Question about Plot
I am trying to plot the solution to my PDE problem and when I turn it into a numpy array using solution_array.vector().get_local() and plot it again I see a different solution being plotted.
Can anyone point out the fault ?
    from mpl_toolkits.mplot3d import Axes3D
    # Step 1: Define the Problem (Geometry and Material Parameters)
    L_k = 1e-6  # Length of the domain in the y direction
    lam = 1e-6
    K1 = Constant(3.81e-12)  # Splay elastic constant
    K2 = Constant(3.81e-10)  # Twist elastic constant
    q0 = Constant(0)
    dim_x = 16
    dim_y = 16
    # Sub domain for Periodic boundary condition
      # Left boundary is "target domain" G
          return bool(x[0] < DOLFIN_EPS and on_boundary)
      # Map right boundary (H) to left boundary (G)
      def map(self, x, y):
          y[0] = x[0]-lam
          y[1] = x[1]
    # Create mesh and finite element
    mesh = RectangleMesh(Point(0,0), Point(lam, L_k),dim_x-1,dim_y-1)  # Define the rectangular mesh
    #1d Experiment
    #mesh_1D =  IntervalMesh(dim_x,0,L_k)
    V = FunctionSpace(mesh, "CG", 1)#constrained_domain=PeriodicBoundary())
    # Create Dirichlet boundary condition at phi(x,0)
    theta0 = Constant(0) #Expression("DOLFIN_PI", degree=1,lam=lam)
    def bottom_boundary(x, on_boundary):
      return near(x[0], 0.0) and on_boundary
    bc_bottom = DirichletBC(V,theta0,bottom_boundary)
    # Boundary condition at y=L (takes only odd multiples of pi/2)
    u_k = Constant(1)
    def top_boundary(x, on_boundary):
      return near(x[0],L_k) and on_boundary
    theta_L = Constant(DOLFIN_PI/2)#Expression("(2*u_k+1)*DOLFIN_PI/2",degree=1,u_k = u_k)
    bc_top = DirichletBC(V, theta_L,top_boundary)
    # Collect boundary conditions
    bcs = [bc_bottom,bc_top]
    f = Constant(0)
    a = K1 * dot(grad(u)[0], grad(v)[0]) * dx + K2 * dot(grad(u)[1], grad(v)[1]) * dx
    #a = dot(grad(u), grad(v)) * dx
    L = f*v*dx
    # Compute solution
    phi = Function(V)
    solve(a == L, phi, bcs)
    # Plot solutionT
    #plot(mesh,scalarbar = False,title="Finite Element Mesh")
    plot(phi,scalarbar = False,interactive=True)
    # Convert the FEniCS Function to a numpy array
    xyz = V.tabulate_dof_coordinates()
    #print(xyz[:,0])
    (xyz)
    n_array = phi.vector().get_local()
    n_array= n_array.reshape((dim_x,dim_y))
    print("Here is n_array")
    # Create the 3D plot
    fig = plt.figure()
    ax = plt.axes(projection='3d')
    ax.view_init(30,60)
    # Data for a three-dimensional line
    Z = np.fliplr(n_array.T)
    x_line = np.linspace(0,lam,dim_x)
    y_line = np.linspace(0,L_k,dim_y)
    X,Y= np.meshgrid(y_line,x_line)
    ax.plot_surface(X, Y, np.cos(Z), rstride=1, cstride=1,
                  cmap='viridis', edgecolor='none')
    ax.contour3D(X,Y,Z, 50, cmap='binary')
    ax.set_title('surface');
    #Line-plot
    plt.figure()
    #plt.xlabel("x")
    #plt.ylabel("Director $\phi(x,z)$ ")
    plt.plot(x_line,Z[:,dim_x//2],color = 'r') # Bottom phi = pi*x/LAMBDA
    plt.plot(x_line,Z[:,dim_x-1],color = 'g') # top    phi = (2*u+1)/2*pi
    plt.figure()
    plt.plot(y_line,Z[dim_x//2,:],color = 'r') # Bottom phi = pi*x/LAMBDA
    #plt.plot(y_line,Z[dim_x-1,:],color = 'g') # top    phi = (2*u+1)/2*pi
    #plt.imshow(np.cos(Z))
    #2d Image render
    plt.figure()
    #quiveropts = dict(pivot='middle')
    plt.imshow(Z)
    plt.figure()
    plt.quiver(Y,X,np.cos(Z),np.zeros_like(Z),pivot='mid')
