Hello everyone,
I generate a .msh file with the following script
import numpy
import pygmsh
resolution = 0.08
R = 1.0
r = 0.25
c = [0.0, 0.0, 0.0]
geometry = pygmsh.geo.Geometry()
model = geometry.__enter__()
circle_r = model.add_circle([0,-0.2,0], r, mesh_size=resolution)
circle_R = model.add_circle(c, R, mesh_size=resolution)
plane_surface = model.add_plane_surface( circle_R.curve_loop, holes=[circle_r.curve_loop])
model.synchronize()
model.add_physical([plane_surface], "Volume")
model.add_physical(circle_r.curve_loop.curves, "Obstacle")
geometry.generate_mesh(dim=2)
gmsh.write("membrane_m`Preformatted text`esh.msh")
gmsh.clear()
geometry.__exit__()
mesh_from_file = meshio.read("membrane_mesh.msh")
out_mesh = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data={
"name_to_read": [cell_data]})
return out_mesh
line_mesh = create_mesh(mesh_from_file, "line", prune_z=True)
meshio.write("line_mesh.xdmf", line_mesh)
triangle_mesh = create_mesh(mesh_from_file, "triangle", prune_z=True)
meshio.write("triangle_mesh.xdmf", triangle_mesh)
and then read the mesh in another python script
#create mesh with new method
mesh=Mesh()
with XDMFFile("triangle_mesh.xdmf") as infile:
infile.read(mesh)
with XDMFFile("line_mesh.xdmf") as infile:
# Define function spaces
Q = FunctionSpace(mesh, 'P', 1)
# Define boundaries
inflow = 'on_boundary && (x[0] < 0.01) && (x[0]*x[0] + x[1]*x[1] > (0.5*0.5))'
This second script appears to automatically assume cartesian coordinates (x[0] = x and x[1] = y) to read the mesh. Is there a way to specify in the second script that x[0], x[1] are polar coordinates (x[0] = r, x[1] = theta) instead?
Thanks
