Periodic boundary conditions implemented on non-straight Facets in a geometry
In the following geometry, I wish to define periodic boundary conditions on the left and right boundary for a linear elasticity analysis. However, I have hard time implementing it. I have defined the left and right boundary with facet tags. While implementing I get error.
gmsh.model.add("Winding Pack-1")
gdim = 2
mesh_comm = MPI.COMM_WORLD
model_rank = 0
h = 1
lc = 1e-3
# Added Points in the geometry
gmsh.model.geo.addPoint(0,0,0,lc,1)
gmsh.model.geo.addPoint(1,0,0,lc,2)
gmsh.model.geo.addPoint(1.5,1,0,lc,3)
gmsh.model.geo.addPoint(-0.5,1,0,lc,4)
#gmsh.model.geo.addPoint(0.3,0.3,0,lc,5)
#gmsh.model.geo.addPoint(0.7,0.3,0,lc,6)
#gmsh.model.geo.addPoint(0.7,0.6,0,lc,7)
#gmsh.model.geo.addPoint(0.3,0.6,0,lc,8)
# Added Lines in the geometry
gmsh.model.geo.addLine(1,2,1)
gmsh.model.geo.addLine(2,3,2)
gmsh.model.geo.addLine(3,4,3)
gmsh.model.geo.addLine(4,1,4)
#gmsh.model.geo.addLine(5,6,5)
#gmsh.model.geo.addLine(6,7,6)
#gmsh.model.geo.addLine(7,8,7)
#gmsh.model.geo.addLine(8,5,8)
gmsh.model.geo.addCurveLoop([1,2,3,4],1)
gmsh.model.geo.addPlaneSurface([1],1)
gmsh.model.geo.synchronize()
gmsh.model.addPhysicalGroup(1, [1], name="bottom")
gmsh.model.addPhysicalGroup(1, [2], name="right")
gmsh.model.addPhysicalGroup(1, [3], name="top")
gmsh.model.addPhysicalGroup(1, [4], name="left")
gmsh.model.addPhysicalGroup(2, [1], name="my_surface")
gmsh.option.setNumber("Mesh.CharacteristicLengthMin", h)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", h)
domain, cell_markers, facet_markers = gmshio.model_to_mesh(gmsh.model, mesh_comm, model_rank, gdim=gdim)
#facet_markers.name = "Facet markers"
gmsh.write("Winding Pack-1.msh")
gmsh.fltk.run()
gmsh.finalize()
def strain(u, repr ="vectorial"):
    eps_t = sym(grad(u))
    if repr =="vectorial":
        return as_vector([eps_t[0,0], eps_t[1,1], 2*eps_t[0,1]])
    elif repr =="tensorial":
        return eps_t
E = fem.Constant(domain, 200000000000.0)
nu = fem.Constant(domain,0.3)
lmbda = E*nu/(1+nu)/(1-2*nu)
mu = E/2/(1+nu)
C = as_matrix([[lmbda+2*mu, lmbda, 0.0],[lmbda, lmbda+2*mu,  0.0],[0.0, 0.0, mu]])
def stress(u, repr ="vectorial"):
    sigv = dot(C, strain(u))
        return sigv
        return as_matrix([[sigv[0], sigv[2]], [sigv[2], sigv[1]]])
# Define Function Space
degree = 2
V = fem.functionspace(domain, ("P",degree, (gdim,)))
#Define Variational Problem
du = TrialFunction(V)
u_ = TestFunction(V)
u = fem.Function(V, name = "Displacement")
a_form = inner(stress(du),strain(u_))*dx
# Applying a uniform pressure
#rho = 7850
#g = 9.81
T = fem.Constant(domain, 1000000.0)
#fg = fem.Constant(domain, np.array([0, -rho*g]))
#fg = fem.Constant(domain, 78500.0)
#Self-weight on the surface
n = FacetNormal(domain)
#L_form = dot(-fp*n,u_) * ds(5) + dot(fg*n,u_) * ds(5)
ds = ufl.Measure("ds", domain=domain, subdomain_data=facet_markers)
L_form = dot(T*n,u_) * ds(3)
#L_form = dot(-T*n,u_) * ds(5) + dot(fg*n,u_) * ds(5)
#Boundary Conditions (simply supported on top and bottom edges)
V_ux, _ = V.sub(0).collapse()
V_uy, _ = V.sub(1).collapse()
bottom_dofs = fem.locate_dofs_topological((V.sub(1), V_uy), gdim-1, facet_markers.find(1))
top_dofs = fem.locate_dofs_topological((V.sub(1), V_uy), gdim-1, facet_markers.find(3))
left_dofs = fem.locate_dofs_topological((V.sub(0), V_ux), gdim-1, facet_markers.find(4))
right_dofs = fem.locate_dofs_topological((V.sub(0), V_ux), gdim-1, facet_markers.find(2))
ux0 = fem.Function(V_ux)
uy0 = fem.Function(V_uy)
#bcs = [fem.dirichletbc(uy0, bottom_dofs, V.sub(1)),fem.dirichletbc(ux0, left_dofs, V.sub(0)),fem.dirichletbc(uy0, top_dofs, V.sub(1)), fem.dirichletbc(ux0, right_dofs, V.sub(0))]
bcs = [fem.dirichletbc(uy0, bottom_dofs, V.sub(1))]
#bcs = [fem.dirichletbc(uy0, bottom_dofs, V.sub(1)),fem.dirichletbc(ux0, left_dofs, V.sub(0))]
periodic_boundary = facet_markers.find(2)
#Cyclic Symmetry Condition
def periodic_relation(x):
    out_x = np.zeros(x.shape)
    out_x[0] = 1 - x[0]
    out_x[1] = x[1]
    out_x[2] = x[2]
    return out_x
# Periodic boundary - topological
facets = mesh.locate_entities_boundary(domain, gdim - 1, periodic_boundary)
arg_sort = np.argsort(facet_markers)
mt = mesh.meshtags(domain, gdim - 1, facet_markers[arg_sort], np.full(len(facet_markers), 2, dtype=np.int32))
with common.Timer("~~Periodic: Compute mpc condition"):
    mpc = dolfinx_mpc.MultiPointConstraint(V)
    mpc.create_periodic_constraint_topological(V, mt, 2, periodic_relation, bcs)
    mpc.finalize()
WPsolve = LinearProblem(a_form, L_form, mpc, u=u, bcs=bcs, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
WPsolve.solve()
#WPsolve = fem.petsc.LinearProblem(a_form, L_form, u=u, bcs=bcs)
#WPsolve.solve()
V0 = fem.functionspace(domain, ("DG", 0, (3,)))
sig_exp = fem.Expression(stress(u), V0.element.interpolation_points())
sig = fem.Function(V0, name="Stress")
sig.interpolate(sig_exp)
import pyvista
from dolfinx import plot
pyvista.set_jupyter_backend("static")
topology, cell_types, geometry = plot.vtk_mesh(domain, 2)
grid = pyvista.UnstructuredGrid(topology, cell_types, geometry)
p = pyvista.Plotter()
p.add_mesh(grid,show_edges=True)
p.view_xy()
p.show_axes()
p.show()
vtk = io.VTKFile(domain.comm, "wpex3.pvd", "u")
vtk.write_function(u, 0)
vtk.write_function(sig, 0)
vtk.close()
You have already asked this question at: Implementation of periodic boundary condition for Plane Strain Case- mesh imported using GMSH API
Please remove one of the questions.
I have flagged for the removal of this question asked previously. How do I implement the periodic bc for facets 2 (right) and 4 (left) eges as per the geometry along the x-direction.
You know the geometric relation for the line on the left and the line on the right.
Thus given appropriate boundary tags of either set of facets, you can make a periodic map
def map(x):
     return (your_map(x[0], x[1]), x[1])
which can be used in the same way as in:
However, as you know that the points are matching, you could also use create_point_to_point_constraint as shown in: dolfinx_mpc/python/demos/demo_elasticity_disconnect.py at 02338e6dcf44f7b5b08238586b277aac8153d4f3 · jorgensd/dolfinx_mpc · GitHub
Hello Jorgen,
I did not understand exactly how to create mapping using facets, however, I tried this another approach taking some assistance from your suggested link. I am still getting this error which I am not able to understand. Here is the MWE.
import os
import sys
#import pyvista
from dolfinx.cpp.mesh import to_type, cell_entity_type
import dolfinx.fem.petsc
from dolfinx.graph import adjacencylist
from dolfinx.geometry import bb_tree, compute_collisions_points, compute_colliding_cells
from dolfinx.io import VTXWriter, distribute_entity_data, gmshio
from dolfinx.mesh import meshtags_from_entities, locate_entities_boundary, meshtags
from ufl import (FacetNormal, FiniteElement, as_matrix, Identity, Measure, TestFunction, TrialFunction, VectorElement, as_vector, div, dot, ds, dx, inner, lhs, grad, nabla_grad, rhs, sym)
import dolfinx_mpc.utils
from dolfinx_mpc import LinearProblem
gmsh.model.add("mesh")
gdim = 2
model_rank = 0
h = 0.05
lc = 1e-3
gmsh.model.geo.addPoint(0.1,0,0,lc,2)
gmsh.model.geo.addPoint(0.157735027,0.1,0,lc,3)
gmsh.model.geo.addPoint(-0.057735027,0.1,0,lc,4)
gmsh.write("mesh.msh")
gmsh.fltk.run()
gmsh.finalize()
        return eps_t
mu = E/2/(1+nu)
        return sigv
degree = 2
# Applying a uniform traction
periodic_boundary = right_dofs  # This is my slave side
facets = locate_entities_boundary(domain, domain.topology.dim-1, periodic_boundary)
arg_sort = np.argsort(facets)
mt = meshtags(domain, domain.topology.dim -1, facets[arg_sort], np.full(len(facets), 2, dtype=np.int32))
    out_x[0] = ((np.pi)/3) - x[0]
    out_x[1] = x[1]
    #out_x[2] = x[2]
    return out_x
    mpc.create_periodic_constraint_topological(V.sub(0), mt, 2, periodic_relation, bcs, default_scalar_type(1))
    mpc.finalize()
WPsolve.solve()
My error is
TypeError                                 Traceback (most recent call last)
Cell In[16], line 72
     69 periodic_boundary = right_dofs  # This is my slave side
     71 # Periodic boundary - topological
---> 72 facets = locate_entities_boundary(domain, domain.topology.dim-1, periodic_boundary)
     73 arg_sort = np.argsort(facets)
     74 mt = meshtags(domain, domain.topology.dim -1, facets[arg_sort], np.full(len(facets), 2, dtype=np.int32))
File ~/anaconda3/envs/bluemira-dolmpc/lib/python3.11/site-packages/dolfinx/mesh.py:233, in locate_entities_boundary(mesh, dim, marker)
    208 def locate_entities_boundary(mesh: Mesh, dim: int, marker: typing.Callable) -> np.ndarray:
    209     """Compute mesh entities that are connected to an owned boundary
    210     facet and satisfy a geometric marking function.
    211
    231
    232     """
--> 233     return _cpp.mesh.locate_entities_boundary(mesh._cpp_object, dim, marker)
TypeError: locate_entities_boundary(): incompatible function arguments. The following argument types are supported:
    1. (mesh: dolfinx.cpp.mesh.Mesh_float32, dim: int, marker: Callable[[numpy.ndarray[numpy.float32]], numpy.ndarray[bool]]) -> numpy.ndarray[numpy.int32]
    2. (mesh: dolfinx.cpp.mesh.Mesh_float64, dim: int, marker: Callable[[numpy.ndarray[numpy.float64]], numpy.ndarray[bool]]) -> numpy.ndarray[numpy.int32]
Invoked with: <dolfinx.cpp.mesh.Mesh_float64 object at 0x71c5bedc4fb0>, 1, [array([6212, 6218, 6224, 6230, 6236, 6242, 6248, 6262, 6268, 6282, 6288,
       6294, 6300, 6306, 6312, 6318, 6324, 6330, 6336, 6342, 6348, 6354,
       6358, 6360, 6362, 6364, 6366, 6368, 6370, 6372, 6376, 6382, 6384,
       6388, 6392, 6398, 6400, 6402, 6404, 6406, 6408, 6410, 6412, 6414,
       6416, 6418, 6420, 6422, 6424], dtype=int32), array([3106, 3109, 3112, 3115, 3118, 3121, 3124, 3131, 3134, 3141, 3144,
       3147, 3150, 3153, 3156, 3159, 3162, 3165, 3168, 3171, 3174, 3177,
       3179, 3180, 3181, 3182, 3183, 3184, 3185, 3186, 3188, 3191, 3192,
       3194, 3196, 3199, 3200, 3201, 3202, 3203, 3204, 3205, 3206, 3207,
       3208, 3209, 3210, 3211, 3212], dtype=int32)]
Here you are mixing dofs and facets:
You have stated that
First of all, periodic_boundary is a list of degrees of freedom.
You are trying to send these into locate_entities_boundary, which takes in a function for locating entities (facets, edges or vertices) based on a geometrical function.
Here is a minimal working example for your case. Please inspect it carefully as I have taken quite a lot of care reducing it to a minimal example
from dolfinx.common import Timer
from dolfinx.io import VTXWriter, gmshio
from ufl import (FacetNormal, as_matrix, TestFunction, TrialFunction, as_vector, dot, ds, dx, inner, grad, sym)
gdim = 2
model_rank = 0
h = 0.05
lc = 1e-3
delta_x = 0.57735027
gmsh.model.geo.addPoint(0.1+delta_x,0.1,0,lc,3)
gmsh.model.geo.addPoint(-delta_x,0.1,0,lc,4)
#gmsh.fltk.run()
gmsh.finalize()
        return eps_t
mu = E/2/(1+nu)
        return sigv
degree = 2
    Map the line
    y = 0.1/delta_x * x - 0.01/delta_x
    to
    y = -0.1/delta_x*x
    to
    meaning that if we have (x,y) from the right line
    x_left = -delta_x/0.1 * y
    if y = 0 -> x_left = 0
    if y = 0.01 -> x_left = -delta_x
    out_x[0] = x[1] * (-delta_x/0.1)
    out_x[1] = x[1]
    return out_x
with Timer("~~Periodic: Compute mpc condition"):
    mpc.create_periodic_constraint_topological(V.sub(0), facet_markers, 2, periodic_relation, bcs, default_scalar_type(1))
    mpc.finalize()
u = fem.Function(mpc.function_space, name = "Displacement")
WPsolve.solve()
with dolfinx.io.VTXWriter(domain.comm, "solution.bp", [u]) as bp:
    bp.write(0)
Many Thanks, Jorgen! It is working now. Now I understand my mistake.
