I am beginner with FEniCSx and am currently working with version 0.8.0.
I am implementing a phase-field brittle fracture problem using a monolithic approach and attempting to integrate a damped Newton method. As part of this process, firstly I am trying to develop a custom Newton solver that completely replicates the results of dolfinx.nls.petsc.NewtonSolver.
Using Dokken’s tutorial as a guide, I have created a custom Newton solver. In my MWE, the commented sections use dolfinx.nls.petsc.NewtonSolver, while the remaining code is for the custom Newton solver.
However, I am encountering the following issues:
- The residuals from the custom solver do not match those from
dolfinx.nls.petsc.NewtonSolver. Additionally, the custom solver requires more iterations and is significantly slower. - The custom solver does not support parallel execution. When I attempt to run it in parallel, the code hangs and does not proceed.
Here is the code snippet:
import os
import dolfinx.fem.petsc
import dolfinx.nls.petsc
from dolfinx import fem, io, log, mesh
import basix
from myfunctionstrial import mtrl_parameters, fracture_parameters, degradation_fn, \
bracket_operator_plus, bracket_operator_minus, log_info, log_setup
MPI.COMM_WORLD.Barrier()
start_time = MPI.Wtime()
# loading a 2D mesh - Single Edge Notched shear (SENP) specimen discretized with quadrilateral elements
meshfilename = "senp.msh"
if meshfilename.endswith(".msh"):
# dmesh -> DOLFINxmesh, ct -> cell_tags, ft -> facet_tags
dmesh, ct, ft = io.gmshio.read_from_msh(meshfilename, MPI.COMM_WORLD, 0, gdim=2)
raise ValueError("Only .msh or .xdmf file formats for meshes are supported!")
# creating mixed element function space, test functions and solution vectors
# function elements P->mechanics field (vector), S->fracture field (scalar), R-> history field (scalars)
P = basix.ufl.element("CG", dmesh.basix_cell(), 1, shape=(dmesh.geometry.dim,))
S = basix.ufl.element("CG", dmesh.basix_cell(), 1)
R = basix.ufl.element("DG", dmesh.basix_cell(), 0)
# mixed element
mix = basix.ufl.mixed_element([P,S])
# create a function space consisting of a mixed element at each node
V = fem.functionspace(dmesh,mix)
# create a separate function space for history variable
W = fem.functionspace(dmesh,R)
# test functions du->mechanics field, dd->fracture field
du , dd = ufl.TestFunctions(V)
# mixed solution vector creation, sol-> n+1 th load increment step, solold-> n th time step (previous)
sol = fem.Function(V)
solold = fem.Function(V)
# history variable vector creation
H = fem.Function(W)
Hold = fem.Function(W) # history field at the previous time step
# individual solution vectors at n+1 step, u-> mechanics field, d-> fracture field
u, d = ufl.split(sol)
# individual solution vectors at n th step, uold-> mechanics field, dold-> fracture field
uold, dold = ufl.split(solold)
lmda, mu, K = mtrl_parameters()
G_cr, l, total_u, delta_u, k =fracture_parameters()
# function for returning facets in the top edge
def top(x):
return np.isclose(x[1],1)
# function for returning facets in the bottom edge
def bot(x):
return np.isclose(x[1],0)
# function for returning facets in the crack face
def crack(x):
#crack is at (0,0.5) to (0.5,0.5)
return np.logical_and(abs(x[1]-0.5) <= 0.001, x[0] <= 0.5)
# subspace of mechanics field, accessing all components of u
V0,_ = V.sub(0).collapse()
# subspace of mechanics field, accessing u along x-direction
V01, _ = V.sub(0).sub(0).collapse()
# subspace of mechanics field, accessing u along y-direction
V02, _ = V.sub(0).sub(1).collapse()
# subspace of fracture field, accessing d
V1,_ = V.sub(1).collapse()
# obtain corresponding facets as per the requirement
bot_facets = mesh.locate_entities_boundary(dmesh, 1, bot)
top_facets = mesh.locate_entities_boundary(dmesh, 1, top)
crack_facets = mesh.locate_entities_boundary(dmesh, 1, crack)
# obtain dofs on the corresponding facets using the subspaces
# on bottom face all components of u are chosen
bot_dofs = fem.locate_dofs_topological((V.sub(0),V0), 1, bot_facets)
# on top face only x-component of u is chosen
top_dofs = fem.locate_dofs_topological((V.sub(0).sub(0),V01), 1, top_facets)
# on top face only y-component of u is chosen
top_dofs_y = fem.locate_dofs_topological((V.sub(0).sub(1),V02), 1, top_facets)
# the phase field parameter d dofs is chosen on the crack facets
crack_dofs = fem.locate_dofs_topological((V.sub(1),V1), 1, crack_facets)
# expression for defining values to the corresponding boundary conditions
# boundary values values needed for bottom face
u_bot = fem.Function(V0)
u_botval = fem.Constant(dmesh,ScalarType([0.0,0.0]))
u_botexpr = fem.Expression(u_botval,V0.element.interpolation_points())
u_bot.interpolate(u_botexpr)
# boundary values values needed for top face
u_top = fem.Function(V01)
u_topval = fem.Constant(dmesh,ScalarType(0.001))
u_topexpr = fem.Expression(u_topval,V01.element.interpolation_points())
u_top.interpolate(u_topexpr)
u_topy = fem.Function(V02)
u_topyval = fem.Constant(dmesh,ScalarType(0))
u_topyexpr = fem.Expression(u_topyval,V02.element.interpolation_points())
u_topy.interpolate(u_topyexpr)
# expression for defining the value of d at crack facets
d_crack = fem.Function(V1)
d_crack.x.array[:] = 1
# defining dirichlet boundary condition on the bottom face, all components of u=0 (fixed)
bc_ubot = fem.dirichletbc(u_bot,bot_dofs,V.sub(0))
# defining dirichlet boundary condition on the top face, for applying load increments along x
bc_utop = fem.dirichletbc(u_top, top_dofs, V.sub(0).sub(0))
# defining dirichlet boundary condition on the top face, for applying uy=0
bc_utopy = fem.dirichletbc(u_topy, top_dofs_y, V.sub(0).sub(1))
# defining dirichlet boundary condition on the pre-crack face to be d=1
bc_dcrack = fem.dirichletbc(d_crack, crack_dofs, V.sub(1))
# defining tractions - (Neumann Boundary Conditions) - zero tractions on the boundary
t_bar = fem.Constant(dmesh,np.array([0.0,0.0],dtype=ScalarType))
# defining body forces - zero body forces
b = fem.Constant(dmesh,np.array([0.0,0.0],dtype=ScalarType))
# facet normal (will be required for computation of forces)
n = ufl.FacetNormal(dmesh)
#botom line - id - 1
#top line - id - 2
#crack upper line - id - 31
#crack bot line - id -1- 32
#surface - id - 4
ds_top = ufl.Measure(integral_type='ds', domain=dmesh, subdomain_data=ft, subdomain_id=2)
# defining constitutive and kinematical relations
def To2D(A):
return ufl.as_tensor([[ A[0,0], A[0,1]],
[ A[1,0], A[1,1]] ])
def To3D(A):
return ufl.as_tensor([[ A[0,0], A[0,1], 0],
[ A[1,0], A[1,1], 0],
[ 0, 0, 0]])
# infinitesimal strain tensor
def epsilon(x_u):
return ufl.sym(ufl.grad(x_u))
# stress tensor
def sigma(x_u, x_d):
eps = epsilon(x_u)
eps=To3D(eps)
dev_epsilon = eps - ( (1/3)*ufl.tr(eps)*To3D(ufl.Identity(len(x_u))) )
stress3d= (degradation_fn(x_d)+ k) * ( (lmda+mu)*bracket_operator_plus(ufl.tr(epsilon(x_u)))*To3D(ufl.Identity(len(x_u))) + 2*mu*dev_epsilon ) +\
(lmda+mu)* bracket_operator_minus(ufl.tr(epsilon(x_u))) *To3D(ufl.Identity(len(x_u))) # Deviator split
return To2D(stress3d)
#return (degradation_fn(x_d)+ k)*(2.0*mu*epsilon(x_u)+lmda*ufl.tr(epsilon(x_u))*ufl.Identity(len(x_u))) # alternative - for hybrid implementation (ref. thesis)
# defining fracture related expressions
# tensile part of elastic strain energy density
def psi_e(x_u):
eps = epsilon(x_u)
eps=To3D(eps)
return 0.5*(lmda+mu)*(bracket_operator_plus(ufl.tr(epsilon(x_u))))**2 + mu*ufl.inner(dev_epsilon,dev_epsilon)
# History field variable
def H(x_uold,x_u,x_Hold):
return ufl.conditional(ufl.operators.gt(psi_e(x_u),x_Hold),psi_e(x_u),x_Hold)
# defining the variational form (monolithic)
# mechanics field variational form
mech = ufl.inner(sigma(u, d),epsilon(du))*ufl.dx - ufl.dot(b,du)*ufl.dx - ufl.dot(t_bar,du)*ds_top
# fracture field variational form
frac = G_cr*l*ufl.dot(ufl.grad(d),ufl.grad(dd)) *ufl.dx + ((G_cr/l) + 2*H(uold,u,Hold))*ufl.inner(d,dd) * ufl.dx - 2*dd*H(uold,u,Hold) *ufl.dx
# combined variational form
F = mech + frac
# problem creation
problem = dolfinx.fem.petsc.NonlinearProblem(F,sol,[bc_ubot, bc_utop, bc_dcrack, bc_utopy])
# Initialize solver and set parameters
# solver creation - nonlinear solver - newton solver
solver = dolfinx.nls.petsc.NewtonSolver(MPI.COMM_WORLD,problem)
# newton solver parameters
# convergence criterion - incremental tolerance (or residual tolerance)
# set relative tolerance
solver.rtol = 1e-6
# set absolute tolerance
solver.atol = 1e-6
# set max iterations
solver.max_it = 30
# krylov subspace solver parameters
ksp = solver.krylov_solver
opts = PETSc.Options()
# using direct solver with LU preconditioner
ksp.setFromOptions()
# uncomment below lines to know about the residual and convergence status at each solution step
# visible only in console (will not be logged in log file)
if (MPI.COMM_WORLD.rank ==0):
log_info("PETSc problem created and solver parameters set.",my_logger)
# general initializations
residual = dolfinx.fem.form(F)
dsol = ufl.TrialFunction(V)
J = ufl.derivative(F, sol, dsol)
jacobian = dolfinx.fem.form(J)
# Next, we define the matrix `A`, right hand side vector `L` and the correction function `du`
delsol = fem.Function(V)
delu, deld = ufl.split(delsol)
#delu = delsol.sub(0)
#deld = delsol.sub(1)
A = dolfinx.fem.petsc.create_matrix(jacobian)
L = dolfinx.fem.petsc.create_vector(residual)
solver = PETSc.KSP().create(dmesh.comm)
solver.setOperators(A)
load = 0
# initializing u, d, uold, dold, aold, vold for problem solving and results saving
u = sol.sub(0)
d = sol.sub(1)
uold = solold.sub(0)
dold = solold.sub(1)
while load <= 1:
# incrementing displacement
u_topval.value = load*total_u
'''# exception handling for situations when newton solver does not converge
try:
r = solver.solve(sol) # r = [convergence iterations, converge status(true or false)]
assert r[1]
except:
if(MPI.COMM_WORLD.rank ==0):
my_logger.error("Newton Solver did not converge!.")
print("Newton Solver did not converge!.")
break'''
#solver:
i = 0
max_iterations=30
L2_error = []
L_norm = []
while i < max_iterations:
# Assemble Jacobian and residual
with L.localForm() as loc_L:
loc_L.set(0)
A.zeroEntries()
dolfinx.fem.petsc.assemble_matrix(A, jacobian, bcs=[bc_ubot, bc_utop, bc_dcrack, bc_utopy])
dolfinx.fem.petsc.assemble_vector(L, residual)
L.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
L.scale(-1)
# Compute b - J(u_D-u_(i-1))
dolfinx.fem.petsc.apply_lifting(L, [jacobian], [[bc_ubot, bc_utop, bc_dcrack, bc_utopy]], x0=[sol.x.petsc_vec])
# Set du|_bc = u_{i-1}-u_D
dolfinx.fem.petsc.set_bc(L, [bc_ubot, bc_utop, bc_dcrack, bc_utopy], sol.x.petsc_vec, 1.0)
L.ghostUpdate(addv=PETSc.InsertMode.INSERT_VALUES, mode=PETSc.ScatterMode.FORWARD)
# Solve linear problem
solver.solve(L, delsol.x.petsc_vec)
delsol.x.scatter_forward()
# Update u_{i+1} = u_i + delta u_i
sol.x.array[:] += delsol.x.array
i += 1
# Compute norm of update
correction_norm = np.linalg.norm(L.array)
L_norm.append(correction_norm)
print(f"Iteration {i}: Correction norm {correction_norm}")
if correction_norm < 1e-6:
break
# bounding d value to be between 0 and 1 # not necessary given the problem formulation ?????
interimp = sol.sub(1).collapse()
interimp.x.array [interimp.x.array < 0] = 0
interimp.x.array [interimp.x.array > 1] = 1
sol.sub(1).interpolate(interimp)
# updating u, d for next iteration
solold.x.array[:] = sol.x.array
solold.x.scatter_forward()
# incrementing load step
load += delta_u
# end stopwatch
end_time = MPI.Wtime()
print(f"Elapsed time: {end_time-start_time} s.")
I would be grateful if anyone can point out where i am making mistake or the way whereby I can solve the problems.
(If the problem can be resolved this way, I would prefer not to use the SNES solver, as my damped Newton method is specifically customized for my problem. However, if using SNES provides a significantly more convenient solution, I am open to exploring that approach—please guide me on how to implement it.)
