Parallel computing with mpirun
Will the mesh size or total number of meshed nodes affect the number of processors I can use? When I use different mesh sizes and mpirun -np 4, sometimes it works but sometimes doesn’t.
Thanks
In theory you should be able to use as many processors as there are cells in the mesh (would not advice it). Please provide a minimal working example that gives you an error message on different number of processors
Thank you
Here is the minimal example. There is no error messages, but it seems take forever to run
b_u1=assemble(L_u1, tensor=b_u1) if using mpirun -np 4
from future import print_function
import pdb
import gc
from sys import getsizeof
from numpy import array
if not has_linear_algebra_backend(“PETSc”) and not has_linear_algebra_backend(“Tpetra”):
info(“DOLFIN has not been configured with Trilinos or PETSc. Exiting.”)
exit()
if not has_krylov_solver_preconditioner(“amg”):
info("Sorry, this demo is only available when DOLFIN is compiled with AMG "
“preconditioner, Hypre or ML.”)
exit()
if has_krylov_solver_method(“minres”):
krylov_method = “minres”
elif has_krylov_solver_method(“tfqmr”):
krylov_method = “tfqmr”
info("Default linear algebra backend was not compiled with MINRES or TFQMR "
“Krylov subspace method. Terminating.”)
exit()
Tf = 0.0025/0.87 # final time
num_steps = 6000 # number of time steps
dt1 = Tf / num_steps # time step size
dt1 =0.1E-6
mu_s=100000000
mu_l = 0.00392 # dynamic viscosity
#mu_s=mu_l
rho_l = 3750. # density
rho_s = 4420.
k_l=50
k_s=30.
T_s=1923.
T_l=1973.
#Cp=Constant(759.75) # specific heat ( Change later)
Cp_s=740.
Cp_l=830.
dH=286000.
Create mesh and define function spaces
#mesh = BoxMesh(Point(0.0,0.0,0.0), Point(0.0008,0.0006,0.0003),270,180,90)
mesh = BoxMesh(Point(0.0,0.0,0.0), Point(0.0003,0.0003,0.0003),40,40,40)
V = VectorElement(“CG”, mesh.ufl_cell(), 1)
Q = FiniteElement(“CG”, mesh.ufl_cell(), 1)
#pdb.set_trace()
W=FunctionSpace(mesh, V* Q)
T = FunctionSpace(mesh, ‘CG’, 1)
#q_degree = 2
#dx = dx(metadata={‘quadrature_degree’: q_degree})
#dof_x = T.tabulate_dof_coordinates().reshape(T.dim(),mesh.geometry().dim())
xT = dof_x[:, 0]
yT = dof_x[:, 1]
zT = dof_x[:, 2]
print ('Velocity dofs = ', W.dim())
print ('Pressure dofs = ', T.dim())
#pdb.set_trace()
Define boundaries
boundary_parts = MeshFunction(“size_t”, mesh, mesh.topology().dim()-1)
tor=0.00001
top = AutoSubDomain(lambda x,on_bnd: x[2]>=0.0003-tor and on_bnd)
bot = AutoSubDomain(lambda x,on_bnd: x[2]<=0.0+tor and on_bnd)
left = AutoSubDomain(lambda x,on_bnd: x[0]<=0.0+tor and on_bnd)
right = AutoSubDomain(lambda x,on_bnd: x[0]>=0.0003-tor and on_bnd)
front = AutoSubDomain(lambda x,on_bnd: x[1]<=0.0+tor and on_bnd)
back = AutoSubDomain(lambda x,on_bnd: x[1]>=0.0003-tor and on_bnd)
top.mark(boundary_parts, 1)
bot.mark(boundary_parts, 2)
left.mark(boundary_parts, 3)
right.mark(boundary_parts, 4)
front.mark(boundary_parts, 5)
back.mark(boundary_parts, 6)
ds1 = Measure(“ds”, subdomain_id=1,subdomain_data=boundary_parts)
Define boundary conditions
top = DirichletBC(T, Constant(0), boundary_parts,1)
top_ind=np.fromiter(top.get_boundary_values().keys(),dtype=np.int)
#pdb.set_trace()
bcu_wall1 = DirichletBC(W.sub(0), Constant((0, 0,0)), boundary_parts,2)
bcu_wall2 = DirichletBC(W.sub(0), Constant((0, 0,0)), boundary_parts,3)
bcu_wall3 = DirichletBC(W.sub(0), Constant((0, 0,0)), boundary_parts,4)
bcu_wall5 = DirichletBC(W.sub(0).sub(1), Constant((0)), boundary_parts,5)
bcu_wall6 = DirichletBC(W.sub(0), Constant((0, 0,0)), boundary_parts,6)
bcu_wall4 = DirichletBC(W.sub(0).sub(2), Constant((0)), boundary_parts,1)
indd=np.fromiter(bcu_wall1.get_boundary_values().keys(),dtype=np.int)
bcu = [ bcu_wall1,bcu_wall2,bcu_wall3,bcu_wall4,bcu_wall5,bcu_wall6]
Define trial and test functions
up0 = Function(W)
u0,p0=up0.split(deepcopy=True)
u1 = as_vector((up0[0], up0[1], up0[2]))
p1 = up0[3]
up1 = Function(W)
up2 = Function(W)
upf = Function(W)
up_bc = Function(W)
up = TrialFunction(W)
u = as_vector((up[0],up[1], up[2]))
p = up[3]
vq = TestFunction(W)
v = as_vector((vq[0],vq[1], vq[2]))
q = vq[3]
Tu = TrialFunction(T)
Tv = TestFunction(T)
Define functions for solutions at previous and current time steps
T_n = Function(T)
T_ = Function(T)
T_n.interpolate(Constant(300.0))
tor1=1.e-10
up0.interpolate(Constant([tor1,tor1,tor1,tor1]))
fun_l=Function(T)
stepfn=Function(T)
mu=Function(T)
rho=Function(T)
k=Function(T)
Cp=Function(T)
U = 0.5*(u0 + u)
dt = Constant(dt1)
rho_c=rho_l
k_c=k_l
mu_c=mu_l
#alpham=1./2*((1-f_l(T_n,T_l,T_s,fun_l))*rho_s-f_l(T_n,T_l,T_s,fun_l)*rho_l)/((1-f_l(T_n,T_l,T_s,fun_l))*rho_s+f_l(T_n,T_l,T_s,fun_l)*rho_l)
Cp_c=Cp_l
#pdb.set_trace()
mu.vector()[:] = mu_c
rho.vector()[:] = rho_c
k.vector()[:] = k_c
Cp.vector()[:] = Cp_c
Define strain-rate tensor
return sym(nabla_grad(u))
Define stress tensor
def sigma(u, p,mu):
return 2muepsilon(u) - p*Identity(len(u))
xT1=np.ascontiguousarray(xT, dtype=np.float32)
yT1=np.ascontiguousarray(yT, dtype=np.float32)
LSpower=85.0.36
R=3.75E-5
t = 0
#pdb.set_trace()
#flux=Expression('power/(pi
R2)exp(-2(x2)/R**2)’,power=power,R=R,pi=np.pi,x=xT)
x_cord = Function(T)
x_cord.vector()[:]=np.ascontiguousarray(xT, dtype=np.float32)
y_cord = Function(T)
y_cord.vector()[:]=np.ascontiguousarray(yT, dtype=np.float32)
Time-stepping
it=0
A_u1=None
AT=None
b_u1=None
bT=None
h = mesh.hmax()
def dtang_T(T_n,T):
dtang = Expression(('Tx', 'Ty','Tz'),Tx=project(T_n.dx(0),T,solver_type='cg', preconditioner_type='hypre_amg'), \
        Ty=project(T_n.dx(1),T,solver_type='cg', preconditioner_type='hypre_amg'),Tz=Function(T),degree=2)
return dtang
for n in range(num_steps):
Res = rho/dt*(u-u0) + rho*dot(u0,grad(u)) - (mu)*div(grad(u)+grad(u).T) + grad(p)
tau_supg = Constant(((2.0/dt1)**2 + (2.0*sqrt(np.dot(u0.vector().get_local(),u0.vector().get_local()))/h)**2 + 9*(4.0*mu_l/rho_l/(h**2))**2)**(-0.5))
F_LS = (tau_supg*inner(Res,dot(u0, grad(v))-mu*div((grad(v)+grad(v).T))))*dx
F1 = rho*dot((u - u0) / dt, v)*dx + \
     rho*inner(v, dot(grad(u), u0))*dx \
     + (mu)*inner(grad(v), grad(u)+grad(u).T)*dx \
     - inner(div(v), p)*dx -inner(q, div(u))*dx- dot(Constant((-0.00008))*dtang_T(T_n,T),v)*ds1 \
     +F_LS
#pdb.set_trace()
a_u1 = lhs(F1)
L_u1 = rhs(F1)
#pdb.set_trace()
A_u1=assemble(a_u1, tensor=A_u1)
#pdb.set_trace()
#pdb.set_trace()
[bc.apply(A_u1,b_u1) for bc in bcu]
precond = mu*inner(grad(u)+grad(u).T, nabla_grad(v))*dx \
  +rho*inner(v, dot(grad(u), u0))*dx +dt/rho *inner(grad(p), grad(q))*dx + dt/rho *p*q*dx+(0.01/mu_l) * p*q*dx\
  +rho/dt*inner(u, v)*dx
P, btmp = assemble_system(precond, L_u1, bcu)
solver = PETScKrylovSolver(krylov_method,'amg')
solver.set_operators(A_u1, P)
solver.parameters['monitor_convergence'] = False
solver.parameters['maximum_iterations'] = 1000
solver.parameters['relative_tolerance'] =5E-3
solver.parameters['absolute_tolerance'] = 5E-5
solver.parameters["error_on_nonconvergence"] = False
solver.solve(up1.vector(), b_u1)
assign(up0, up1)
Please format your code by encapsulating it with ```.
Also, please remove any part of the code that is not required for the code to Get to a hanging state. For instance, try removing the matrix assembly and the boundary conditions, as well as trying to simplify the form.
Do you end up with the same issue if you use this mesh on a standard passion problem?
Hope this is what you preferred. It works fine with single or two processors but end up with the issue when I use four processors
import pdb
import gc
dt1 =0.1E-6
mu= 0.00392 # dynamic viscosity
rho= 3750. # density
up0 = Function(W)
p1 = up0[3]
up1 = Function(W)
up2 = Function(W)
upf = Function(W)
up_bc = Function(W)
p = up[3]
q = vq[3]
tor1=1.e-10
tor=0.00001
dt = Constant(dt1)
T_n = Function(T)
h = mesh.hmax()
def dtang_T(T_n,T):
return dtang
Res = rho/dt*(u-u0) + rhodot(u0,grad(u)) - (mu)div(grad(u)+grad(u).T) + grad§
sqrt(np.dot(u0.vector().get_local(),u0.vector().get_local()))/h)*2 + 9(4.0
mu/rho/(h**2))2)(-0.5))
F_LS = (tau_supginner(Res,dot(u0, grad(v))-mudiv((grad(v)+grad(v).T))))*dx
F1 = rho*dot((u - u0) / dt, v)dx +
rho
+F_LS
a_u1 = lhs(F1)
L_u1 = rhs(F1)
A_u1=assemble(a_u1)
b_u1=assemble(L_u1)
Way better. Stille please encapsulate your code such that it gets formatted.
Example :
a="s"
Is achieved by using ``` before and after the code
import pdb
import gc
dt1 =0.1E-6
V = VectorElement("CG", mesh.ufl_cell(), 1)
Q  = FiniteElement("CG", mesh.ufl_cell(), 1)
up0 = Function(W)
p1  = up0[3]
up1 = Function(W)
up2 = Function(W)
upf = Function(W)
up_bc = Function(W)
p   = up[3]
q   = vq[3]
tor1=1.e-10
boundary_parts = MeshFunction("size_t", mesh, mesh.topology().dim()-1)
tor=0.00001
ds1 = Measure("ds", subdomain_id=1,subdomain_data=boundary_parts)
dt   = Constant(dt1)
T = FunctionSpace(mesh, 'CG', 1)
T_n = Function(T)
h = mesh.hmax()
def dtang_T(T_n,T):
    return dtang
tau_supg = Constant(((2.0/dt1)**2 + (2.0*sqrt(np.dot(u0.vector().get_local(),u0.vector().get_local()))/h)**2 + 9*(4.0*mu/rho/(h**2))**2)**(-0.5))
     +F_LS
a_u1 = lhs(F1)
L_u1 = rhs(F1)
A_u1=assemble(a_u1)
b_u1=assemble(L_u1)
The problem is
If you change this to:
dtang_T = as_vector((T_n.dx(0), T_n.dx(1), Function(T)))
Your code runs nicely.
Thank you so much! it works
