Phase field fracture in Dolfinx
Dear all,
Recently, I am working on the classic phase field fracture problem.
Here is the link to the original journal paper.
BTW, it’s also realized in another topic but in the way of Dolfin.
Because I always use the newest Dolfinx, I tried to update the code into the Dolfinx version. After the update, the code can run successfully. However, there are two problems.
1. if the tolerance is set as 1e-3, the result is wrong. If the tolerance is set as 1e-6, it will never converge.
2. the errors of running code by 1 core and multiple cores are different.
Can anyone please let me know where I am wrong? Thanks a lot for your time and help! My code is attached as below.
import csv
import pandas as pd
import time
from dolfinx import fem, io, mesh, plot, common, geometry
import pyvista
from dolfinx.io import gmshio
teststart = time.perf_counter()
print("start the simulation")
rank = MPI.COMM_WORLD.rank
comm = MPI.COMM_WORLD
W = 1
H = 0.0001
gdim = 2
crack_marker = 10
if rank == 0:
    box = gmsh.model.occ.addRectangle(0, 0, 0, W, W)
    rectangle1 = gmsh.model.occ.addRectangle(0, W / 2 - H, 0, W / 2, H)
    whole_domain = gmsh.model.occ.cut([(2, box)], [(2, rectangle1)])
    gmsh.model.occ.synchronize()
    material_marker = 1
    assert len(volumes) == 1
    gmsh.model.addPhysicalGroup(volumes[0][0], [volumes[0][1]], material_marker)  # box
    gmsh.model.setPhysicalName(volumes[0][0], material_marker, "materials")
    # crack_marker = 10
    crack = []
    for boundary in boundaries:
        # print(boundary, center_of_mass)
        if np.allclose(center_of_mass, [0.5, 0.49995, 0]):
            crack.append(boundary[1])
        if np.allclose(center_of_mass, [0.25, 0.4999, 0]):
        if np.allclose(center_of_mass, [0.25, 0.5, 0]):
    gmsh.model.addPhysicalGroup(1, crack, crack_marker)
    gmsh.model.setPhysicalName(1, crack_marker, "crack_wall")
    gmsh.option.setNumber("Mesh.CharacteristicLengthMin", 0.008)
    gmsh.option.setNumber("Mesh.CharacteristicLengthMax", 0.008)
    gmsh.option.setNumber("Mesh.Algorithm", 5)
    gmsh.write("mesh_applied.msh")
gmsh.finalize()
gmsh_model_rank = 0
mesh_comm = MPI.COMM_WORLD
msh, cell_markers, facet_markers = gmshio.read_from_msh("mesh_applied.msh", mesh_comm, gmsh_model_rank, gdim=gdim)
# print(facet_markers.find(crack_marker))
V = fem.FunctionSpace(msh, ("CG", 1))
W = fem.VectorFunctionSpace(msh, ("CG", 1))
WW = fem.FunctionSpace(msh, ("DG", 0))
p, q = ufl.TrialFunction(V), ufl.TestFunction(V)
u, v = ufl.TrialFunction(W), ufl.TestFunction(W)
Gc = 2.7
l = 0.015
lmbda = 121.15e3
mu = 80.77e32
    return ufl.sym(ufl.grad(u))
def sigma(u):
    return lmbda * ufl.nabla_div(u) * ufl.Identity(len(u)) + 2 * mu * epsilon(u)
def psi(u):
    return 0.5 * (lmbda + mu) * (
        0.5 * (ufl.tr(epsilon(u)) + abs(ufl.tr(epsilon(u))))
    ) ** 2 + mu * inner(ufl.dev(epsilon(u)), ufl.dev(epsilon(u)))
def H(uold, unew, Hold):
    return ufl.conditional(ufl.lt(psi(uold), psi(unew)), psi(unew), Hold)
def bottom(x):
    return np.isclose(x[1], 0)
bottom_sld_facets = mesh.locate_entities_boundary(msh, msh.topology.dim - 1, bottom)
bottom_sld_dofs_x = fem.locate_dofs_topological(W.sub(0), msh.topology.dim - 1, bottom_sld_facets)
bottom_sld_bc_x = fem.dirichletbc(ScalarType(0), bottom_sld_dofs_x, W.sub(0))
bottom_sld_dofs_y = fem.locate_dofs_topological(W.sub(1), msh.topology.dim - 1, bottom_sld_facets)
bottom_sld_bc_y = fem.dirichletbc(ScalarType(0), bottom_sld_dofs_y, W.sub(1))
def top(x):
    return np.isclose(x[1], 1)
top_sld_facets = mesh.locate_entities_boundary(msh, msh.topology.dim - 1, top)
top_sld_dofs_x = fem.locate_dofs_topological(W.sub(0), msh.topology.dim - 1, top_sld_facets)
top_sld_bc_x = fem.dirichletbc(ScalarType(0), top_sld_dofs_x, W.sub(0))
top_sld_dofs_y = fem.locate_dofs_topological(W.sub(1), msh.topology.dim - 1, top_sld_facets)
load = 0.0
top_y_load = fem.dirichletbc(load, top_sld_dofs_y, W.sub(1))
bc_u = [bottom_sld_bc_x, bottom_sld_bc_y, top_y_load]
f = fem.Constant(msh, ScalarType((0, 0)))
T = fem.Constant(msh, ScalarType((0, 0)))
ds = ufl.Measure("ds", domain=msh)
fdim = msh.topology.dim - 1
initial_crack = fem.Function(V)
initial_crack.interpolate(lambda x: 1.0 + 0 * x[0])
bc_phi = [fem.dirichletbc(initial_crack, fem.locate_dofs_topological(V, fdim, facet_markers.find(crack_marker)))]
unew, uold = fem.Function(W), fem.Function(W)
pnew, pold, Hold = fem.Function(V), fem.Function(V), fem.Function(V)
E_du = ((1.0 - pold) ** 2) * inner(grad(v), sigma(u)) * dx
E_phi = (Gc * l * inner(grad(p), grad(q)) + ((Gc / l) + 2.0 * H(uold, unew, Hold)) * inner(p, q) - 2.0 * H(uold, unew, Hold) * q) * dx
a_sld = ufl.lhs(E_du)
L_sld = ufl.rhs(E_du) + ufl.dot(f, v) * ufl.dx + ufl.dot(T, v) * ds
a_E_phi = ufl.lhs(E_phi)
L_E_phi = ufl.rhs(E_phi)
bilinear_form_sld = fem.form(a_sld)
linear_form_sld = fem.form(L_sld)
bilinear_form_E_phi = fem.form(a_E_phi)
linear_form_E_phi = fem.form(L_E_phi)
A_sld = fem.petsc.create_matrix(bilinear_form_sld)
b_sld = fem.petsc.create_vector(linear_form_sld)
A_E_phi = fem.petsc.create_matrix(bilinear_form_E_phi)
b_E_phi = fem.petsc.create_vector(linear_form_E_phi)
solver_sld = PETSc.KSP().create(msh.comm)
solver_sld.setOperators(A_sld)
solver_sld.setType(PETSc.KSP.Type.GMRES)
solver_sld.getPC().setType(PETSc.PC.Type.JACOBI)
solver_E_phi = PETSc.KSP().create(msh.comm)
solver_E_phi.setOperators(A_E_phi)
solver_E_phi.setType(PETSc.KSP.Type.GMRES)
solver_E_phi.getPC().setType(PETSc.PC.Type.JACOBI)
t = 0
u_r = 0.007
deltaT = 0.1
tol = 1e-6
while t <= 1.0:
    t += deltaT
    if t >= 0.7:
        deltaT = 0.0001
    load = t * u_r
    iter = 0
    err = 1
    while err > tol:
        iter += 1
        with b_sld.localForm() as loc_b_sld:
            loc_b_sld.set(0)
        A_sld.zeroEntries()
        fem.petsc.assemble_matrix(A_sld, bilinear_form_sld, bcs=bc_u)
        A_sld.assemble()
        fem.petsc.assemble_vector(b_sld, linear_form_sld)
        fem.petsc.apply_lifting(b_sld, [bilinear_form_sld], [bc_u])
        b_sld.ghostUpdate(addv=PETSc.InsertMode.ADD_VALUES, mode=PETSc.ScatterMode.REVERSE)
        fem.petsc.set_bc(b_sld, bc_u)
        solver_sld.solve(b_sld, unew.vector)
        unew.x.scatter_forward()
        with b_E_phi.localForm() as loc_b_E_phi:
            loc_b_E_phi.set(0)
        A_E_phi.zeroEntries()
        fem.petsc.assemble_matrix(A_E_phi, bilinear_form_E_phi, bcs=bc_phi)
        A_E_phi.assemble()
        fem.petsc.assemble_vector(b_E_phi, linear_form_E_phi)
        fem.petsc.apply_lifting(b_E_phi, [bilinear_form_E_phi], [bc_phi])
        fem.petsc.set_bc(b_E_phi, bc_phi)
        solver_E_phi.solve(b_E_phi, pnew.vector)
        pnew.x.scatter_forward()
        error_form_p = fem.form((pnew - pold) ** 2 * ufl.dx)
        error_form_u = fem.form((unew - uold) ** 2 * ufl.dx)
        error_p = np.sqrt(comm.allreduce(fem.assemble_scalar(error_form_p), MPI.SUM))
        error_u = np.sqrt(comm.allreduce(fem.assemble_scalar(error_form_u), MPI.SUM))
        error = np.maximum(error_p, error_u)
        err = error
        uold.x.array[:] = unew.x.array
        pold.x.array[:] = pnew.x.array
        uold.x.scatter_forward()
        pold.x.scatter_forward()
        psi_expr = fem.Expression(psi(unew), V.element.interpolation_points())
        Hold.interpolate(psi_expr)
        Hold.x.scatter_forward()
        if rank == 0:
            print("timestep:", round(t, 5), "in the while loop, iteration is", iter, "error is", round(err, 9), tol)
    if rank == 0:
        print("time step for now is", round(t, 5))
        print("unew max is", np.max(unew.x.array))
if rank == 0:
    testend = time.perf_counter()
    print("time consumed:", testend-teststart)
Hi, I am trying your code and then it reports that “ImportError: cannot import name ‘create_vtk_mesh’ from ‘dolfinx.plot’”? Did you meet such problem?
@Zhitong Consider Cannot import name ‘vtk_mesh’ from ‘dolfinx.plot’.
it’s the old version of fenicsx.
Hello, I would like to ask, did you solve this problem? I am currently also working on this topic and corresponding code.
Best regards
There is also PhaseFieldX: Introduction — PhaseFieldX 0.1 documentation that has a large collection of phasefield methods on top of FEniCSx.
Maybe @CastillonMiguel can spot what is wrong.
I’ve updated the code to 0.10 with and ensured that one get’s an error if the solver doesn’t converge (and use direct solver for debugging).
As I’m not familiar with the scheme it’s hard to give further guidance.
import time
from dolfinx import fem, mesh
import dolfinx.io.gmsh as gmshio
import dolfinx.fem.petsc
W = 1
H = 0.0001
gdim = 2
crack_marker = 10
if rank == 0:
    material_marker = 1
    # crack_marker = 10
    crack = []
gmsh.finalize()
gmsh_model_rank = 0
mesh_data = gmshio.read_from_msh(
msh = mesh_data.mesh
cell_markers = mesh_data.cell_tags
facet_markers = mesh_data.facet_tags
V = fem.functionspace(msh, ("CG", 1))
W = fem.functionspace(msh, ("CG", 1, (msh.geometry.dim,)))
WW = fem.functionspace(msh, ("DG", 0))
Gc = 2.7
l = 0.015
lmbda = 121.15e3
mu = 80.77e32
def sigma(u):
def psi(u):
def bottom(x):
def top(x):
load = 0.0
bc_phi = [
    fem.dirichletbc(
        initial_crack,
        fem.locate_dofs_topological(V, fdim, facet_markers.find(crack_marker)),
E_phi = (
) * dx
b_sld = fem.petsc.create_vector(fem.extract_function_spaces(linear_form_sld))
b_E_phi = fem.petsc.create_vector(fem.extract_function_spaces(linear_form_E_phi))
solver_sld.setType(PETSc.KSP.Type.PREONLY)
solver_sld.getPC().setType(PETSc.PC.Type.LU)
solver_sld.getPC().setFactorSolverType("mumps")
solver_sld.setErrorIfNotConverged(True)
solver_E_phi.setType(PETSc.KSP.Type.PREONLY)
solver_E_phi.getPC().setType(PETSc.PC.Type.LU)
solver_E_phi.getPC().setFactorSolverType("mumps")
solver_E_phi.setErrorIfNotConverged(True)
t = 0
u_r = 0.007
deltaT = 0.1
tol = 1e-6
while t <= 1.0:
    t += deltaT
    if t >= 0.7:
        deltaT = 0.0001
    load = t * u_r
    iter = 0
    err = 1
    while err > tol:
        iter += 1
            loc_b_sld.set(0)
        A_sld.zeroEntries()
        A_sld.assemble()
        b_sld.ghostUpdate(
        solver_sld.solve(b_sld, unew.x.petsc_vec)
            loc_b_E_phi.set(0)
        A_E_phi.assemble()
        b_sld.ghostUpdate(
        solver_E_phi.solve(b_E_phi, pnew.x.petsc_vec)
        err = error
        psi_expr = fem.Expression(psi(unew), V.element.interpolation_points)
        if rank == 0:
            print(
                "timestep:",
                round(t, 5),
                iter,
                "error is",
                round(err, 9),
                tol,
            print(error_u, error_p, tol)
    if rank == 0:
if rank == 0:
    print("time consumed:", testend - teststart)
Hello, I have solved this problem. However, it’s two years ago, so I cant remember the way to solve it. sorry.:joy:
Hello, could you still find the code which worked successfully? Thank you.
The problem in the file refers to the single edge notched tension (SENT) test. The algorithm used is the staggered scheme, which incorporates the history field to enforce irreversibility of the damage variable.
I recommend checking the PhaseFieldX package (based on the latest version of FEniCSx 0.10.0), as it implements the same formulation and includes this example. You can find the example here:
https://phasefieldx.readthedocs.io/en/latest/auto_examples/PhaseFieldFracture/plot_1711.html
The PhaseFieldX repository is available here:
https://github.com/CastillonMiguel/phasefieldx
Best regards,
Sorry, I tried but failed.
Could you please provide more details about the error you encountered and the origin of the problem? If possible, it would be very helpful if you could share the specific part of the code where the issue occurs, as well as any error messages. With that information, I may be able to better understand the issue and help you resolve it.
