Simple periodic boundary condition without dolfinx_mpc
I’m new to DolfinX (using the 0.6.0 version), and I wanted to implement a very simple case of Poisson equation with Dirichlet BC on the vertical walls (x=0 and x=1), and with periodic BC on horizontal walls (y=0 and y=1).
Unfortunately I didn’t find anything in the documentation to solve this kind of problem. I saw the dolfinx_mpc library, however it seems to be overpowered in my case.
So I wanted to know if there is an alternative simple and straightforward way to just map my top boundary to the bottom one, as I have a very simple grid.
Here is my code so far (if needed) working for the Dirichlet BC on vertical walls :
## Create a simple rectangle mesh
# define geometric and mesh parameters
Lx = 1.0
Ly = 1.0
n_x = 64
n_y = 64
# create the mesh
msh = mesh.create_rectangle(comm=MPI.COMM_WORLD,
                            points=((0.0, 0.0), (Lx, Ly)), n=(n_x, n_y),
                            cell_type=mesh.CellType.triangle,)
V = fem.FunctionSpace(msh, ("Lagrange", 1))
## Define boundaries
v_facets = mesh.locate_entities_boundary(msh, dim=1,
                                                marker=lambda x: np.logical_or(np.isclose(x[0], 0.0),
        np.isclose(x[0], Lx)))
dofs_v = fem.locate_dofs_topological(V=V, entity_dim=1, entities=v_facets)
Dbc = fem.dirichletbc(value=ScalarType(0), dofs=dofs_v, V=V)
bc = [Dbc]
## Define the variational problem
u = ufl.TrialFunction(V)
f = 10 * ufl.exp(-((x[0] - 0.5) ** 2 + (x[1] - 0.5) ** 2) / 0.02)
g = ufl.sin(5 * x[0])
L = inner(f, v) * dx + inner(g, v) * ds
## Assemble matrix and vector, applying the boundary conditions
A = fem.petsc.assemble_matrix(fem.form(a), bcs=bc)
b = fem.petsc.assemble_vector(fem.form(L))
fem.petsc.apply_lifting(b, [fem.form(a)], bcs=[bc])
b.assemble()
fem.petsc.set_bc(b, bcs=bc)
## Setup solver
u_sol = fem.Function(V)
solver = PETSc.KSP().create(msh.comm)
solver.setOperators(A)
solver.solve(b, u_sol.vector)
u_sol.vector.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
Consider the following workaround (works in serial):
