Point Source and Reflection of Waves
Hello.
I am trying to build understanding on how to deal with the reflection of acoustic waves using FEniCS. It is a fairly simple problem, yet I can’t manage to get it working for I am new to FEniCS, so any basic comments on my code will help me a lot!
The domain is a unit square with a point source in the middle of it. I have:
The Wave Equation
\partial u^2 / \partial t^2 = c^2 \nabla^2 u + f
The Weak Form
a(u,v) = \int_{\Omega} (vu^{n+1} - c^2 \Delta t^2 \nabla v \nabla u^{n+1})dx
L_{n+1}(v) = \int_{\Omega}(2u^{n} - u^{n-1} + \Delta t^2 f^{n+1})vdx - \int_{\Gamma^N} (gv)ds
Neumann boudary condition on all the 4 walls
\partial u / \partial n = g = 0
The code I have written with some pieces of examples
T = 5.0
num_steps = 250
dt = T / num_steps
c = 1
nx = 80
ny = 80
mesh = RectangleMesh(Point(-1,-1), Point(1,1),nx,ny)
#Initial pressure
init = "0"
g_ini = Expression(init,t=0, degree=0)
u_0 = interpolate(g_ini,V)
u_1 = interpolate(g_ini,V)
#Null source term
f = Constant(0)
#Neumann boundary condition
g = Constant('0.0')
#Variational Form
a = u*v*dx - c*c*dt*dt*dot(grad(u), grad(v))*dx
L = (2*u_1 - u_0 + dt*dt*f)*v*dx - g*v*ds
# Time-stepping
t = 0
file = File("wave/wave.pvd")
for n in range(num_steps):
    #Point source
    PS = PointSource(V, Point(0, 0), sin(10 * t))
    PS.apply(u.vector())
    #Solve, no boundaries specified as I have only Neumann
    solve(a == L, u)
    plot(u)
    #Update solutions
    u_0.assign(u_1)
    u_1.assign(u)
    file<<u
The output is completely static. No point source and no reflection. What am I missing ?
Thank you in advance!
Hello
You have multiple issues in here:
  1. You should define a VectorFunctionSpace NOT a FunctionSpace as displacement is not scalar but is a vector
  2. In your weak form you should use inner product for multiplication of the trial and test functions (Same thing for the linear part of the variational form)
  3. The terms in the bilinear part of the variational form, should be added NOT subtracted
I did some modifications in your code. The below should work:
t = 0
T = 5.0
num_steps = 250
dt = T / num_steps
c = 1
nx = 80
ny = 80
mesh = RectangleMesh(Point(-1, -1), Point(1, 1), nx, ny)
V = VectorFunctionSpace(mesh, 'CG', 1)
g_ini = Constant((0.0, 0.0))
u_0 = interpolate(g_ini, V)
u_1 = interpolate(g_ini, V)
a = inner(u, v) * dx + c * c * dt * dt * inner(grad(u), grad(v)) * dx
L = 2*inner(u_1,v)*dx-inner(u_0,v)*dx
bc = DirichletBC(V,g_ini, "on_boundary")
while t <= T:
    A, b = assemble_system(a, L, bc)
    PS.apply(b)
    solve(A, u.vector(), b)
    u_0.assign(u_1)
    u_1.assign(u)
    file << u
Thanks a lot for the explanations and the code @Leo, that did trick!
May I ask a second question?
For the next step I’d like to have a front wave propagating from the left boundary to the right (no point source). I tried redefining the expression for the left boundary and maintaining the others:
tol=1E-14
u_L = Expression(('50*sin(10*t)','50*sin(10*t)'), degree=2, t=0)
def boundary_L(x, on_boundary):
    if on_boundary:
        if near(x[0],-2,tol):
            return True
            return False
        return False
bc_L = DirichletBC(V,u_L, boundary_L)
def boundary_T(x, on_boundary):
    if on_boundary:
            return False
            return True
        return False
bc_T = DirichletBC(V,g_ini, boundary_T)
bc = [bc_L,bc_T]
But this gives have no output. What would you suggest ?
Thanks once again.
Please consider the following:
t = 0
T = 5.0
num_steps = 250
dt = T / num_steps
c = 1
nx = 80
ny = 80
tol = 1E-14
# Define boundary
def LEFT(x, on_boundary):
    return on_boundary and abs(x[0] + 1.0) < tol
bound_x =  Expression(("sin(10*t)"), degree=1, t=0)
while t <= T:
    bound_x.t = t
    bc_x = DirichletBC(V.sub(0), bound_x, LEFT)
    bc = [bc_x]
    u_0.assign(u_1)
    u_1.assign(u)
    file << u
Brilliant!
Now I see a bit better how to declare boundary conditions for different scenarios.
Thanks again!
Hi again.
I realized something unexpected. Take a look at the output, it shows the displacement in the X coordinate. The amplitudes are getting lower as they drive away from the source.
Is that correct, given that there is no loss term in the equation?
Thanks!
Well, based on what I am seeing here, the problem could be the size of the time step. You may want to use smaller time steps (0.001 instead of 0.004). Please look at the results of this quick test:
Yes, I admit I haven’t checked this. Doing as you did gives much better results.
I’ll try and check for the convergence requirements.
Thanks once again!
Hi, sorry to bother again, but I was reading back through this and thinking what if I wanted to declare a pressure wave equation? Pressure is a scalar, so it should be OK to define a FunctionSpace and use regular multiplication in the weak form, right?
I did a quick test and I show a comparison between defining a FunctionSpace (left) and a VectorFunctionSpace (right). They seem very similar to me. Do you have any comment on that?
I’m asking this because my next step is to define absorbing boundary conditions, maybe through perfectly-matched-layers, and the only references I found use pressure to deduce the PMLs.
maybe this example can be of any help (using vedo.dolfin):
