Hello Everyone,
I have adopted the hyperelastic Tutorial from Dokken to incorporate another free energy.
My goal is to take the derivative of this free energy \Psi to C:
\frac{d \Psi}{d \boldsymbol{C}} with \boldsymbol{C} = \boldsymbol{F}^T \boldsymbol{F} and \boldsymbol{F} being the deformation gradient.
However, when I do this and then try to solve the system I get the error message:
File “/usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/nls/petsc.py”, line 47, in solve
n, converged = super().solve(u.x.petsc_vec)
RuntimeError: Failed to successfully call PETSc function ‘KSPSolve’. PETSc error code is: 73, Object is in wrong state
2024-06-10 15:42:15.528 ( 0.380s) [main ] loguru.cpp:526 INFO| atexit
I use dolfinx v:0.8
However, when I take the derivative with the deformation gradient, this error does not appear, even when both variables are tensors with the same shape.
I appreciate any advice on what I’m missing, as it seems to be a pretty simple problem but I can not figure it out.
Here is a MME:
from dolfinx import log, default_scalar_type
from dolfinx import fem, mesh
def free_energy_mech(_F_def):
free Energy of the mechanical part
detF = ufl.det(_F_def) # J = det(F)
_C = ufl.variable(_F_def.T * _F_def) # Right Cauchy-Green tensor
Ic = detF**(-2/3)*ufl.tr(_C) # Invariants of deformation tensors
# Elasticity parameters
c1 = default_scalar_type(0.189439) # MPa
c2 = default_scalar_type(-5.197e-6) # MPa
c3 = default_scalar_type(0.0024059) # MPa
D1 = default_scalar_type((0.189439*10)**(-1)) # MPa for nu = 0.452
# Stored strain energy density (nearly incompressible Yeoh Model)
_Psi = c1*(Ic - 3) + c2*(Ic - 3)**2 + c3*(Ic - 3)**3 + 1/D1*(detF-1)**2
return _Psi
L = 20.0
domain = mesh.create_box(MPI.COMM_WORLD, [[0.0, 0.0, 0.0], [L, 1, 1]], [20, 5, 5], mesh.CellType.hexahedron)
V = fem.functionspace(domain, ("Lagrange", 2, (domain.geometry.dim, )))
def left(x):
return np.isclose(x[0], 0)
def right(x):
return np.isclose(x[0], L)
# Concatenate and sort the arrays based on facet indices. Left facets marked with 1, right facets with two
marked_values = np.hstack([np.full_like(left_facets, 1), np.full_like(right_facets, 2)])
facet_tag = mesh.meshtags(domain, fdim, marked_facets[sorted_facets], marked_values[sorted_facets])
u_bc = np.array((0,) * domain.geometry.dim, dtype=default_scalar_type)
left_dofs = fem.locate_dofs_topological(V, facet_tag.dim, facet_tag.find(1))
bcs = [fem.dirichletbc(u_bc, left_dofs, V)]
B = fem.Constant(domain, default_scalar_type((0, 0, 0)))
u = fem.Function(V)
# Spatial dimension
d = len(u)
# Identity tensor
I = ufl.variable(ufl.Identity(d))
# Deformation gradient
F_def = ufl.variable(I + ufl.grad(u))
C = ufl.variable(F_def.T * F_def)
Ic = ufl.variable(ufl.tr(C))
J = ufl.variable(ufl.det(F_def))
psi = free_energy_mech(F_def)
dPsidC = ufl.diff(psi, C)
# dPsidC = ufl.diff(psi, F_def)
P2nd = 2*dPsidC - 1/3*(ufl.inner(dPsidC,C)*ufl.inv(C)) #2nd Pioloa-Kirchoff
P1st = P2nd* F_def.T
ds = ufl.Measure('ds', domain=domain, subdomain_data=facet_tag, metadata=metadata)
# Define form F (we want to find u such that F(u) = 0)
F = ufl.inner(ufl.grad(v), P1st) * dx - ufl.inner(v, B) * dx - ufl.inner(v, T) * ds(2)
problem = NonlinearProblem(F, u, bcs)
solver = NewtonSolver(domain.comm, problem)
# Set Newton solver options
solver.atol = 1e-8
solver.rtol = 1e-8
tval0 = -1.5
for n in range(1, 2):
T.value[2] = n * tval0
num_its, converged = solver.solve(u)
assert (converged)
u.x.scatter_forward()
print(f"Time step {n}, Number of iterations {num_its}, Load {T.value}")
