Plot of solution only showing at nodal values
I am using Fenics to extract the FEM matrices and to plot the finite element solution. I am using another language to solve the resulting time dependent system.
The domain of the PDE is a complicated shape with different portions of the boundary subject to various boundary conditions.
I am doing a simple experiment in which I supply the nodal values of the FEM solution, i.e.
unodalVals = 10*np.ones(1357)
Then converting it to a vector object via
u.vector().set_local(unodalVals)
And subsequently plotting the FEM solution in my domain with a complicated shape.
plot(u)
However, below is a snippet of how the plot looks like:
I was expecting to see a single color just covering the whole domain. Instead, what I get are blobs of the same intensity at the nodes of the mesh.
I am new to Fenics and did not encounter this issue with the heat equation example in the tutorial.
Any suggestions how to resolve this? Help appreciated.
A minimal working example would help diagnose the issue. But it looks like you’re providing the wrong / not enough data to a high order space.
Hi nate, thanks for getting back. Are you saying that the dimension of the nodal values I provided, 1357, is not enough? The resulting matrices I get from assemble in fenics have this dimension so I am not sure what you mean…
Another issue is that the inputs to FunctionSpace are xml.gz files.
It’s very difficult for me to help/debug without having a minimal working example.
Hi Nate,
Yes, that’s fair. Here’s a minimal working example. I really appreciate your help looking into this:
Here’s my code:
import dolfin as df
import fenics as fe
mesh_file = 'ref3_mesh_fenics.xml.gz'
gamma_numbers_file = 'ref3_gamma_numbers_fenics.xml.gz'
# set matrix reordering off
df.parameters['reorder_dofs_serial'] = False
# read mesh file and mesh function for gamma numbers
mesh = df.Mesh(mesh_file)
gamma_numbers = df.MeshFunction('size_t', mesh, gamma_numbers_file)
# define function space linear lagrange elements P1
V = df.FunctionSpace(mesh, 'Lagrange', 1)
u = df.Function(V)
fe.plot(u)
The files included above can be downloaded from this link
I hope it’s more clear now…
Just as I said, you’re not providing enough data:
import dolfin as df
u = df.Function(V)
print(f"Number of DoFs: {V.dim()}, mesh vertices: {mesh.num_vertices()}, size of unodalVals: {unodalVals.shape}")
df.plot(u)
Number of DoFs: 5177, mesh vertices: 5177, size of unodalVals: (1357,)
Accounting for this, I get what I assume is your expected result:
Nate, thank you for your reply. However, I do not see what changes you made to my script. Did I overlook it? May I know what was the missing piece?
Choose your data correctly. It’s underprescribed. E.g. you could make the following change:
unodalVals = 10*np.ones(V.dim())
Hi Nate,
Yes, I just realized it now. Thank you so much. It turns out that the error is that I mismatched the file with the number of nodes. I should have used the file in the other directory for the 1357 degrees of freedom. This is really a stupid mistake from my end. Thanks for your patience!
