Plot mesh parallel, show partitioning
I’d like to pyvista-plot my mesh, when running on multiple processors, with a flag for showing mesh partitioning or not (the ‘or not’ is where I struggle).
I am following How to collect the global mesh without writing a file - #3 by edgar and Pyvista, how to gather data to plot on rank=0 - #3 by LiborKudela, but would like to avoid creating a FunctionSpace if not necessary. So I got the following MWE:
import pyvista,dolfinx
show_partitioning = True
domain = dolfinx.mesh.create_rectangle(MPI.COMM_WORLD,[(0,0),(1,1)], (10,10))
topology, cell_types, geometry = dolfinx.plot.vtk_mesh(domain)
num_cells_local = domain.topology.index_map(domain.topology.dim).size_local
num_cells_local_geom = domain.geometry.index_map().size_local
# Gather data
num_dofs_per_cell = topology[0]
global_topology = domain.comm.gather(
    topology[: (num_dofs_per_cell + 1) * num_cells_local], root=0
if show_partitioning:
    global_geometry = domain.comm.gather(geometry[:, :], root=0)
    # FAULTY LINE IS HERE:
    global_geometry = domain.comm.gather(geometry[:num_cells_local_geom, :], root=0)
global_ct = domain.comm.gather(cell_types[:num_cells_local], root=0)
if domain.comm.rank == 0:
    root_geoms = [np.vstack(global_geometry)]  if not show_partitioning else global_geometry
    root_tops = [np.concatenate(global_topology)]  if not show_partitioning else global_topology
    root_cts = [np.concatenate(global_ct)]  if not show_partitioning else global_ct
    plotter = pyvista.Plotter()
    colors = ['k','r','b','g']
    for color, root_top, root_ct, root_geom in zip(colors,root_tops, root_cts, root_geoms):
        grid = pyvista.UnstructuredGrid(root_top, root_ct, root_geom)
        plotter.add_mesh(grid, style="wireframe", color=color, line_width=2)
    plotter.view_xy()
    plotter.show()
This works nicely for --np 1 (obviously) and works nicely with --np 2 and show_partitioning = True, but shows something a wrong with --np 2 and show_partitioning = False.
I know the error must be in one particular line (highlighted in the MWE), but can’t figure out what it should be. A hint is much appreciated!
I am not quite sure what you are trying to achieve here.
You have ignored the crucial:
# Map to global dof indices
global_dofs = V.dofmap.index_map.local_to_global(topology[topology_dofs].copy())
# Overwrite topology
topology[topology_dofs] = global_dofs
This is crucial as one maps the local topology indices to a single global numbering.
For more about this see for instance section 6.2 of:
which tries to explain global ordering.
That code snipped doesn’t quite work for me since I want to operate directly on the mesh, not on a functionspace:
I’m trying to adopt
instead of
topology, cell_types, geometry = dolfinx.plot.vtk_mesh(V)
The geometry also has an index map, I.e mesh.geometry.index_map.local_to_global that you have to use to map the topology array retrieved by plot.vtk_mesh to its global indices before gather them.
I believe I tried that before, as I figured the geometry object would behave almost identical to a Function in a Functionspace. But I’m getting the error message:
global_dofs = domain.geometry.index_map.local_to_global(topology[topology_dofs].copy())
AttributeError: 'nanobind.nb_method' object has no attribute 'local_to_global'
I’m running v0.8.0. Should I upgrade to 0.10.0? Comparing dolfinx.cpp.mesh — DOLFINx 0.8.0 documentation to dolfinx.mesh — DOLFINx 0.10.0.0 documentation it looks like the interface changed (but not from v0.8.0 to v0.9.0 though?).
In your view, what are the primary resources for developing ones understanding of Fenics’ inner workings? I notice I’m often limited to manipulating snippets that I find online. I also notice that FenicsX asks its users to have a deeper understanding of the software than Fenics. The paper you cite is a good start, I had seen it a while back but I’ll give it a second read.
Try
global_dofs = domain.geometry.index_map().local_to_global(topology[topology_dofs].copy())
The paper is a good start.
I would also consider
and
that goes through some notions.
Also the short note I made on mesh creation might be of help
Ah damn, sorry, that was a novice mistake. That seems to have done it, thanks.
Current working MWE:
show_partitioning = False # or True
# Gather data
    # Map topology to global dof indices
    topology_dofs = (np.arange(len(topology)) % (num_dofs_per_cell+1)) != 0
global_topology = domain.comm.gather(topology[: (num_dofs_per_cell + 1) * num_cells_local], root=0)
    colors = ['k','r','b','m']
    plotter.view_xy()
    plotter.show()
And thanks for the addititional resources. I’ll take a look.
It seems like a lot of great resources are available (scifem, oasix, comet, ambit, donfin_dg, etc), but they are not too easily found if one doesn’t know they exist. Maybe it’s an option to create a separate “Category” on the Discourse where people can promote their work?
I’ll make a category for that, as it lowers the threshold for promoting. We have had internal discussions on how to promote external libraries.
