Parallel solve from solve method
Hello, i am begginer in parallel fenics technology.
I have Navie-Stokes solver for 3D geometry, and i want solve in parallel. How i can parallel procedure solve? Is it possible to solve matrices in parallel when calling solve method?
My code with solve method:
#num_steps
for n in range(num_steps):
    # Update current time
    b1 = assemble(L1)
    [bc.apply(b1) for bc in bcu]
    solve(A1, u_.vector(), b1, 'bicgstab', 'hypre_amg')
    b2 = assemble(L2)
    [bc.apply(b2) for bc in bcp]
    solve(A2, p_.vector(), b2, 'bicgstab', 'hypre_amg')
    b3 = assemble(L3)
    solve(A3, u_.vector(), b3, 'cg', 'sor')
    max_u = np.abs(np.array(u_n.vector()) - np.array(u_.vector())).max()
    u_n.assign(u_)
    p_n.assign(p_)
    print('t = %.2f: error = %.6g' % (t, max_u))
I can attach the complete code of the problem that works for non-parallel computations
FEniCS does by default run in parallel using mpirun -n num_procs program.py. The solvers interfaced are the PETSc solver suite, see PETSc: Summary of Sparse Linear Solvers Available from PETSc
which gives you an overview of which solvers run in parallel or not.
What is mean X in a cell in the table?
X means that it is supported (i.e. it supports either parallel or complex depending on the column
Thanks, for you answer
I make primitive fenics script, and i want use parallel solver:
I start with this command:
mpirun -n 8 3D_tube_script.py
But i see thih problem:
mpirun was unable to find the specified executable file, and therefore
did not launch the job.  This error was first reported for process
rank 0; it may have occurred for other processes as well.
NOTE: A common cause for this error is misspelling a mpirun command
      line parameter option (remember that mpirun interprets the first
      unrecognized command line token as the executable).
Node:       fenics
Executable: 3D_tube_script.py
My script:
msh = meshio.read("gmsh/3D_channel.msh")
    out_mesh = meshio.Mesh(points=mesh.points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
    if prune_z:
        out_mesh.prune_z_0()
    return out_mesh
tetra_mesh = create_mesh(msh, "tetra", prune_z=True)
meshio.write("facet_mesh.xdmf", triangle_mesh)
print("Normal read!")
mesh = Mesh()
    infile.read(mesh)
        return bool((x[2] < DOLFIN_EPS or x[2] > (1.0 - DOLFIN_EPS)) \
                    and on_boundary)
    def map(self, x, y):
        y[0] = x[0]
        y[1] = x[1]
        y[2] = x[2] - 1
pbc = PeriodicBoundary()
V = VectorFunctionSpace(mesh, "P", 2, constrained_domain=pbc)
P = FunctionSpace(mesh, "P", 1)
dim = mesh.topology().dim()
print('Dim:',dim)
mvc = MeshValueCollection("size_t", mesh, dim-1)
with XDMFFile("facet_mesh.xdmf") as infile:
facet_domains = cpp.mesh.MeshFunctionSizet(mesh, mvc)
bcp_inflow = DirichletBC(P, Constant(8), facet_domains, 6)
bcu_walls = DirichletBC(V, Constant((0, 0, 0)), facet_domains, 8)
bcp_outflow = DirichletBC(P, Constant(0), facet_domains, 7)
bcu = [bcu_walls]
bcp = [bcp_outflow, bcp_inflow]
T = 3.0            # final time
num_steps = 3000   # number of time steps
k  = Constant(dt)
rho = 1
mu = 1
p = TrialFunction(P)
q = TestFunction(P)
u_n = Function(V)
u_  = Function(V)
p_n = Function(P)
p_  = Function(P)
U  = 0.5*(u_n + u)
n  = FacetNormal(mesh)
f_constant  = Constant((0, 0, 0))
# Define symmetric gradient
    return sym(nabla_grad(u))
# Define stress tensor
def sigma(u, p):
    return 2*mu*epsilon(u) - p*Identity(len(u))
# Define variational problem for step 1
F1 = rho*dot((u - u_n) / k, v)*dx \
   + rho*dot(dot(u_n, nabla_grad(u_n)), v)*dx \
   + inner(sigma(U, p_n), epsilon(v))*dx \
   + dot(p_n*n, v)*ds - dot(mu*nabla_grad(U)*n, v)*ds \
   - dot(f_constant, v)*dx
a1 = lhs(F1)
L1 = rhs(F1)
a2 = dot(nabla_grad(p), nabla_grad(q))*dx
L2 = dot(nabla_grad(p_n), nabla_grad(q))*dx - (1/k)*div(u_)*q*dx
a3 = dot(u, v)*dx
L3 = dot(u_, v)*dx - k*dot(nabla_grad(p_ - p_n), v)*dx
print("Go to assemble!")
# Assemble matrices
A1 = assemble(a1)
A2 = assemble(a2)
A3 = assemble(a3)
# Apply boundary conditions to matrices
[bc.apply(A1) for bc in bcu]
[bc.apply(A2) for bc in bcp]
t=0
    b1 = assemble(L1)
    b2 = assemble(L2)
    b3 = assemble(L3)
    error = np.abs(np.array(u_n.vector()) - np.array(u_.vector())).max()
    max_u = np.abs(np.array(u_n.vector()) ).max()
    u_n.assign(u_)
    p_n.assign(p_)
    print('t = %.4f: error = %.6g, max_u = %.6g' % (t, error, max_u))
File("u_n") << u_n
I want to make my solvers run in parallel without splitting the mesh. How i can solve it?
If i use:
mpirun -n 8 python3 3D_tube_script.py
I get this error:
Normal read!
  File "3D_tube_script.py", line 13, in <module>
  File "/usr/local/lib/python3.8/dist-packages/meshio/_helpers.py", line 141, in write
    return writer(filename, mesh, **kwargs)
  File "/usr/local/lib/python3.8/dist-packages/meshio/xdmf/main.py", line 535, in write
    XdmfWriter(*args, **kwargs)
  File "/usr/local/lib/python3.8/dist-packages/meshio/xdmf/main.py", line 346, in __init__
    self.h5_file = h5py.File(self.h5_filename, "w")
  File "/usr/lib/python3/dist-packages/h5py/_hl/files.py", line 406, in __init__
    fid = make_fid(name, mode, userblock_size,
  File "/usr/lib/python3/dist-packages/h5py/_hl/files.py", line 179, in make_fid
    fid = h5f.create(name, h5f.ACC_TRUNC, fapl=fapl, fcpl=fcpl)
  File "h5py/_objects.pyx", line 54, in h5py._objects.with_phil.wrapper
  File "h5py/_objects.pyx", line 55, in h5py._objects.with_phil.wrapper
  File "h5py/h5f.pyx", line 108, in h5py.h5f.create
OSError: Unable to create file (unable to lock file, errno = 11, error message = 'Resource temporarily unavailable')
You should create and read your mesh in serial as neither Gmsh (by default) or meshio supports parallel execution. As reading in xdmf files is supported in parallel, i suggest you split your script into two pieces:
  1. script creating and converting the mesh
  2. one reading it into dolfin and solving the problem of interest.
You could Also spawn Gmsh or meshio on only one rank, as illustrated in:
https://jorgensd.github.io/dolfinx-tutorial/chapter3/subdomains.html#subdomains-defined-from-external-mesh-data
Thank very mach! For script above, I must split:
One part:
    if prune_z:
    return out_mesh
Two part:
mesh = Mesh()
    infile.read(mesh)
                    and on_boundary)
        y[0] = x[0]
        y[1] = x[1]
        y[2] = x[2] - 1
print('Dim:',dim)
bcu = [bcu_walls]
k  = Constant(dt)
rho = 1
mu = 1
q = TestFunction(P)
u_n = Function(V)
u_  = Function(V)
p_n = Function(P)
p_  = Function(P)
U  = 0.5*(u_n + u)
def sigma(u, p):
a1 = lhs(F1)
L1 = rhs(F1)
a3 = dot(u, v)*dx
# Assemble matrices
A1 = assemble(a1)
A2 = assemble(a2)
A3 = assemble(a3)
t=0
    b1 = assemble(L1)
    b2 = assemble(L2)
    b3 = assemble(L3)
    u_n.assign(u_)
    p_n.assign(p_)
File("u_n") << u_n
Did I understand the example correctly?
Yes, that is correct
