Problem with Matplotlib
Hello everyone,
I wrote this simple code and everything works okay, but at the end when it comes to use matplotlib I get an error concerning PETSc
import pyvista
from ufl import SpatialCoordinate, TestFunction, TrialFunction, dot, ds, dx, grad, div, FacetNormal,VectorElement, inner
from dolfinx import fem, mesh, io, plot
from dolfinx.fem.petsc import assemble_vector, assemble_matrix, create_vector, apply_lifting, set_bc
def V_exact(mode):
    #return lambda x: mode.atan(mode.pi * x[1])
    # return lambda x: (10000 -8000 * x[1]) * x[1]
    return lambda x: -mode.cos(mode.pi*x[1])
V_numpy = V_exact(np) # which will be used for interpolation
V_ufl = V_exact(ufl) # which will be used for defining the source term
def solve_poisson(N=10, degree=1):
    domain = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([0, 0]), np.array([1, 1])],
                          [N, N], mesh.CellType.triangle)
    x = SpatialCoordinate(domain)
    sigma = fem.Constant(domain, PETSc.ScalarType(500))
    f = div(-sigma * grad(V_ufl(x)))
    W = fem.FunctionSpace(domain, ("Lagrange", 1))
    V = TrialFunction(W)
    csi = TestFunction(W)
    a = dot(sigma * grad(V), grad(csi)) * dx
    L = f * csi * dx
    # We start by identifying the facets contained in each boundary and create a custom integration measure ds
    boundaries = [(1, lambda x: np.isclose(x[0], 0)),
                  (2, lambda x: np.isclose(x[0], 1)),
                  (3, lambda x: np.isclose(x[1], 0)),
                  (4, lambda x: np.isclose(x[1], 1))]
    # We now loop through all the boundary conditions and create MeshTags identifying the facets for each boundary condition
        facets = mesh.locate_entities(domain, fdim, locator)
        facet_indices.append(facets)
    facet_tag = mesh.meshtags(domain, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
    domain.topology.create_connectivity(domain.topology.dim - 1, domain.topology.dim)
    # We can then inspect individual boundaries using the Threshold-filter in Paraview
    ds = ufl.Measure("ds", domain=domain, subdomain_data=facet_tag)
    # Dirichlet condition
    facets = facet_tag.find(3)
    dofs = fem.locate_dofs_topological(W, fdim, facets)
    facets2 = facet_tag.find(4)
    dofs2 = fem.locate_dofs_topological(W, fdim, facets2)
    BCs = [fem.dirichletbc(PETSc.ScalarType(-1), dofs, W), fem.dirichletbc(PETSc.ScalarType(1), dofs2, W)]
    default_problem = fem.petsc.LinearProblem(a, L, bcs=BCs,
                                              petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
    return default_problem.solve(), V_ufl(x)
def error_L2_func(Vh, V_ex, degree_raise=3):
    # Create higher order function space
    degree = 1 #Vh.function_space.ufl_element().degree
    family = Vh.function_space.ufl_element().family_name
    mesh = Vh.function_space.mesh
    Q = fem.functionspace(mesh, (family, degree + degree_raise))
    # Interpolate approximate solution
    V_W = fem.Function(Q)
    V_W.interpolate(Vh)
    # Interpolate exact solution, special handling if exact solution
    # is a ufl expression or a python lambda function
    V_ex_W = fem.Function(Q)
    if isinstance(V_ex, ufl.core.expr.Expr):
        u_expr = fem.Expression(V_ex, Q.element.interpolation_points)
        V_ex_W.interpolate(u_expr)
        V_ex_W.interpolate(V_ex)
    # Compute the error in the higher order function space
    e_W = fem.Function(Q)
    e_W.x.array[:] = V_W.x.array - V_ex_W.x.array
    # Integrate the error
    error = fem.form(ufl.inner(e_W, e_W) * ufl.dx)
    error_local = fem.assemble_scalar(error)
    error_global = mesh.comm.allreduce(error_local, op=MPI.SUM)
    return np.sqrt(error_global)
N = [10, 20, 40, 80, 160]
error_L2 = []
error_H1 = []
h = []
mpi_rank = 5
for i in range(len(N)):
    Vh, Vex = solve_poisson(N[i])
    comm = Vh.function_space.mesh.comm
    error_L2 += [error_L2_func(Vh, V_numpy)]
    eh = Vh - Vex
    error_H10 = fem.form(dot(grad(eh), grad(eh)) * dx)
    E_H10 = np.sqrt(comm.allreduce(fem.assemble_scalar(error_H10), op=MPI.SUM))
    error_H1 += [E_H10]
    h += [1. / N[i]]
    if comm.rank == 0:
        mpi_rank = comm.rank
        print(f"h: {h[i]:.2e} Error: {error_L2[i]:.2e}")
if mpi_rank == 0:
    plt.figure(figsize=(10, 6))
    plt.loglog(N, error_L2, label='$L^2$ error')
    plt.loglog(N, error_H1, label='$H^1$ error')
    plt.loglog(N, h)
    h_square = [x**2 for x in h]
    plt.loglog(N, h_square)
    plt.xlabel('N')
    plt.ylabel('Error')
    plt.legend()
    plt.grid(True)
the erro
[0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
can someone tell me what is wrong? I look also at other posts related to matplotlib, but this problem is not related to plotting a mesh or something more involved.
Thanks in advance.
Michele.
Your code runs fine on my system.
This error has popped up several time in this post, for instance at Segmentation fault upon importing matplotlib into a dolfinx . Consider using the search button for more results. Overall, this sort of problem is typically related to how you installed dolfinx and matplotlib, so you’ll need to provide us more details on that.
yes, that solved my problem, I will search better next time, sorry.
