I wanted to ask a question about post-processing: After I am solving my problem in a very fine mesh, I plot the deformation of the meshes over the body (to do so, I am using Paraview and Warp by vector filter).
However, since my meshes are very fine and the deformation of their edges is not viewable on every part of the domain, I am thinking of creating a secondary coarse mesh. Then, I want to plot the results of the fine mesh on the domain, and, plot the secondary mesh edges and their deformation on the same domain.
I wanted to know if there is any way to do this (i.e, creating a secondary mesh, and plotting their edge over the main results)? Whether using Fenics or Paraview filters would solve my problem.
I have attached the Poisson equation demo as a minimal code.
Thanks in advance for all the help!
mesh = UnitSquareMesh(32, 32)
def boundary(x):
return x[0] < DOLFIN_EPS or x[0] > 1.0 - DOLFIN_EPS
u0 = Constant(0.0)
bc = DirichletBC(V, u0, boundary)
f = Expression("10*exp(-(pow(x[0] - 0.5, 2) + pow(x[1] - 0.5, 2)) / 0.02)", degree=2)
g = Expression("sin(5*x[0])", degree=2)
a = inner(grad(u), grad(v))*dx
L = f*v*dx + g*v*ds
# Compute solution
solve(a == L, u, bc)
file = File("poisson.pvd")
file << u
