Performance issues using external operators for finite elasto-plasticity
Dear FEniCS community,
for the last couple of months, I’ve been utilizing external operators to implement some material models. I’ve managed to achive great results/performance in the case of hyperelasticity, and small strain elasto-plasticity. The latter one was done in a slightly different algorithmic manner than the referenced example.
My next goal was finite elasto-plasticity. While the routine is working, I’ve noticed a significant drop in performance. I’m aware that the finite elasto-plasticity is more computationally intensive than hyperelasticity or its small strain counterpart, still I find such performance drop off a bit surprising.
I’ve installed FEniCSx via conda-forge. The following is an example of uniaxial tension test of a 3D-Cube, which I use as a benchmark:
# Import modules
import jax
import jax.lax
import jax.numpy as jnp
from jax.scipy.linalg import expm
from dolfinx import fem, mesh
import basix
from dolfinx_external_operator import (
    FEMExternalOperator,
    evaluate_external_operators,
    evaluate_operands,
    replace_external_operators,
from solvers import NonlinearProblemWithCallback
jax.config.update("jax_enable_x64", True)   # Set 64-bit arithmetic in JAX
# Tensor- to Nye-notation and vice versa
def jaxt2n(A, x):
    return jnp.array([A[0,0], A[1,1], A[2,2], x * A[0,1], x * A[0,2], x * A[1,2]])
def jaxn2t(v, x):
    return jnp.array([[v[0], v[3] / x, v[4] / x],
                      [v[3] / x, v[1], v[5] / x],
                      [v[4] / x, v[5] / x, v[2]]])
def uflt2n(A, x):
    return ufl.as_vector([A[0,0], A[1,1], A[2,2], x * A[0,1], x * A[0,2], x * A[1,2]])
def ufln2t(v, x):
    return ufl.as_tensor([[v[0], v[3] / x, v[4] / x],
# A 3-D cube
length = 1.0
width  = 1.0
height = 1.0
N = 5
domain = mesh.create_box(MPI.COMM_WORLD, [[0.0, 0.0, 0.0], [length, width, height]],\
                         [N, N, N], mesh.CellType.hexahedron)
gdim = domain.topology.dim    # Dimension of the body
fdim = gdim - 1               # Dimension of the facets
domain.topology.create_connectivity(fdim, gdim)   # Establish topological connections (needed for boundary conditions)
# Identify the planar boundaries of the cube mesh
def xBot(x):
    return np.isclose(x[0], 0)
def xTop(x):
    return np.isclose(x[0], length)
def yBot(x):
    return np.isclose(x[1], 0)
def yTop(x):
    return np.isclose(x[1], width)
def zBot(x):
    return np.isclose(x[2], 0)
def zTop(x):
    return np.isclose(x[2], height)
boundaries = [(1, xBot),(2,xTop),(3,yBot),(4,yTop),(5,zBot),(6,zTop)]   # Mark the sub-domains
# Build collections of facets on each subdomain and mark them appropriately.
facet_indices, facet_markers = [], []                     # Initalize empty collections of indices and markers.
    facets = mesh.locate_entities(domain, fdim, locator)    # An array of all the facets in a given subdomain ("locator")
    facet_indices.append(facets)                          # Add these facets to the collection.
    facet_markers.append(np.full_like(facets, marker))    # Mark them with the appropriate index.
# Format the facet indices and markers as required for use in dolfinx.
facet_tags = mesh.meshtags(domain, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])  # Add these marked facets as "mesh tags" for later use in BCs.
# Define element formulationd and function spaced
V1e = basix.ufl.element("Lagrange", domain.basix_cell(), 1)                              # For scalars
V3e = basix.ufl.element("Lagrange", domain.basix_cell(), 1, shape=(3,))                  # For vectors
G6e = basix.ufl.quadrature_element(domain.basix_cell(), degree=2, value_shape=(6, ))     # For tensors in Nye-notation (at the quadrature point)
G8e = basix.ufl.quadrature_element(domain.basix_cell(), degree=2, value_shape=(8, ))     # For internal variables (at the quadrature point)
V1 = fem.functionspace(domain, V1e)
V3 = fem.functionspace(domain, V3e)
G6 = fem.functionspace(domain, G6e)
G8 = fem.functionspace(domain, G8e)
u = fem.Function(V3, name="Displacement")
hist = fem.Function(G8, name="History variables")
# Initialize internal variables
init_array = np.array([1.0, 1.0, 1.0, 0.0, 0.0, 0.0, 0.0, 0.0])
num_quadpoints = hist.x.array.size // 8
init_values = np.tile(init_array, num_quadpoints)
hist.x.array[:] = init_values
# Kinematics
Id = ufl.Identity(3)
F = Id + ufl.grad(u)
GLS = 0.5 * (F.T * F - Id)
GLS_nye = uflt2n(GLS, 2)
PK2_nye = FEMExternalOperator(GLS_nye, function_space=G6)   # Declare the second Piola-Kirchhoff stress tensor as an external operator
def psi(RCGe, kappa):
    E  = 200e3   # E-Modulus
    nu = 0.3    # Poisson's ratio
    H  = 0   # Hardening modulus
    lmbda = E * nu / (1 - 2 * nu) / (1 + nu)    # 1st Lame parameter
    mu = E / 2 / (1 + nu)                       # 2nd Lame parameter
    I1 = jnp.trace(RCGe)    # 1st invariant
    I3 = jnp.linalg.det(RCGe)   # 3rd invariant
    psi_e = 0.5 * mu * (I1 - 3 - jnp.log(I3)) + 0.25 * lmbda * (I3 - 1 - jnp.log(I3))   # Elastic part of the free energy
    psi_h = 0.5 * H * kappa**2  # Hardening part of the free energy
    return psi_e + psi_h
dpsidRCGe = jax.grad(psi, argnums=0)
dpsidkappa = jax.grad(psi, argnums=1)
def Phi(Y, R):
    sigy_0 = 300    # Initial yield stress
    devY = Y - jnp.trace(Y) / 3 * jnp.identity(3)    # Deviatoric part of the plastic driving force
    Phi = jnp.sqrt(3 / 2) * jnp.linalg.norm(devY, ord='fro') - (sigy_0 + R)    # Von Mises yield criterion/function
    return Phi
dPhidY = jax.grad(Phi, argnums=0)
dPhidR = jax.grad(Phi, argnums=1)
# Local residuum
def r(L, hist_old, RCG):
    Up_n_nye = hist_old[:6]
    kappa_n = hist_old[6]
    Up_nye = L[:6]
    kappa = L[6]
    dlambda = L[7]
    Up = jaxn2t(Up_nye, 2)
    Up_n = jaxn2t(Up_n_nye, 2)
    invUp = jnp.linalg.inv(Up) #precompute_inverses(Up)
    invUp_n = jnp.linalg.inv(Up_n) #precompute_inverses(Up_n)
    RCGe = invUp @ RCG @ invUp
    dpsidRCGe_ = dpsidRCGe(RCGe, kappa)
    PK2 = 2.0 * invUp @ dpsidRCGe_ @ invUp
    Y = 2.0 * RCGe @ dpsidRCGe_
    R = dpsidkappa(RCGe, kappa)
    Z = 2.0 * dlambda * dPhidY(Y, R)
    res_Phi = Phi(Y, R)
    res_Up = invUp @ expm(Z) @ invUp - invUp_n @ invUp_n
    res_Up_nye = jaxt2n(res_Up, 1)
    res_kappa = kappa_n - kappa - dlambda * dPhidR(Y, R)
    res = jnp.concatenate((res_Phi.reshape(1), res_Up_nye, res_kappa.reshape(1)))
    return res, PK2
drdL = jax.jacfwd(r)    # Local jacobian
TOL = 1.0e-8     # Tolerance for local Newton scheme
NITER_MAX = 25   # Maximal number of local Newton iterations
def PK2_local(GLS_nye, hist_old):
    Core function. Performs the return-mapping
    algorithm on a Gauss-Point level. Takes the
    Green-Lagrange strain tensor and the history
    variables from the previos time step as inputs
    and calulates the 2nd Piola-Kirchoff stress
    tensors and the new history variables, alongside
    some additional control parameters.
    Up_n_nye = hist_old[:6]    # Plastic stretch from previous time step
    kappa_n = hist_old[6]      # Accumulated plastic strain from previous time step
    GLS = jaxn2t(GLS_nye, 2)
    RCG = 2.0 * GLS + jnp.identity(3)
    invUp_n = jnp.linalg.inv(Up_n) # precompute_inverses(Up_n)
    # Trial step
    RCGe_trial = invUp_n @ RCG @ invUp_n
    dpsidRCGe_trial = dpsidRCGe(RCGe_trial, kappa_n)
    PK2_trial = 2.0 * invUp_n @ dpsidRCGe_trial @ invUp_n
    Y_trial = 2.0 * RCGe_trial @ dpsidRCGe_trial
    R_trial = dpsidkappa(RCGe_trial, kappa_n)
    Phi_trial = Phi(Y_trial, R_trial)
    state_cond_initial = (PK2_trial, hist_old, RCG)
    def elastic_step(state_cond):
        return state_cond[0], state_cond[1]
    def plastic_step(state_cond_n):
        hist_old = state_cond_n[1]
        RCG = state_cond_n[2]
        L0 = hist_old.at[7].set(0.0)    # Initial local solution vector
        niter = 0             # Initiate counter
        res_0, PK2_0 = r(L0, hist_old, RCG)
        norm_res_0 = jnp.linalg.norm(res_0)
        state_loop_initial = {"iteration_number": niter,
                              "intvar_current": L0,
                              "intvar_previous": hist_old,
                              "residuum_norm": norm_res_0,
                              "residuum": res_0,
                              "stress": PK2_0,
                              "deformation": RCG}
        def cond_fun(state_loop):
            norm_res = state_loop["residuum_norm"]
            niter = state_loop["iteration_number"]
            return jnp.logical_and(norm_res > TOL, niter < NITER_MAX)
        def body_fun(state_loop_n):
            niter = state_loop_n["iteration_number"]
            res_n = state_loop_n["residuum"]
            norm_res = state_loop_n["residuum_norm"]
            Ln = state_loop_n["intvar_current"]
            h0 = state_loop_n["intvar_previous"]
            RCG = state_loop_n["deformation"]
            j = drdL(Ln, h0, RCG)[0]
            dL = jnp.linalg.solve(j, -res_n)
            L = Ln + dL
            res, PK2 = r(L, h0, RCG)
            norm_res = jnp.linalg.norm(res)
            niter += 1
            state_loop = {"iteration_number": niter,
                          "intvar_current": L,
                          "intvar_previous": h0,
                          "residuum_norm": norm_res,
                          "residuum": res,
                          "stress": PK2,
                          "deformation": RCG}
            return state_loop
        state_loop_final = jax.lax.while_loop(cond_fun, body_fun, state_loop_initial)
        PK2 = state_loop_final["stress"]
        h1 = state_loop_final["intvar_current"]
        return PK2, h1
    PK2, h1 = jax.lax.cond(Phi_trial <= TOL, elastic_step, plastic_step, state_cond_initial)
    return jaxt2n(PK2, 1), h1
dPK2dGLS_local = jax.jacfwd(PK2_local, has_aux=True)    # Material tangent
PK2_global = jax.jit(jax.vmap(PK2_local, in_axes=(0, 0)))   # Global stress values
dPK2dGLS_global = jax.jit(jax.vmap(dPK2dGLS_local, in_axes=(0, 0)))   # Global material tangent
def exof_stress(GLS):
    GLS_ = GLS.reshape((-1, 6))
    hist_ = hist.x.array[:].reshape((-1, 8))
    PK2_, _ = PK2_global(GLS_, hist_)
    return PK2_.reshape(-1)
def exof_tangent(GLS):
    dPK2dGLS_, hist_new = dPK2dGLS_global(GLS_, hist_)
    return dPK2dGLS_.reshape(-1), hist_new.reshape(-1)
def PK2_external(derivatives):
    if derivatives == (0,):
        return exof_stress
    elif derivatives == (1,):
        return exof_tangent
        return NotImplementedError
PK2_nye.external_function = PK2_external
dx = ufl.Measure('dx', domain=domain, metadata={'quadrature_degree': 2, 'quadrature_rule':'default'})   # Volume integration measure
v = ufl.TestFunction(V3)
virtGLS = ufl.sym(F.T * ufl.grad(v))
virtGLS_nye = uflt2n(virtGLS, 2)
du = ufl.TrialFunction(V3)
R = ufl.inner(PK2_nye, virtGLS_nye) * dx   # Residuum
J = ufl.derivative(R, u, du)           # Jacobian
J_expanded = ufl.algorithms.expand_derivatives(J)
R_replaced, R_external_operators = replace_external_operators(R)
J_replaced, J_external_operators = replace_external_operators(J_expanded)
R_form = fem.form(R_replaced)
J_form = fem.form(J_replaced)
# Find the specific constrained DOFs
xBot_ux_dofs = fem.locate_dofs_topological(V3.sub(0), facet_tags.dim, facet_tags.find(1))
yBot_uy_dofs = fem.locate_dofs_topological(V3.sub(1), facet_tags.dim, facet_tags.find(3))
zBot_uz_dofs = fem.locate_dofs_topological(V3.sub(2), facet_tags.dim, facet_tags.find(5))
xTop_ux_dofs = fem.locate_dofs_topological(V3.sub(0), facet_tags.dim, facet_tags.find(2))
ux_disp = fem.Constant(domain, 0.0) # Initialize displacements of xTop facet
bcs_1 = fem.dirichletbc(0.0, xBot_ux_dofs, V3.sub(0))      # ux fix - xBot
bcs_2 = fem.dirichletbc(0.0, yBot_uy_dofs, V3.sub(1))      # uy fix - yBot
bcs_3 = fem.dirichletbc(0.0, zBot_uz_dofs, V3.sub(2))      # uz fix - zBot
bcs_4 = fem.dirichletbc(ux_disp, xTop_ux_dofs, V3.sub(0))  # ux disp - xTop
bcs = [bcs_1, bcs_2, bcs_3, bcs_4]
# Callback function for updating the external operators in the Newton-loop
def constitutive_update():
    evaluated_operands = evaluate_operands(J_external_operators)
    PK2_coeff, _ = evaluate_external_operators(J_external_operators, evaluated_operands)
    PK2_nye.ref_coefficient.x.array[:] = PK2_coeff
# Set up the problem and initialize the solver
problem = NonlinearProblemWithCallback(R_replaced, u, bcs=bcs, J=J_replaced, external_callback=constitutive_update)
# Global Newton-Raphson solver and its options
solver = NewtonSolver(domain.comm, problem)
solver.max_it = 200
solver.rtol = 1e-8
ksp = solver.krylov_solver
opts = PETSc.Options()  # type: ignore
ksp.setFromOptions()
ux_disp_max = 0.05   # Maximum displacements of x-Top facet
Nsteps = 100         # Number of loading steps
u.x.array[:] = np.finfo(PETSc.ScalarType).eps   # Initial displacements
# Loading loop
for n, disp in enumerate(np.linspace(0, ux_disp_max, Nsteps + 1)[1:]):
    ux_disp.value = disp  # Apply displacement
    num_its, converged = solver.solve(u)  # Solve the problem
    assert converged
    print(f"Time step {n}, Displacement {disp}, Number of iterations {num_its} .")
    u.x.scatter_forward()  # Update ghost values (parallel computing)
    # Extract history values
    _, (_, hist_coeff) = evaluate_external_operators(J_external_operators, evaluated_operands)
    hist.x.array[:] = hist_coeff  # Update history variables
As mentioned previously, the routine produces valid results (deformed shape, stress response, evolution of internal variables, local convergenve etc.). The core of the performance issues might lie in how I structure/utilize the JAX functions. Still, I would like to rule out other potential issues which I might be missing. If someone is profficient in JAX, or has stumbled upon similiar performance issues using external operators, I would really appriciate your help. Please let me know if I should provide further crucial information.
Best regards
Nadir
@a-latyshev maybe you have some ideas ?:slight_smile:
Hi, I suspect that the issue is due to the derivation of the material tangent via direct automatic differentiation of the Newton solver in the plastic step.
I suggest to look at the approach proposed in dolfinx_materials such as the Finite-strain \(\boldsymbol{F}^\text{e}\boldsymbol{F}^\text{p}\) plasticity — dolfinx_materials
It is not yet implemented with external operators but shares a similar implementation. The main difference is that we define a custom JVP rule for the Newton solver using implicit differentiation rather than AD of unrolled Newton iterations, see also https://bleyerj.github.io/teaching/Bleyer_advanced_computational_methods_2025.pdf slides 41 to 45
Dear @Nadir.Kopic
@bleyerj is right! It looks like passing AD through the Newton loop is quite expensive. Using the implicit function theorem (IFT) will improve performance.
Actually, there is an implementation of the Mohr-Coulomb tutorial, where we apply IFT and indeed obtain a better performance. You may find this implementation in supplementary materials to the paper on external operators (see appendix A.1), which will be published soon in JTCAM. In supplementary materials, you need to find the file demo_plasticity_mohr_coulomb_mpi.py, which contains this more advanced implementation with IFT.
Since you are familiar with our tutorials on external operators, it will be very straightforward for you to understand the script.
Essentially, you need these lines of code
def C_tang_local(sigma_local, dlambda_local, deps_local, sigma_n_local):
    # implicit function theorem and automatic differentiation:
    # http://implicit-layers-tutorial.org/implicit_functions/
    y_local = jnp.c_["0,1,-1", sigma_local, dlambda_local]
    j = drdy(y_local, deps_local, sigma_n_local)
    return jnp.linalg.inv(j)[:4,:4] @ C_elas
return_mapping_vec = jax.jit(jax.vmap(return_mapping, in_axes=(0, 0)))
C_tang_vec = jax.jit(jax.vmap(C_tang_local, in_axes=(0, 0, 0, 0)))
def C_tang_impl(deps):
    deps_ = deps.reshape((-1, stress_dim))
    sigma_n_ = sigma_n.x.array.reshape((-1, stress_dim))
    (sigam_global, state) = return_mapping_vec(deps_, sigma_n_)
    sigma_global, niter, yielding, norm_res, dlambda = state
    C_tang_global = C_tang_vec(sigma_global, dlambda, deps_, sigma_n_)
    unique_iters, counts = jnp.unique(niter, return_counts=True)
    max_yielding = jnp.max(yielding)
    max_yielding_rank = MPI.COMM_WORLD.allreduce((max_yielding, MPI.COMM_WORLD.rank), op=MPI.MAXLOC)[1]
    if MPI.COMM_WORLD.rank == max_yielding_rank:
        print("\tInner Newton summary:", flush=True)
        print(f"\t\tUnique number of iterations: {unique_iters}", flush=True)
        print(f"\t\tCounts of unique number of iterations: {counts}", flush=True)
        print(f"\t\tMaximum f: {max_yielding}", flush=True)
        print(f"\t\tMaximum residual: {jnp.max(norm_res)}", flush=True)
    return C_tang_global.reshape(-1), sigma_global.reshape(-1)
that replace the code from the original tutorials, where we apply AD to the Newton algorithm:
dsigma_ddeps = jax.jacfwd(return_mapping, has_aux=True)
Consider applying IFT to your dPK2dGLS_local.
I hope this information will help you improve performance. :slightly_smiling_face:
Cheers,
Andrey
I have an additional remark on your implementation concerning the use of NonlinearProblemWithCallback.
The function constitutive_update will be called on every iteration of the Newton solver, or more explicitly, on this line
The motivation behind the classes NonlinearProblemWithCallback and PETScNonlinearProblem is that we want to make additional computations on every iteration. For example, updating the history variables which is the case of nonlinear solid mechanics problems (see how we update cumulative plastic strain increment dp in the von Mises tutorial).
In this regard, are you sure that you don’t need to update your history variables in the constitutive_update function?
Another remark, in your code
normally evaluate_external_operators(J_external_operators, evaluated_operands) returns the output of the exof_tangent function, the first output of which is values of the derivative dPK2dGLS_. So basically, you do PK2_nye.ref_coefficient.x.array[:] = dPK2dGLS_.reshape(-1), which is not supposed to be correct.
Probably, it is not clear, but in the plasticity tutorials, to get the derivative of the external operator, we have to pass through the return-mapping procedure that results in computing the external operator itself. That’s why, to save numerical resources, the external function returns values for both the external operator and its derivatives (e.g. like here Plasticity of Mohr-Coulomb with apex-smoothing — External operators within FEniCSx/DOLFINx).
At the same time, the first argument of the external function is the values of an appropriate external operator, and they will be used automatically by the algorithm via evaluate_external_operators, which is why we typically ignore this output in our code.
After saying this, I’d change your actual code so that PK2_local should return jaxt2n(PK2, 1) twice and then you have to catch those values throughout the rest of your code (and you don’t need exof_stress). Basically, you have to reproduce the same structure of the code as in the Mohr-Coulomb tutorial. Please, take a look at it again and track how we manipulate the data throughout the code.
Hi everyone,
@bleyerj utilizing implicit differentiation improved the performance massively. I was familiar with the method, but didn’t expect it would have such a huge impact on the performance. Thank you for highlighting it!
@a-latyshev Thank you for the additional implementation example! Regarding your questions.
I don’t think it’s necessary to update the history variables for each global newton iteration. I do it once the global residuum has converged. I didn’t experience any convergence issues (local and global) in any simulations I ran. The reason could be on how we treat the history part of our models. While you consider a rate formulation of the constitutive law in your examples, I declare the plastic stretch as a history variable and proceed to formulate the constitutive relationships in a more conventional way. Still, I might be wrong. I will take a more detailed look into the literature in the near future :smiley: .
Regarding your second suggestion, I have already tried this with hyperelasticity, yet errors occurred. Here is how I did it:
import jax
import jax.lax
import basix
    evaluate_operands,
def jaxt2n(A, x):
def jaxn2t(v, x):
length = 1.0
width  = 1.0
height = 1.0
N = 10
fdim = gdim - 1
def xBot(x):
def xTop(x):
def yBot(x):
def yTop(x):
def zBot(x):
def zTop(x):
V3 = basix.ufl.element("Lagrange", domain.basix_cell(), 1, shape=(3,))
T3 = basix.ufl.quadrature_element(domain.basix_cell(), degree=2, value_shape=(6,))
V  = fem.functionspace(domain, V3)
T  = fem.functionspace(domain, T3)
u = fem.Function(V, name="Displacement")
RCG = F.T * F
GLS = 0.5 * (RCG - Id)
GLS_nye = ufl.as_vector([GLS[0,0], GLS[1,1], GLS[2,2], 2.0 * GLS[0,1], 2.0 * GLS[0,2], 2.0 * GLS[1,2]])
PK2 = FEMExternalOperator(GLS_nye, function_space=T)
def psi_local(GLS_nye):
    E = 200e3
    nu = 0.3
    Id = jnp.identity(3)
    RCG = 2.0 * GLS + Id
    I1 = jnp.trace(RCG)
    I3 = jnp.linalg.det(RCG)
    return mu / 2 * (I1 - 3 - jnp.log(I3)) + lmbda / 4 * (I3 - 1 - jnp.log(I3))
def PK2_local(GLS_nye):
    return jax.grad(psi_local)(GLS_nye), jax.grad(psi_local)(GLS_nye)
PK2_global = jax.jit(jax.vmap(PK2_local, in_axes=0))
dPK2dGLS_global = jax.jit(jax.vmap(dPK2dGLS_local, in_axes=0))
def exof_tangent(GLS_glo):
    GLS_ = GLS_glo.reshape((-1, 6))
    dPK2dGLS_, PK2_ = dPK2dGLS_global(GLS_)
    return dPK2dGLS_.reshape(-1), PK2_.reshape(-1)
        return exof_tangent
PK2.external_function = PK2_external
virGLS = ufl.sym(F.T * ufl.grad(v))
virGLS_nye = ufl.as_vector([virGLS[0,0], virGLS[1,1], virGLS[2,2], 2.0 * virGLS[0,1], 2.0 * virGLS[0,2], 2.0 * virGLS[1,2]])
du = ufl.TrialFunction(V)
R = ufl.inner(PK2, virGLS_nye) * dx
xBot_ux_dofs = fem.locate_dofs_topological(V.sub(0), facet_tags.dim, facet_tags.find(1))
yBot_uy_dofs = fem.locate_dofs_topological(V.sub(1), facet_tags.dim, facet_tags.find(3))
zBot_uz_dofs = fem.locate_dofs_topological(V.sub(2), facet_tags.dim, facet_tags.find(5))
xTop_ux_dofs = fem.locate_dofs_topological(V.sub(0), facet_tags.dim, facet_tags.find(2))
bcs_1 = fem.dirichletbc(0.0, xBot_ux_dofs, V.sub(0))
bcs_2 = fem.dirichletbc(0.0, yBot_uy_dofs, V.sub(1))
bcs_3 = fem.dirichletbc(0.0, zBot_uz_dofs, V.sub(2))
bcs_4 = fem.dirichletbc(ux_disp, xTop_ux_dofs, V.sub(0))
    ((_, PK2_coeff), ) = evaluate_external_operators(J_external_operators, evaluated_operands)
    PK2.ref_coefficient.x.array[:] = PK2_coeff
solver.max_it = 200
solver.rtol = 1e-8
ux_disp_max = 0.1
Nsteps = 100
# Loading loop
    assert converged
    print(f"Time step {n}, Displacement {disp}, Number od iterations {num_its} .")
This is the error message I get:
  File "/home/nadir/FEM/cam-fenicsx/elasticity/singelem_hypelas_exo_batched.py", line 210, in <module>
  File "/home/nadir/miniconda3/envs/fenicsx-envnew/lib/python3.13/site-packages/dolfinx/nls/petsc.py", line 51, in solve
    n, converged = super().solve(u.x.petsc_vec)
  File "/home/nadir/FEM/cam-fenicsx/elasticity/solvers.py", line 113, in form
    self.external_callback()
  File "/home/nadir/FEM/cam-fenicsx/elasticity/singelem_hypelas_exo_batched.py", line 181, in constitutive_update
  File "/home/nadir/dolfinx-external-operator/src/dolfinx_external_operator/external_operator.py", line 169, in evaluate_external_operators
    np.copyto(external_operator.ref_coefficient.x.array, external_operator_eval)
TypeError: Cannot cast scalar from dtype('O') to dtype('float64') according to the rule 'same_kind'
The same approach worked for small-strain elasticity. Could it be due to the non-linearity of the operand? We already discussed this once. Your suggestion was to define separate functions for the stress and tangent.
Best regards
Nadir
Dear @Nadir.Kopic
The issue arises due to the presence of two external operators in the J_external_operators list: the operator itself and its derivative. However, you’ve only provided the external function for the derivative.
You have two options:
  1. Return to the previous implementation, where you defined exof_stress for the multi-index (0,).
  2. Or, since that approach is more expensive, you can try the following trick: evaluate only the derivative of the external operator and then explicitly update the values of the original operator using the result. For example:
    dPK2dGLS = [J_external_operators[1]]
    evaluated_operands = evaluate_operands(dPK2dGLS)
    ((_, PK2_coeff), ) = evaluate_external_operators(dPK2dGLS, evaluated_operands)
To identify which element in the list is the derivative, you can check the derivatives attribute like so:
for ex_op in J_external_operators:
    if ex_op.derivatives == (1,):
        dPK2dGLS = ex_op
P.S.
The error TypeError: Cannot cast scalar from dtype('O') to dtype('float64') according to the rule 'same_kind' is related to improper use of NotImplementedError :slight_smile:
To prevent similar issues in the future, raise the error explicitly:
        return exof_tangent
        raise NotImplementedError(f'There is no external function for the derivative {derivatives}.')
I will also update our tutorials accordingly :upside_down_face:
Dear Andrey,
thanks for the detailed explanation. I tried the second approach, and even tho it worked, it resulted in a worse convergence in some cases.
For single elements test, like uniaxial tension, there was no difference to my previous implementation. For more complex loading, like this example, the convergence got much worse. It jumped from 5-6 iterations per loading step, to 10-13.
Here is the adjusted code for the torsion example:
import jax
import basix
    evaluate_operands,
# Auxilliary functions
def jaxt2n(A, x):
def jaxn2t(v, x):
output_dir = utly.path.set_up_output()
utly.log.set_up(output_dir)
# A 3-D cube
length = 0.5
width  = 0.5
height = 3.0
N = 8
domain = mesh.create_box(MPI.COMM_WORLD, [[-0.5, -0.5, 0.0], [length, width, height]],
                         [N, N, 4*N], mesh.CellType.hexahedron)
# Define element formulation and function space
S1 = basix.ufl.element("Lagrange", domain.basix_cell(), 1)                              # For scalars
V3 = basix.ufl.element("Lagrange", domain.basix_cell(), 1, shape=(3,))                  # For vectors
T3 = basix.ufl.quadrature_element(domain.basix_cell(), degree=2, value_shape=(6,))      # For tensors (Nye notation)
S  = fem.functionspace(domain, S1)
u = fem.Function(V, name="Displacement")    # Define displacements - solution vector
stretch_11 = fem.Function(S, name="Stretch")
stretch_11_expr = fem.Expression(F[0, 0], S.element.interpolation_points())
RCG = F.T * F
PK2 = FEMExternalOperator(GLS_nye, function_space=T)     # Declare the second Piola-Kirchhoff stress tensor as an external operator
    E = 200e3                                   # E-Modulus (MPa)
    lmbda = E * nu / (1 - 2 * nu) / (1 + nu)    # 1st Lame constant
    mu = E / 2 / (1 + nu)                       # 2nd Lame constant
    I1 = jnp.trace(RCG)
    psi = mu / 2 * (I1 - 3 - jnp.log(I3)) + lmbda / 4 * (I3 - 1 - jnp.log(I3))
    return psi
PK2_local = jax.grad(psi_local)
dPK2dGLS_local = jax.jacfwd(PK2_local)
        return exof
def bottom(x):
    return np.isclose(x[2], 0.0)
def top(x):
bottom_dofs = fem.locate_dofs_geometrical(V, bottom)
top_dofs = fem.locate_dofs_geometrical(V, top)
u_bot = fem.Function(V)
u_top = fem.Function(V)
bcs = [fem.dirichletbc(u_bot, bottom_dofs), fem.dirichletbc(u_top, top_dofs)]
theta = fem.Constant(domain, 0.0)
Rot = ufl.as_matrix([[ufl.cos(theta), ufl.sin(theta), 0], [-ufl.sin(theta), ufl.cos(theta), 0], [0, 0, 1]])
rotation_displ = ufl.dot(Rot, x) - x
rot_expr = fem.Expression(rotation_displ, V.element.interpolation_points())
solver.max_it = 200
solver.rtol = 1e-8
angle_max = 2 * np.pi
Nsteps = 100
out_file = "results/structure_torsion_exo.xdmf"
with io.XDMFFile(domain.comm, out_file, "w") as xdmf:
    xdmf.write_mesh(domain)
for n, angle in enumerate(np.linspace(0, angle_max, Nsteps + 1)[1:]):
    theta.value = angle
    u_top.interpolate(rot_expr)
    assert converged
    print(
        f"Time step {n}, Number of iterations {num_its}, Angle {angle*180/np.pi:.0f} deg."
    with io.XDMFFile(domain.comm, out_file, "a") as xdmf:
        xdmf.write_function(u, n + 1)
Any Idea what could be the reason behind the worse convergence?.
Best regards
Nadir
Dear @Nadir.Kopic,
First of all, my apologies for the late reply.
I couldn’t run your code snippet directly, as it would require additional setup to properly configure the external operators. However, here are some thoughts on why using external operators might lead to worse convergence:
  1. Consider experimenting with the degree of your finite elements. In the hyperelasticity example you mentioned, it’s noted:
“Now, we define the global non-linear potential energy. Note that since we have non-linear expressions, we specify to the measure dx the desired level of accuracy of the quadrature method. Otherwise, FEniCS may use overly conservative estimates of the required number of quadrature points.”
In your snippet, external operators are defined on quadrature spaces of degree 2:
It’s possible that your problem requires a higher quadrature degree.
  1. Are you using an appropriate linear solver and preconditioner for your problem? These choices can greatly impact convergence. For instance, if you’re running in serial mode, you might consider disabling MUMPS. Tuning solver parameters can make a significant difference.
  2. In general, I would not expect exactly the same convergence/precision when using external operators compared to purely symbolic formulations. External operators involve extra computational steps, like their updates, which can slightly affect numerical precision, but again, this depends on how the user implements the external operator behaviour. For example, in our von Mises plasticity example, the external operator version required 7 Newton iterations, whereas the symbolic UFL implementation needed only 4. Potentially, playing with the solver parameters, elements degree and the implementation itself could help to improve the overall performance.
I hope these suggestions are helpful. Please feel free to reach out if you have further questions—I’d be happy to help.
