Suppose we have the 2D rectangular domain defined as follows:
from dolfinx.io.gmshio import model_to_mesh
import pyvista
from dolfinx import plot
from ufl import (FacetNormal, FiniteElement, Identity,TestFunction, TrialFunction, VectorElement,
div, dot, ds, dx, inner, lhs, nabla_grad, rhs, sym)
from dolfinx.fem import Constant,Function, FunctionSpace, assemble_scalar, dirichletbc, form, locate_dofs_geometrical,locate_dofs_topological
from dolfinx.fem.petsc import assemble_matrix, assemble_vector, apply_lifting, create_vector, set_bc
A = np.array([0,0])
B = np.array([3,0])
C = np.array([3,1])
D = np.array([0,1])
#gmsh.option.setNumber("General.Terminal",0) #To hide the mesh output values
mesh_size = 0.1
point_1 = gmsh.model.geo.add_point(A[0],A[1], 0, mesh_size)
point_2 = gmsh.model.geo.add_point(B[0],B[1], 0, mesh_size)
point_3 = gmsh.model.geo.add_point(C[0],C[1], 0, mesh_size)
point_4 = gmsh.model.geo.add_point(D[0],D[1], 0, mesh_size)
line_1 = gmsh.model.geo.add_line(point_1, point_2)
line_2 = gmsh.model.geo.add_line(point_2, point_3)
line_3 = gmsh.model.geo.add_line(point_3, point_4)
line_4 = gmsh.model.geo.add_line(point_4, point_1)
curve_loop = gmsh.model.geo.add_curve_loop([line_1,line_2,line_3,line_4])
plane_surface = gmsh.model.geo.add_plane_surface([curve_loop])
gmsh.model.geo.synchronize()
gmsh.model.addPhysicalGroup(2, [plane_surface], name = "fluid")
gmsh.model.addPhysicalGroup(1, [line_1,line_3], name = "walls")
gmsh.model.addPhysicalGroup(1, [line_4], name = "in_flow")
gmsh.model.addPhysicalGroup(1, [line_2], name = "out_flow")
gmsh.model.mesh.generate()
mesh, cell_tags, facet_tags = model_to_mesh(gmsh.model, MPI.COMM_WORLD, 0,gdim=2)
gmsh.finalize()
You can draw it via:
topology, cell_types, geometry_for_plotting = plot.create_vtk_mesh(mesh, 2)
#If you have the word geometry in place of geometry_for_plotting, it might conflict with the boundingBoxTree statement in the get coordinate function
grid = pyvista.UnstructuredGrid(topology, cell_types, geometry_for_plotting)
pyvista.set_jupyter_backend("pythreejs")
plotter = pyvista.Plotter()
plotter.view_xy()
if not pyvista.OFF_SCREEN:
plotter.show()
pyvista.start_xvfb()
figure = plotter.screenshot("fundamentals_mesh.png")
Suppose to solve the Navier Stokes Poiseuille flow, we can define the boundary conditions as mentioned in the tutorial
t = 0
T = 10
num_steps = 500
dt = T/num_steps
v_cg2 = VectorElement("CG", mesh.ufl_cell(), 2)
s_cg1 = FiniteElement("CG", mesh.ufl_cell(), 1)
V = FunctionSpace(mesh, v_cg2)
Q = FunctionSpace(mesh, s_cg1)
p = TrialFunction(Q)
q = TestFunction(Q)
def inflow(x):
return np.isclose(x[0], A[0])
inflow_dofs = locate_dofs_geometrical(Q, inflow)
bc_inflow = dirichletbc(PETSc.ScalarType(8), inflow_dofs, Q)
def walls(x):
return np.logical_or(np.isclose(x[1],A[1]), np.isclose(x[1],C[1]))
wall_dofs = locate_dofs_geometrical(V, walls)
u_noslip = np.array((0,) * mesh.geometry.dim, dtype=PETSc.ScalarType)
bc_noslip = dirichletbc(u_noslip, wall_dofs, V)
def outflow(x):
return np.isclose(x[0], C[0])
outflow_dofs = locate_dofs_geometrical(Q, outflow)
bc_outflow = dirichletbc(PETSc.ScalarType(0), outflow_dofs, Q)
bcu = [bc_noslip]
bcp = [bc_inflow, bc_outflow]
But, can you please help me to utilize the physical groups I have defined through GMSH directly; For example
gmsh.model.addPhysicalGroup(1, [line_4], name = "in_flow") for the inflow boundary condition
I’m trying as below:
fdim = mesh.topology.dim - 1
bc_inflow = dirichletbc(PETSc.ScalarType(8), locate_dofs_topological(Q, fdim, facet_tags.find(in_flow)))
I tried to use what they have done here-,To%20tag,-the%20different%20surfaces) but it was not successful.
I really appreciate your help
