Hi, I’m new to Fenics. I have the following equations
\Delta u(x) - \nabla U(x) \cdot \nabla u(x) = 0, x\in \Omega_{ \setminus A\cup B}
u(x) = 0, x\in \partial A, u(x) = 1, x\in \partial B
\nabla u(x) \vec n = 0, x \in \partial \Omega
\Omega = \{x,y:x^2+y^2\leq4\}, A = \{x,y:(x+1)^2+y^2\leq0.5^2\}
B = \{x,y:(x-1)^2+y^2\leq0.5^2\}
And I obtain the variation formulation like this:
0=\int_{\Omega}(\Delta u - \nabla U \cdot \nabla u)e^{-U}v dx = -\int_{\Omega} \nabla u \nabla v e^{-U} dx
After I setting up the problem, the result of u I obtained is quite exploded from what I expected(say u \leq 1 for all x,y)
Here is my code. Could anyone help me figure it out. Many thanks.
from dolfinx.io import gmshio
from gmsh import *
from dolfinx.io import XDMFFile, gmshio
import pyvista
from dolfinx.mesh import CellType, create_rectangle, locate_entities_boundary
from dolfinx.fem import (Constant, dirichletbc, Function, FunctionSpace, locate_dofs_geometrical,
locate_dofs_topological)
from ufl import SpatialCoordinate, TestFunction, TrialFunction, dot, ds, dx, grad, inner
gmsh.clear()
markerId = 1
disk = gmsh.model.occ.addDisk(0, 0, 0, 2, 2)
hole1 = gmsh.model.occ.addDisk(-1, 0, 0, 0.5, 0.5)
hole2 = gmsh.model.occ.addDisk(1, 0, 0, 0.5, 0.5)
membrane1 = gmsh.model.occ.cut([(2, disk)], [(2, hole1), (2,hole2)])
gmsh.model.occ.synchronize()
volumes = gmsh.model.getEntities(dim=2)
gdim = 2
gmsh.model.addPhysicalGroup(volumes[0][0], [volumes[0][1]], 11)
boundary = gmsh.model.getBoundary(membrane1[0], oriented=False)
boundary_ids = [b[1] for b in boundary]
gmsh.model.addPhysicalGroup(2, boundary_ids, tag=1)
meshSize = 0.05
gmsh.option.setNumber("Mesh.CharacteristicLengthMin",meshSize)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax",meshSize)
gmsh_model_rank = 0
mesh_comm = MPI.COMM_WORLD
domain, cell_markers, facet_markers = gmshio.model_to_mesh(gmsh.model, mesh_comm, gmsh_model_rank, gdim=gdim)
def outer(x):
return np.isclose(x[0]**2+x[1]**2, 4)
def inner1(x):
return np.isclose((x[0]+1)**2+x[1]**2, 0.25)
def inner2(x):
return np.isclose((x[0]-1)**2+(x[1])**2, 0.25)
boundary_facets_outer = locate_entities_boundary(domain, domain.topology.dim-1, outer)
boundary_facets_inner1 = locate_entities_boundary(domain, domain.topology.dim-1, inner1)
boundary_facets_inner2 = locate_entities_boundary(domain, domain.topology.dim-1, inner2)
boundary_dofs_outer = locate_dofs_topological(V, domain.topology.dim - 1,boundary_facets_outer)
boundary_dofs_inner1 = locate_dofs_topological(V, domain.topology.dim - 1, boundary_facets_inner1)
boundary_dofs_inner2 = locate_dofs_topological(V, domain.topology.dim - 1, boundary_facets_inner2)
bcs_inner1 = dirichletbc(default_scalar_type(0), boundary_dofs_inner1, V)
bcs_inner2 = dirichletbc(default_scalar_type(1), boundary_dofs_inner2, V)
bcs = [bcs_inner1, bcs_inner2]
V = FunctionSpace(domain, ("Lagrange", 1))
x = SpatialCoordinate(domain)
uD = fem.Function(V)
class MyExpression:
def __init__(self):
self.t = 0.0
def eval(self, x):
return np.full(x.shape[1], np.exp((-x[0]**4)/4 + (x[0]**2)/2 - (x[1]**2)/2))
g = MyExpression()
uD.interpolate(g.eval)
a = dot(grad(u), grad(v))*uD * dx
f = Constant(domain, default_scalar_type(0))
L = f * v * dx
problem = LinearProblem(a, L,bcs=bcs, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
pyvista_cells, cell_types, geometry = vtk_mesh(V)
grid = pyvista.UnstructuredGrid(pyvista_cells, cell_types, geometry)
grid.point_data["u"] = uh.x.array
grid.set_active_scalars("u")
plotter = pyvista.Plotter()
plotter.add_text("uh", position="upper_edge", font_size=14, color="black")
plotter.view_xy()
plotter.show()
