PointSource Method Malfunctioning
Hi guys,
I’m using FEniCS 2019.1.0 to test the convergence of finite element methods for problems with singular data. Specifically, I’m looking at the Poisson equation with a delta source - \nabla^2u = \delta(x).
Using a mollified delta, I’m able to achieve convergence to the analytical solution u = -\frac{1}{2\pi}\ln(r) for any point except the origin. However, when using the built-in FEniCS PointSource method, I can’t get convergence at all. Does anyone have any idea why this is? Find attached the code I’m using.
import mshr as mshr
import fenics as fe
plt.close('all')
class Delta(fe.UserExpression):
    def __init__(self, eps, x0, **kwargs):
        self.eps = eps
        self.x0 = x0
        fe.UserExpression.__init__(self, **kwargs)
    def eval(self, values, x):
        eps = self.eps
        values[0] = eps/fe.pi/(np.linalg.norm(x-self.x0)**2 + eps**2)
    def value_shape(self): return ()
resolution = [5, 10, 20, 40]
error_moll_delta = np.zeros(4)
error_pt_source = np.zeros(4)
h = np.zeros(4)
order_moll_delta = np.zeros(4)
order_pt_source = np.zeros(4)
for i in range(len(resolution)):
    domain_geometry = mshr.Circle(fe.Point(0., 0.), 1 + 0.01)
    mesh = mshr.generate_mesh(domain_geometry, resolution[i])
    h[i] = mesh.hmax()
    V = fe.FunctionSpace(mesh, "Lagrange", 1)
    def boundary(x, on_boundary):
        return on_boundary
    # Define boundary condition
    u0 = fe.Constant(0.0)
    bc = fe.DirichletBC(V, u0, boundary)
    #%% Using Continuous Delta Approximation
    u = fe.TrialFunction(V)
    v = fe.TestFunction(V)
    delta = Delta(eps=1E-4, x0=np.array([0., 0.]), degree=5)
    f = delta
    magnitude = fe.Constant(1)
    a = fe.dot( fe.grad(u), fe.grad(v) )*fe.dx
    L = magnitude*f*v*fe.dx
    u = fe.Function(V)
    assembler = fe.SystemAssembler(a, L, bc)
    solver = fe.LUSolver("mumps")
    A = fe.Matrix()
    solver.set_operator(A)
    assembler.assemble(A)
    b = fe.assemble(L)
    bc.apply(b)
    fe.solve(A, u.vector(), b)
    u_e = fe.Expression('-1/(2*3.14159)*'
                        + 'std::log( pow( pow(x[0],2) + pow(x[1],2), 1/2) )',
                        degree = 6)
    V = u.function_space()
    mesh = V.mesh()
    degree = V.ufl_element().degree()
    W = fe.FunctionSpace(mesh, "P", degree + 3)
    u_e_w = fe.interpolate(u_e, W)
    u_w = fe.interpolate(u, W)
    e_w = fe.Function(W)
    e_w.vector()[:] = u_e_w.vector().get_local() - u_w.vector().get_local()
    error = e_w**2*fe.dx
    E = fe.errornorm(u_e, u, 'L2')
    print("Error using mollified delta with resolution ",
          resolution[i], " is ", E)
    error_moll_delta[i] = E
    #%% Using PointSource Method
    f = fe.Constant(0)
    L = f*v*fe.dx
    u = fe.Function(V)
    A = fe.Matrix()
    b = fe.assemble(L)
    delta = fe.PointSource(V, fe.Point(0,0), 1)
    delta.apply(b)
    bc.apply(b)
                        degree = 6)
    mesh = V.mesh()
    # Also plot analytical solution and error function
    error_pt_source[i] = E
    print("Error using point source with resolution ", resolution[i], " is ", E)
for j in range(1, len(resolution)):
    h_ratio = h[j]/h[j-1]
    error_ratio_pt_source = error_pt_source[j]/error_pt_source[j-1]
    error_ratio_moll_delta = error_moll_delta[j]/error_moll_delta[j-1]
    order_moll_delta[j] = np.log(error_ratio_moll_delta)/np.log(h_ratio)
    order_pt_source[j] = np.log(error_ratio_pt_source)/np.log(h_ratio)
Seems to me a duplicate of Non-Convergence When Using 'PointSource' Method, hence I am closing. If I am wrong, please get in touch with me.
