0.)  (2, 0.)  (3, -2.)  (4, 2.)  (5, 0.)
row 5: (0, 0.)  (1, 0.)  (2, 0.)  (3, -2.)  (4, 0.)  (5, 2.)
row 6: (1, 0.)  (2, 0.)  (3, 0.)  (6, 0.)  (7, 0.)  (8, 0.)
row 7: (1, 0.)  (2, 0.)  (3, -2.)  (6, 0.)  (7, 2.)  (8, 0.)
row 8: (1, 0.)  (2, 0.)  (3, -2.)  (6, 0.)  (7, 0.)  (8, 2.)
  type: mpi
Process [0]
0.
0.
0.
0.
0.
0.
0.
0.
0.
