Hi all, I’m new to FEniCS, and as a first working example I wanted to simulate the reflection of a plane wave off a flat surface. I begin with a box-shaped Mesh with MeshTags indicating the reflective surface at y = 0, and the remaining boundaries. I define a TM plane wave function E_b coming in at a 45-degree angle. I want FEniCS to compute the ‘scattered’ function E_s, which I expect to be a plane wave travelling in the perpendicular direction.
With E = E_b + E_s, I use the double-curl equation
\qquad \nabla \times \nabla \times E - k^2 E = 0 \text{.}
At y = 0, I impose the boundary condition
\qquad n \times E = 0 \text{,}
while at the remaining boundaries, I impose the first-order absorbing boundary condition
\qquad n \times (\nabla \times E) + j k n \times (E \times n) = 0 \text{.}
I dump these equations straight into the code, as
a = ufl.inner(ufl.curl(ufl.curl(E_s)) - k**2 * E_s, v) * dx \
+ ufl.inner(ufl.cross(n, E_s), v) * ds_surface \
+ ufl.inner(ufl.cross(n, ufl.curl(E_s)) + 1j * k * ufl.cross(n, ufl.cross(E_s, n)), v) * ds_boundary
L = - ufl.inner(ufl.cross(n, E_b), v) * ds_surface
where
V = FunctionSpace(mesh, FiniteElement("N1curl", mesh.ufl_cell(), 3))
E_s = TrialFunction(V)
dx = Measure("dx", my_mesh)
ds = Measure("ds", my_mesh, subdomain_data = facet_tags)
ds_surface = ds(1)
ds_boundary = ds(2)
n = FacetNormal(my_mesh)
I solve a == L as a LinearProblem, and the computation goes through without error, however the output of E_s is not remotely what I’m expecting.
Since I’m new to FEniCS (this is my first code snippet), I expect that I’m making a basic mistake in my setup. Does anyone have any suggestions?
Edit: Full code for completeness. I believe I’m using the dolfinx/lab:stable Docker image for running the code. The Git commit has for dolfinx is 24f86a9ce57df6978070dbee22b3eae8bb77235f.
import pyvista as pv
# Create box mesh
my_mesh = mesh.create_box(
MPI.COMM_WORLD,
[[0, 0, 0], [1, 1, 1]],
[10, 10, 1] # z-direction is irrelevant for now
boundaries = [(1, lambda x: np.isclose(x[1], 0)), # Reflective boundary
(2, lambda x: np.isclose(x[0], 1)) or np.isclose(x[0], 0) or np.isclose(x[1], 1) or np.isclose(x[2], 0) or np.isclose(x[2], 1)]
# Create tags for both boundaries
fdim = my_mesh.topology.dim - 1
facets = mesh.locate_entities(my_mesh, fdim, locator)
facet_indices.append(facets)
facet_tags = mesh.meshtags(my_mesh, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
class BackgroundElectricField:
def __init__(self, theta: float, n_bkg: float, k0: complex):
self.theta = theta # Angle with respect to the x-axis!
self.n_bkg = n_bkg # Background refractive index
self.kx = self.n_bkg * k0 * np.cos(self.theta) # x wavevector
self.ky = self.n_bkg * k0 * np.sin(self.theta)
def eval(self, x):
phi = self.kx * x[0] + self.ky * x[1]
ax, ay = np.sin(self.theta), np.cos(self.theta)
return (-ax * np.exp(1j * phi), ay * np.exp(1j * phi), np.zeros(x[2].shape))
curl_el = ufl.FiniteElement("N1curl", my_mesh.ufl_cell(), 3) # ufl_cell or basix_cell depending on version
V = fem.FunctionSpace(my_mesh, curl_el)
theta = 1.75 * np.pi # Angle of incidence of the background field --- I think this is pointing to the down & right
n_bkg = 1.33 # Background refractive index
wavelength = 0.3 # Wavelength of the background field.
k = 2 * np.pi / wavelength
f = BackgroundElectricField(theta, n_bkg, k)
E_b = fem.Function(V)
E_b.interpolate(f.eval)
E_s = ufl.TrialFunction(V)
dx = ufl.Measure("dx", my_mesh)
ds = ufl.Measure("ds", my_mesh, subdomain_data = facet_tags)
ds_surface = ds(1)
ds_boundary = ds(2)
n = ufl.FacetNormal(my_mesh)
# Maxwell equations
L = ufl.inner(ufl.cross(n, E_b), v) * ds_surface
# Solve problem
problem = fem.petsc.LinearProblem(a, L, bcs=[], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
E_s = problem.solve()
# Plot results
V_dg = fem.VectorFunctionSpace(my_mesh, ("Discontinuous Lagrange", 3))
E_dg = fem.Function(V_dg)
E_dg.interpolate(E_s)
pv.start_xvfb()
plotter = pv.Plotter()
plotter.set_position([0, 0, 0])
topology, cell_types, geometry = plot.create_vtk_mesh(V_dg)
grid = pv.UnstructuredGrid(topology, cell_types, geometry)
E_values = np.zeros((geometry.shape[0], 3), dtype = np.float64)
E_values[:, : my_mesh.topology.dim] = E_dg.x.array.reshape(geometry.shape[0], my_mesh.topology.dim).real # Discard imaginary parts for plotting
grid.point_data["E_sh"] = E_values
plotter.add_mesh(grid.copy(), show_edges=True)
plotter.view_xy()
plotter.link_views()
plotter.show(jupyter_backend = 'panel')
