Penalty formulation in Fenics
I am trying to solve a 1D problem with a boundary condition such the u>=0 always.
The sample problem I am trying to solve is
\begin{equation} au_x-\nu u_{xx}= s \, \text{in} \, [0,1] \\ \text{with } s=5e^{-100(x-\frac{1}{8})^2}-5e^{-100(x-\frac{1}{4})^2} \\ u=0 \, \text{at} \, x=0 \,\text{and}\,x=1 \end{equation}
For the given case a=1 ,\nu=0.01
The solution needs an SUPG scheme, and the solution is
In the next step i need to enforce a penalty on this problem such that u>=0 on the domain.
I am trying to solve thos by adding a penalty term to system such that
\begin{equation} au_x-\nu u_{xx} - \zeta*min(u,0)=s \end{equation}
where \zeta is a large number say 10^5.
The corresponding weak form term will be
\int_{\Omega} \zeta*min(u,0)*wd\Omega
However I have tried my best to include this in my code, but nothing seems to work. I am unable to define a function that can be parsed by fenics. Could someone help me on how to define this penalty term?
My code
from ufl import nabla_div
from ufl import *
#import pylab as plt
a = 1.0 # vel coef (1d a vector = scalar)
nu = 0.01 # diff. coef => Pe = 5.0
#Step 1 :Define the unit interval domain
mesh = UnitIntervalMesh(10)
#Step 2: Define the BC
def u0_boundary(x, on_boundary):
    return on_boundary
bc = DirichletBC(V, 0.0, u0_boundary)
#Step 3: Define trial and test function
w = TestFunction(V)
# Step 4: Define the SUPG stabilization tau
#h = mesh.hmin() # uniform mesh
h = CellDiameter(mesh)
Pe = a*h/2.0/nu;
beta = 1.0/tanh(Pe) - 1/Pe
nu2 = beta*a*h/2.0;
tau = nu2/(a*a)
# variational forms
s = Expression('5*exp(-100*(x[0]-1./8)*(x[0]-1./8)) - 5*exp(-100*(x[0]-1./4)*(x[0]-1./4))',degree=10)
a_ = w*dot(a, u.dx(0))*dx + inner(w.dx(0), nu*u.dx(0))*dx
L_ = w*s*dx
# stabilization term
Lu_ = dot(a, u.dx(0)) # linear elem => div(nabla_grad(u)) == 0
Pw_ = dot(a, w.dx(0)) # stabal. operator
# stabilized forms
a_ += tau*Pw_*Lu_*dx
L_ += tau*Pw_*s*dx
#define penalty function
def uneg(x):
    #try3
    val=conditional(ge(x,0),0.0,x)
    #try 2
    #if x>=0.0:
    #    val=0.0
    #else:
    #    val=x
    #try1
    #return (x-abs(x))/2.0 # returns 0 if u is +ve, u if u is negative
    return val # returns 0 if u is +ve, u if u is negative
#uneg(-1)
#uneg(1)
# add penalty constraint
penalty=1.0e5
a_-= w*penalty*uneg(u)*dx
# solve
solve(a_ == L_, u, bc)
fig = plt.figure ( )
ax=plt.subplot(111)
plot(u, label='SUPG')
ax.legend ( )
ax.grid ( True )
The output I get is
    ArityMismatch                             Traceback (most recent call last)
    <ipython-input-86-ce3ff92c8e8e> in <module>
         71 # solve
         72 u = Function(V)
    ---> 73 solve(a_ == L_, u, bc)
         74 fig = plt.figure ( )
         75 ax=plt.subplot(111)
    /usr/local/lib/python3.6/dist-packages/dolfin/fem/solving.py in solve(*args, **kwargs)
        218     # tolerance)
        219     elif isinstance(args[0], ufl.classes.Equation):
    --> 220         _solve_varproblem(*args, **kwargs)
        221
        222     # Default case, just call the wrapped C++ solve function
    /usr/local/lib/python3.6/dist-packages/dolfin/fem/solving.py in _solve_varproblem(*args, **kwargs)
        240         # Create problem
        241         problem = LinearVariationalProblem(eq.lhs, eq.rhs, u, bcs,
    --> 242                                            form_compiler_parameters=form_compiler_parameters)
        243
        244         # Create solver and call solve
    /usr/local/lib/python3.6/dist-packages/dolfin/fem/problem.py in __init__(self, a, L, u, bcs, form_compiler_parameters)
         54         else:
         55             L = Form(L, form_compiler_parameters=form_compiler_parameters)
    ---> 56         a = Form(a, form_compiler_parameters=form_compiler_parameters)
         57
         58         # Initialize C++ base class
    /usr/local/lib/python3.6/dist-packages/dolfin/fem/form.py in __init__(self, form, **kwargs)
         42
         43         ufc_form = ffc_jit(form, form_compiler_parameters=form_compiler_parameters,
    ---> 44                            mpi_comm=mesh.mpi_comm())
         45         ufc_form = cpp.fem.make_ufc_form(ufc_form[0])
         46
    /usr/local/lib/python3.6/dist-packages/dolfin/jit/jit.py in mpi_jit(*args, **kwargs)
         45         # Just call JIT compiler when running in serial
         46         if MPI.size(mpi_comm) == 1:
    ---> 47             return local_jit(*args, **kwargs)
         48
         49         # Default status (0 == ok, 1 == fail)
    /usr/local/lib/python3.6/dist-packages/dolfin/jit/jit.py in ffc_jit(ufl_form, form_compiler_parameters)
         95     p.update(dict(parameters["form_compiler"]))
         96     p.update(form_compiler_parameters or {})
    ---> 97     return ffc.jit(ufl_form, parameters=p)
         98
         99
    /usr/local/lib/python3.6/dist-packages/ffc/jitcompiler.py in jit(ufl_object, parameters, indirect)
        215
        216     # Inspect cache and generate+build if necessary
    --> 217     module = jit_build(ufl_object, module_name, parameters)
        218
        219     # Raise exception on failure to build or import module
    /usr/local/lib/python3.6/dist-packages/ffc/jitcompiler.py in jit_build(ufl_object, module_name, parameters)
        131                                     name=module_name,
        132                                     params=params,
    --> 133                                     generate=jit_generate)
        134     return module
        135
    /usr/local/lib/python3.6/dist-packages/dijitso/jit.py in jit(jitable, name, params, generate, send, receive, wait)
        163         elif generate:
        164             # 1) Generate source code
    --> 165             header, source, dependencies = generate(jitable, name, signature, params["generator"])
        166             # Ensure we got unicode from generate
        167             header = as_unicode(header)
    /usr/local/lib/python3.6/dist-packages/ffc/jitcompiler.py in jit_generate(ufl_object, module_name, signature, parameters)
         64
         65     code_h, code_c, dependent_ufl_objects = compile_object(ufl_object,
    ---> 66             prefix=module_name, parameters=parameters, jit=True)
         67
         68     # Jit compile dependent objects separately,
    /usr/local/lib/python3.6/dist-packages/ffc/compiler.py in compile_form(forms, object_names, prefix, parameters, jit)
        141     """This function generates UFC code for a given UFL form or list of UFL forms."""
        142     return compile_ufl_objects(forms, "form", object_names,
    --> 143                                prefix, parameters, jit)
        144
        145
    /usr/local/lib/python3.6/dist-packages/ffc/compiler.py in compile_ufl_objects(ufl_objects, kind, object_names, prefix, parameters, jit)
        183     # Stage 1: analysis
        184     cpu_time = time()
    --> 185     analysis = analyze_ufl_objects(ufl_objects, kind, parameters)
        186     _print_timing(1, time() - cpu_time)
        187
    /usr/local/lib/python3.6/dist-packages/ffc/analysis.py in analyze_ufl_objects(ufl_objects, kind, parameters)
         88         # Analyze forms
         89         form_datas = tuple(_analyze_form(form, parameters)
    ---> 90                            for form in forms)
         91
         92         # Extract unique elements accross all forms
    /usr/local/lib/python3.6/dist-packages/ffc/analysis.py in <genexpr>(.0)
         88         # Analyze forms
         91
    /usr/local/lib/python3.6/dist-packages/ffc/analysis.py in _analyze_form(form, parameters)
        172                                       do_apply_geometry_lowering=True,
        173                                       preserve_geometry_types=(Jacobian,),
    --> 174                                       do_apply_restrictions=True)
        175     elif r == "tsfc":
        176         try:
    /usr/local/lib/python3.6/dist-packages/ufl/algorithms/compute_form_data.py in compute_form_data(form, do_apply_function_pullbacks, do_apply_integral_scaling, do_apply_geometry_lowering, preserve_geometry_types, do_apply_default_restrictions, do_apply_restrictions, do_estimate_degrees, do_append_everywhere_integrals, complex_mode)
        416         preprocessed_form = remove_complex_nodes(preprocessed_form)
        417
    --> 418     check_form_arity(preprocessed_form, self.original_form.arguments(), complex_mode)  # Currently testing how fast this is
        419
        420     # TODO: This member is used by unit tests, change the tests to
    /usr/local/lib/python3.6/dist-packages/ufl/algorithms/check_arities.py in check_form_arity(form, arguments, complex_mode)
        175 def check_form_arity(form, arguments, complex_mode=False):
        176     for itg in form.integrals():
    --> 177         check_integrand_arity(itg.integrand(), arguments, complex_mode)
    /usr/local/lib/python3.6/dist-packages/ufl/algorithms/check_arities.py in check_integrand_arity(expr, arguments, complex_mode)
        157                              key=lambda x: (x.number(), x.part())))
        158     rules = ArityChecker(arguments)
    --> 159     arg_tuples = map_expr_dag(rules, expr, compress=False)
        160     args = tuple(a[0] for a in arg_tuples)
        161     if args != arguments:
    /usr/local/lib/python3.6/dist-packages/ufl/corealg/map_dag.py in map_expr_dag(function, expression, compress)
         35     Return the result of the final function call.
         36     """
    ---> 37     result, = map_expr_dags(function, [expression], compress=compress)
         38     return result
         39
    /usr/local/lib/python3.6/dist-packages/ufl/corealg/map_dag.py in map_expr_dags(function, expressions, compress)
         82             # Cache miss: Get transformed operands, then apply transformation
         83             if cutoff_types[v._ufl_typecode_]:
    ---> 84                 r = handlers[v._ufl_typecode_](v)
         85             else:
         86                 r = handlers[v._ufl_typecode_](v, *[vcache[u] for u in v.ufl_operands])
    /usr/local/lib/python3.6/dist-packages/ufl/algorithms/check_arities.py in nonlinear_operator(self, o)
         39         for t in traverse_unique_terminals(o):
         40             if t._ufl_typecode_ == Argument._ufl_typecode_:
    ---> 41                 raise ArityMismatch("Applying nonlinear operator {0} to expression depending on form argument {1}.".format(o._ufl_class_.__name__, t))
         42         return self._et
         43
    ArityMismatch: Applying nonlinear operator GE to expression depending on form argument v_1.
Rather than using a penalty approach, I would suggest using the bound constrained TAO solver, see here
Thank you @bleyerj . Is there a 1D example for this type of problem?
